Gönderen Konu: QRP Labs QDX QRP digi 80/40/30/20 Mhz transceiver  (Okunma sayısı 754 defa)
« : 09 Ekim 2021, 20:24:12 »
İki üç yıldır beklenen qrplabs'ın  sdr transceiver'i sonunda satışa çıkıyormuş.
Cihaz LSB/USB desteklemiyor ama digi calismak icin tasarlanmış.Yani FT4/8 ciler için portable bir cihaz.
https://qrp-labs.com/qdx  adresinde detaylı teknik özelliklerini bulabilirsiniz.
Fiyatı 60$ cihaz 20$ kutusu seklinde.
Ama hans milli damadımız olduğundan genelde Türk amatörlere özel indirim yapıyor.
https://www.youtube.com/watch?v=j6Vnh8eiEpg  adresinden videosunu da izleyebilirsiniz.
Özellikleri şu şekilde
Four bands 80, 40, 30 and 20m
5W output at 9V supply (can be built for 4-5W at 12-13V supply)
Single signal transmission (zero unwanted sideband, zero residual carrier, zero intermodulation distortion)
Solid-state band switching and transmit/receive switching under CAT control
High performance embedded SDR SSB receiver with 60-70dB of unwanted sideband cancellation
Built-in 24-bit 48ksps USB sound card
Built-in USB Virtual COM Serial port for CAT control
Si5351A Synthesized VFO with 25MHz TCXO as standard
Easy to build single-board design, Professional quality double-sided, through-hole plated, silk-screen printed PCBs
All SMD components factory assembled
Connectors: 2.1mm power barrel connector, USB B (for audio and CAT control), BNC RF input/output
Built-in test signal generator and testing tools
Receive current 100mA, Transmit current 1.0-1.1A for 5W output with 9V supply (around 0.7A for 5W with 13V supply).
QFU firmware update for lifetime free firmware udpates, easy installation on any PC without drivers, software or hardware e.g. programmer
Optional aluminium extruded cut/drilled/laser-etched black anodized enclosure
