Gönderen Konu: http://www.mods.dk/ (2009 modifikasyonları)  (Okunma sayısı 1336 defa)
Çevrimdışı TB2CCC
« : 31 Ocak 2009, 11:43:12 »
Updated: 06-01-2009 Yaesu FT-8800
Subject: FT-8800 TX and RX
I just recently purchased a FT8800 and could not find any mod for the freq CAP/MARS modificaton: Called Yaesu 8-22-03 and said that it would be around...
Click here to view the article.
Updated: 24-01-2009 Icom IC-V85
Subject: TX Frequency expansion of IC-V85/E
For [USA] (#05), [USA-1] (#15), [USA-2] (#25), [EUR] (#02), [EUR-1] (#22), [UK] (#23) versions RX frequency coverage expansion No need of modificati...
Created: 25-01-2009 Yaesu FT-767
Subject: Meter replacement guide for Yaesu FT-767GX
The Yaesu FT-767GX was produced in the mid eighties. Most of these transceivers will see another decade or two before parts become scarce or the fin...
Created: 23-01-2009 Yaesu VX-3R
Subject: High capacity battery for Yaesu VX-3R
The stock Yaesu FNB-82LI battery is identical to the Kodak KLIC-5000 camera battery, and Kodak makes another battery, the KLIC-5001 (Item #1064062) th...
Created: 12-01-2009 Yaesu FT-950
Subject: FT-950 DSP firmware v11.29 update.
You will notice the difference immediately. WARNING: You perform this update at your own risk. I am not and will not be held responsible for any pro...
Created: 06-01-2009 Yaesu MH-34
Subject: Poor tx audio quality from speaker mic for Yaesu MH-34B4B
I took apart a poor sounding MH-34b4b speaker mic and happened to hit the PTT button. The normal muddy and muffled sound was replaced by a crisp clea...
Created: 05-01-2009 Yaesu VX-8R
Subject: Yaesu VX-8R out of bank modification
Here's how to do it: Take out the battery. Under the battery is a heavy, thick plastic cover with very strong adhesive. Remove it using an...
Created: 03-01-2009 Yaesu VX-3R
Subject: Battery Mod Yaesu VX-3r
Ever noticed how similar in size are the batteries of your VX-3r and an standard Nokia BL-5c battery? Even the voltage is compatible (both rated at 3...
Created: 19-01-2009 Kenwood TK-380
Subject: Modify for Field Programming for Kenwood TK-280 & TK-380
This mods is for Field programming the TK-280/380 HT's and does not require it to be program on a FPU computer system.The TK-280 VHF HT model diod...
Created: 19-01-2009 Kenwood TK-280
Created: 05-01-2009 Kenwood TS-450
Subject: Lost reception and transmit for TS-450SAT
I recently purchased a used transceiver TS 450sat, then use a couple of days I note that it lost reception and failed to transmit at times. After rev...
Created: 04-01-2009 Kenwood TS-940
Subject: Intermittent RX sensitivity / Bad Solder joints on RF Board for TS-940
This radio had intermittent RX sensitivity, especially after RF Attenuator control setting was changed. I found and resoldered cracked solder joints ....
Created: 10-01-2009 Icom IC-7000
Subject: TV Modul (PAL) for Icom IC-7000
Push and Hold [AF Gain Control - AF] for 1 sec. to enter the TV menu the LCD turns into the TV screen Push [AF Gain Control - AF] to enter the ....
"I know what is to be young
