Gönderen Konu: (YENİ) KN-990 HF 0.1~30MHz  (Okunma sayısı 786 defa)
« : 06 Nisan 2021, 22:30:30 »
KN-990 Features:    Bangood : US$578.66
3.5 inch LCD, without touch fuction
Frequency range: Reception: 0.1~30MHz
transmitting : Amateur shortwave band
Working mode: SSB/CW/AM/FM/DIGITAL
Receiving sensitivity: 0.2uV
Minimum frequency step: 10Hz
Working voltage: 12~15V DC
Current parameter: RX  0.4A
                               TX 4A @Max
Whole machine size: 160X80X220 (mm) [excluding protrusion]
Transmitting power: rated 15 watts
Modulation mode: all mode digital modulation and demodulation.
Stray suppression system: more than 45dBc
Carrier suppression: greater than or equal to 45dBc
Selectivity: all mode bandwidth is continuously adjustable (minimum bandwidth adjustment step 10Hz).
Çevrimdışı TA0G
Ynt: (YENİ) KN-990 HF 0.1~30MHz
« Yanıtla #1 : 16 Nisan 2021, 23:51:56 »
Çok para Abey
Çevrimdışı TA2CR
« Yanıtla #2 : 19 Nisan 2021, 09:24:41 »
süper mario oyununu görene kadar almayı düşünüyordum onu görünce siprarişi iptal ettim :)
