Gönderen Konu: (YENİ) Tuner Genius XL  (Okunma sayısı 590 defa)
« : 06 Nisan 2021, 22:41:16 »
Preliminary specification of TGXL automatic antenna tuner - 2000W.
We might change some technical details without notice.
Expected time for production and ordering - first quarter 2021.
Integrates with any transceiver
Designed to complement FLEX-6000 series transceivers and the Power Genius XL™ amplifier
Samless SmartSDR™ software integration
Complete control and monitoring (over LAN) from an intuitive Windows™ application
Contest ready - the ONLY single-radio SO2R solution in amateur radio
High accuracy SWR and power meter measures in bypass mode.... and much more.
General Specification
Tuning: Fully automatic and manually tuned operation
Frequency Range: 1.8 to 54 MHz continuous
Radio Interface: Works with all radios using Flex radio LAN, RS232, CI-V, BCD, Pin-to-Band (PTB), or use the built in frequency counter.
Alarms and Warnings: Low drive, Frequency Out of Range, Wrong band, and High power
Matching Range: Up to 10:1 SWR. Resonant antenna frequency range memories will bypass the tuner automatically.
Tuning Time: Tuning solutions (2 to 12 seconds) are stored in memory automatically. Stored memory switching is 20ms.
Tuning Power Requirement: 10W - 200W
User Interface
Large 4.5” color touch screen display
Front panel controls for manual switching, tuning & configuration
Windows™ utility application for over the network control and configuration
RF Characteristics
Nominal Impedance: 50-Ohm unbalanced
Nominal Operating Power: Up to 2000W
Duty Cycle: 100% ICAS
Protection: Intelligent SWR and power derating
1x3 version
Inputs and Outputs: 1x3 matrix (1 in, 3 out)
Switching: Matrix, manual or automatic by frequency/band
SO2R Version
Inputs and Outputs: 2 in, 2 out - each input is paired with one output
Switching: Non-matrix SO2R, manual or automatic by frequency/band
Connector type: UHF/PTFE (SO-239A)
Mechanical/Electrical
Power Supply: 12 - 16V DC @2A via an external 100 to 240 VAC power supply (supplied with TGXL)
Dimensions: 11.8” W x 13.8” D x 5.9” H (30cm W x 35cm D x 15cm H)
Weight: 15.4 lbs (7kg)
 Environmental
Temperature Range: -4F (-20C) to +122F (+50 C)
Humidity: up to 98 percent (non-condensing)
Altitude (ASL): up to 10,000 feet (3,050m)
