Gönderen Konu: 145.800  (Okunma sayısı 1533 defa)
Çevrimdışı TB6DO
145.800
« : 12 Nisan 2012, 23:44:17 »
arkadşlar bu gece saat 23.40 ta uydu frekansında rusça konuşmalar duydum bu nedir bu konuda bilgisi olan arkaşalrımız varmıdır
long 34 8478 E
lat   39 8266 N
QTH LOCATOR KM79KT18RJ
Çevrimdışı TA3BC
Ynt: 145.800
« Yanıtla #1 : 13 Nisan 2012, 00:25:14 »
Dursun bey selamlar
145.800 mhz İSS uluslararası uzay istasyonu röle frekansıdır
duyduunuz sinyal röle üzerinden yapılan görüşmeler olabilir .
73s
Ynt: 145.800
« Yanıtla #2 : 13 Nisan 2012, 09:40:58 »
Meraklı arkadaşlar için Uluslararası Uzay İstasyonunun amatörlük ile i,lgili bilgileri:
INTERNATIONAL SPACE STATION (ISS) - ARISS
Catalog number: 25544
Launch date: November 20, 1998 0640z (ZARYA module)
Launch sites: Baikonur, Kazakhstan
              Kourou, French Guiana
              Uchinoura Space Center, Japan
              Kennedy Space Center, Titusville, Florida, USA
Status: Operational
Current Active Modes: FM Repeater - OFF
                      Voice -       V/v
                      BBS -         OFF
                      2m APRS -     ON
                      70cm Digi -   ON
                      SSTV -        OFF
Expedition 30/31 Crew (November 2011 - July 2012 ):
Commander:                Dan Burbank         KC5ZSX
Flight Engineer:          Anton Shkaplerov
Flight Engineer:          Anatoly Ivanishin
Flight Engineer:          Oleg Kononenko      RN3DX
Flight Engineer:          André Kuipers       PI9ISS
Flight Engineer:          Don Pettit          KD5MDT
Available Modes and Frequencies:
Digital/APRS:
Worldwide 2m packet uplink:     145.825 MHz FM 1k2
Worldwide 2m packet downlink:   145.825 Mhz FM 1k2
Worldwide 70cm packet downlink: 437.550 Mhz FM 1k2
Voice:
Region 1 voice uplink:          145.200 MHz FM
Region 2/3 voice uplink:        144.490 MHz FM
Worldwide downlink:             145.800 MHz FM
Crossband Repeater:
Repeater Uplinks:              1269.650 MHz FM
                                437.800 MHz FM
                                145.990 MHz FM - 67.0 PL (Kenwood)
Repeater Downlink:              145.800 MHz FM
                                437.800 MHz FM (Kenwood)
SSTV Robot 36:
Mode and Antenna Polarization:
V: Linear
U: Linear
Callsigns:
Belgian:                        OR4ISS
German:                         DP0ISS
Russian:                        RS0ISS
                                RZ3DZR
United States:                  NA1SS
2m Packet Mailbox:              RS0ISS-11
2m Digipeater alias:            ARISS
70cm Packet Mailbox:            RS0ISS-1
70cm Digipeater callsign:       RS0ISS
70cm Digipeater alias:          ARISS
Official ARISS Webpage:         http://www.rac.ca/ariss
ISS Fan Club Webpage:           http://www.issfanclub.com
APRS tracking page:             http://www.ariss.net/
ISS Daily Crew Schedule: http://spaceflight.nasa.gov/station/timelines
Remember that the crew operates on UTC time. Also, all of the time
line is NOT translated from Russian and posted.
[03302012]
NNNN
İyi çalışmalar diliyorum.
Ynt: 145.800
« Yanıtla #3 : 13 Nisan 2012, 11:50:59 »
Merhaba .
145.800 Mhz aynı zamanda İSS okul bağlantıları için kullanılmaktadır. yer istasyonu RO1A ile konferans görüşme yapılmış
Sizin duyduğunuz sesleri tüm avrupa istasyonlarıda duyup rapor etmiş
http://www.issfanclub.com/voice-reports
Ynt: 145.800
« Yanıtla #4 : 13 Nisan 2012, 12:48:13 »
Değerli Arkadaşlar
 TB6DO Dursun Öcal      TA3BC Kemal Keklik  TA8A Bilal Ekmekci  TA3EL Ali Rıza Özsarar
Beylere selamlarımı  iletirim.
