Gönderen Konu: icom yeni mobil cihaz ic-7100  (Okunma sayısı 849 defa)
Çevrimdışı TA1AST
« : 26 Ağustos 2012, 09:59:00 »
amatör camiyasına hayırlısı olsun..
Ynt: icom yeni mobil cihaz ic-7100
« Yanıtla #1 : 26 Ağustos 2012, 20:58:05 »
SPECIFICATIONS
Type:   Amateur HF/VHF/UHF transceiver
Frequency range:   TX: 10-160 m + WARC / 6 m / 2 m / 70 cm (and 70 MHz in Europe)
RX: 0.03-200 / 400-470 MHz
Mode:   TX: AM/FM/SSB/CW/RTTY/DV (D-Star)
RX: AM/FM/WFM/SSB/CW/RTTY/DV (D-Star)
RF Power output:   FM/SSB/CW/RTTY: 2-100 / 2-100 / 2-50 / 1-35 W / (2-50 W on 70 MHz)
AM: 1-40 W (HF)
Receiver system:   Double conversion superheterodyne (WFM)
1st IF: 134.732 MHz
2nd IF: 10.7 MHz
Triple conversion superheterodyne (AM/FM/SSB/CW/RTTY)
1st IF: 124.487 MHz
2nd IF: 455 KHz
3rd IF: 36 KHz
Sensitivity:   AM (10 dB S/N)
0.5-1.8 MHz: 13 uV
1.8-29.9 MHz: 2 uV
50-54 MHz: 1 uV
144/440 MHz: 1 uV
FM (12 dB SINAD)
28-29.9 MHz: 0.5 uV
50-54 MHz: 0.25 uV
144/440 MHz: 0.18 uV
WFM (12 dB SINAD)
76-108 MHz: 10 uV
SSB/CW/RTTY (10 dB S/N)
1.8-29.9 MHz: 0.16 uV
50-54 MHz: 0.13 uV
144/440 MHz: 0.11 uV
DV (D-Star)
28-29.7 MHz: 1 uV
50-54 MHz: 0.63 uV
144/440 MHz: 0.35 uV
Selectivity:   AM (BW=6 KHz)
6 KHz (-6 dB), 15 KHz (-60 dB)
FM (BW=15 KHz)
12 KHz (-6 dB), 20 KHz (-60 dB)
SSB (BW=2.4 KHz, sharp)
2.4 KHz (-6 dB), 3.6 KHz (-60 dB)
CW (BW=500 Hz, sharp)
500 Hz (-6 dB), 900 Hz (-60 dB)
RTTY (BW=350 Hz)
360 Hz (-6 dB), 650 Hz (-60 dB)
Image rejection:   HF: 70 dB
6 m/2 m/70 cm: 65 dB
Voltage:   13.8 VDC +/-15%
Current drain:   RX: 1.2-1.5 A
TX: Max 22 A
Impedance:   50 ohms, 2*SO-239
Dimensions (W*H*D):   RF unit: 167*58*225 mm
Controller: 165*64*78 mm
Weight:   RF unit: 2.3 Kg
Controller: 500 gr
Manufactured:   Japan, 2012-201x
Other:   D-Star built-in. Dot-matrix touch-screen controller. 495+10 memoriers. IF-DSP
Voice recorder. SD memory card slot. USB audio in/out. Remote control
Built-in SWR meter
Related documents:   Pre-release info (725 KB)
Options/Accessories:
MBF-1
RS-BA1   Suction cup mounting base
IP remote control software
İcom 7000' in DSTAR modelini yapmışlar. İcom 7000'in HF ve 2m-70cm alma hassasiyeti yeni nesil İCOM 7100'den daha iyi görünüyor. İcom 7100 'ün avrupa versiyonuna 70 MHZ bandınıda eklemişler. Yeni nesil 7100' e birde kayıt hafızası için SD hafıza kartı takmak için slot bırakmışlar. Artıları eksileri cihaz piyasaya çıkınca testlerle ortaya çıkacaktır. Cihaz henüz yeni olduğu için ilk çıkan versiyonlarından hemen almamak lazım. Piyasaya oturup kullanımı başlar yeni cihaz olduğundan ilk versiyonlarda hatalar mutlaka olabilir. Böyle bir durum olursa İcom diğer seri üretimlerinde mutlaka bu eksiklikleri duyar ve düzeltir. Yoksa ABD de olsak ilk versiyon almak sıkıntı yaratmaz yazılımını düzeltmek onarım yoluna gitmek daha kolay olur. Türkiye'de butür eksiklikleri gidermeye kalkmak zor. O yüzden bekleyip görmek lazım düşüncesindeyim.
 Hayırlı olsun.
