Gönderen Konu: (YENİ) Xiegu X6100 HF/50MHz Portable SDR Transceiver  (Okunma sayısı 730 defa)
Xiegu X6100 Receiver Specifications
Frequency coverage: 0,5-30+50-54MHz
Receive sensitivity (10dBS/N)
(PRE=on, ATT=off, NB=off,NR=off, SSB/CW/AM = 10dB S/N, FM = 12dB SINAD)
SSB/CW: 0.20 uV
AM 0,55-1,79 MHz: 10 uV
AM 1,8-30 MHz: 2 uV
AM 50-54 MHz: 2 uV
ADC: 24 bit
Spectrum display bandwidth: 96 kHz
Spectrum refresh rate: 25 frames/a
Spectrum background noise: -140 dBm
Audio output: 0,5W (4 Ohm ≥10% THD)
2kHz BDR (Critical frequency suppression): ≥110 dB
RMDR: ≥85 dB
IMD3: ≥95 dBMDS: -138 dBm
Xiegu X6100 Transmitter Specifications
Frequency range
1.8~2.0 MHz
3.5~3.9 MHz
5.3515~5.3665 MHz
7.0~7.2 MHz
10.1~10.15 MHz
14.0~14.35 MHz
18.068~18.168 MHz
21.0~21.45 MHz
24.89~24.99 MHz
28.0~29.7 MHz
50~54 MHz
Output Power, internal battery: 5W
Output Power, external power supply: 10W
Stray suppression ≥ 60dB
Sideband suppression: ≥50dB
SSB Frequency Response: 300-2700Hz (-6dB)
FM Modulation Swing; +/- 5kHz
Mic Impedance: o,2-10k (600 Ohm typical)
Antenna tuner tuning impedance range: 12.5-200 Ohm
Antenna tuner initial tuning time: ≥ 10s
Antenna tuner memory recall time ≥ 0.1s
Xiegu X6100 General Specifications
Dimensions: 180 x 86 x 49 mm
Weight: x,xx kg
Xiegu X6100 In the Box
X6100 radio unit complete with antenna tuner and internal rechargeable battery
Microphone with backlit remote control keypad
Serial cable for PC connection
12 Volt DC power cord
English manual
Xiegu Service Card
Xiegu X6100 Suggested Accessories
GSOC Panadapter/Data Terminal
XPA125B 100W Solid State Linear Amplifier
Chameleon Portable Antennas
ANjo end fed dipole antennas
ModMic boom microphone & Xiegu adapter bundle
UHF to BNC adapter for connecting antennas with UHF connector
PRICE $824.90