Ne tesadüf benim de buna benzer bir sorum olacaktı denk geldi.
Naçizane elimde  amatör band a çevrilmiş 90 kanallı 4822 var. Ona ayarsız kısa bir tel anten bağlanmış. Sadece bu şartlar altında çukurca bir noktadan dinleme yapıyor, gönderme yapmıyor. Elime 12.000MHz bir kristal geçti ve bununla güçsüz, test amaçlı(-- blinking osilatör---yanar söner r-- beacon cihazı, başka ne ismi varsa)bir cihaz yaptım. Acaba Frekans 90 kanaldan hangisine düşecek? 87 inci  kanala düştü . O kanalda ise her zaman bir baskı var, hiç gitmiyor. İndikatör, gösterge Led devamlı yanık vaziyette.  Bu baskının kaynağını bilen ve daha önemlisi bu 90 kanalın frekanslarını yazan bir cetveli nereden bulabilirim.?
73 Hüsnü Köktürk
Çevrimdışı TA6MO
Ynt: 145.800
« Yanıtla #5 : 13 Nisan 2012, 14:54:05 »
ORBİTRON ADLI UYDU TAKİP PRĞ. BİLGİSAYARINIZA KURARSANIZ. ÇEŞİTLİ AMATÖR UYDULARIN GEÇİŞ ZAMANLARI VE GİRİŞ ÇIKIŞ FREKANSLARINI TAKİP EDER QSO DİNLERSİNİZ .
HATTA BİR CROS YAGİ YAPARSANIZ. UHF GİRİŞ YAPIP VHF KENDİNİZİ DUYARSINIZ.
BİR GÖZÜNÜZ BİLGİSAYAR EKRANINDA, BİR GÖZÜNÜZ TELSİZ CİHAZININ EKRANINDA TÜRKİYE ÜZERİNDEN GEÇERKEN KULANILAN FREKANSIN + - İLERİ GERİ YAPARAK TANITIM SİNYALİNİ YAKALADIKTAN SONRA BEŞ DAKİKA SÜRMEYEN . AVRUPANIN VE RUSYANIN  BABAYİGİT İSTASYONLARI ÇAGRILARI GELİR .
İLK ZAMANLAR BEN GECE'NİN 3:00 , 4:00 KALKIP TELSİZDEN O QSO LARI DİLERDİM. EŞİM YANIMA GELİP BU SAAT TE NEYAPIYORSUN TELSİZ BAŞINDA DEYİP BOYNUNU KIVRATIP GİDERDİ .
SAĞLICAKLA KALIN
TB6BMO - MURAT
MERZİFON
73's
Çevrimdışı TB6DO
Ynt: 145.800
« Yanıtla #6 : 13 Nisan 2012, 21:12:12 »
cevap veren , yardımcı olan tüm arkadaşlarımı ve abilerime teşekkür ediyorum.Daha önceden 1485 825 den ıss gecerken uydunun sesini duyuyordum ama ilk defa görüşmeye denk geldim güzeldi.
long 34 8478 E
lat   39 8266 N
Ynt: 145.800
« Yanıtla #7 : 15 Nisan 2012, 03:51:53 »
Birisi bunu You tube koymuş, videoya almış. Şu adresten izlenebilir
► 2:26► 2:26
http://www.youtube.com/watch?v=5PB4agJazIo
73 Hüsnü Köktürk
Çevrimdışı TB6DO
Ynt: 145.800
« Yanıtla #8 : 15 Nisan 2012, 21:39:33 »
Hüsnü hocam ilginiz için teşekkür ederim sizin verdiğiniz linkteki video zaten normal zamanlarda dinlemek mümkün ki ben her zaman dinliyorum ama ilk defa konuşmaya denk geldim.
long 34 8478 E
lat   39 8266 N
Çevrimdışı TA5ASA
Ynt: 145.800
« Yanıtla #9 : 16 Nisan 2012, 18:52:21 »
http://iss.astroviewer.net/
İstasyonu canlı olarak takip edebilirsiniz,ayrıca OBSERVATION 'dan bulunduğunuz lokasyonu girerek tam üzerinizden geçiş tarih,saat ve görünürlük netlikleri bilgilerini alabilirsiniz.
