Ana Sayfa => Neler, neler yapmışlar! *** => Konuyu başlatan: TA2M - 14 Mayıs 2008, 21:35:45
The Yaesu VX-8R HT provides a full 5 watts FM on 50/144/430 MHz plus 1.5 watts on 222 MHz.
It supports Blue Tooth hands-free operation with the optional BU-1 and BH-1 or BH-2 accessories.
There is also an optional GPS unit and antenna with loads of features. This radio supports
APRS 1200/9600 bps data communication (B band only).
Like the VX7R, the VX8R is submersible and meets IPX57 specifications (3 feet for minimum of 30 minutes).
A powerful 7.4 V 1100 mAh Lithium Ion battery is included.
An optional 3 x AA battery cell case will be offered soon. This HT is small, only 2.36 x 3.74 x 0.92 inches (thinner than VX-7R).
It supports simultaneous independent 2-signal dual receive function with both V + V or U + U. It has weather band receive with Weather Alert. A barometric sensor is included.
You can even operate Amateur radio while receiving FM broadcasts! The receive coverage is wider than VX-7R, with an independent AM/FM broadcast receiver circuit.
The dot matrix LCD display provides Memory tag up to a maximum of 16 characters. You even get a high-resolution Spectrum Analyzer with ±60 channels indication with wave monitoring of received/modulated signal! And DCS and CTCSS encode and decode is included.
AVAILABILITY UPDATE:
This new model is expected late July 2008. Pricing will be announced shortly. [05/13/08].
Features of VX-8R
Optional Bluetooth
Optional GPS
APRS 1200/9600 bps (B band only)
CTCSS/DCS Encode & Decode
Weather Receiving with Weather Alert
Wideband Receive
Dual Receive
Submersible IPX57
Dot Matrix LCD
Hi-Rez Spectrum Analyzer
meraba fiyatı nedir 73 ler tel vermeyin kontür kullanmıyorum uzun zamandır
sanırım Mustafa Bey yeni cihaz tanıtmak maksadıyla yazmış,
Cihaz VX-7R 'nin yerine geçecek olan veliaht sanırım,
Yaesu, VX-3 tasarımı ile ve şimdide vx-7 tasarımı ile dizayn anlamında yeni bir
çizgi yakalamaya çalışıyor, umarım bu sert çizgiler mobil ve sabit
cihazlarında hayata geçmez, benim pek hoşuma gitmedi.
kişisel görüşüm, sadece dizaynı ile alakalı.
İyi günler.
Merhaba
Bu cihaz Amerikada henüz FCC (Federal Communications Commission) den izin alamadığı için satışa çıkamadı.
Cihaz Amerikada Temmuz ayında satışa sunulacak ve amatörler kullanabilecek. Biz Türk amatörleri ne zaman kullanabilir ? işareti.
Cihazın özelliklerini ve bazı teknik detayları sizler için tercüme ettim.
Özellikler.
Yaesu VX-8R el telsizi maksimum 5 watts 50/144/430 MHz FM çıkış gücüne sahip. Ayrıca 222 MHz. 1.5 watts çıkış gücüne sahip. Yaesu bu el cihazında biz amatörlere güzel süprizler yaparak, opsiyonelde olsa mavi diş (bluetooth) teknolojisi ile ellerimizi serbest kılıyor. Bu özellikler için opsiyonel BU-1 ve BH-1 yada BH-2 aksesuarlarını almanız gerekecek.
Ayrıca opsiyonel aksesuarlar arasında GPS ünitesi ve anteni el telsizimize mavi diş üzerinden veri aktararak APRS programı üzerinden 1200/9600 bps veri iletişimi yapabiliyor.(B band sadece).
VX7R gibi VX8R de submersible ( su geçirmez ) Batarya olarak 7.4 V 1100 mAh Lithium Ion tip batarya kutuda standart olarak gelecek. Ayrıca 3 x AA pil alan cell case (batarya kutusu) kullanılabilecek. Acil durumlarda marketten pil alıp haberleşmeye devam etmek için güzel bir aksesuar.
Bu el telsizi gerçekten ölçüleriyle iddialı geliyor. Çünkü sadece 2.36 x 3.74 x 0.92 inches (VX-7R den oldukça kibar ). Yeni cihazımız eş zamanlı olarak 2-sinyal dual olarak dinlemektedir. V + V or U + U. Hava bandını dinleyerek hava alarmları verebilmekte ama bu özellik TA da desteklenmemekte olduğunu düşünürsek bizim için kullanışlı bir özellik değil şuan için. Ayrıca barometrik ünitesi cihazın üzerinde yer almaktadır.
* Opsiyonal Bluetooth
* Opsiyonal GPS
* APRS 1200/9600 bps (B band only)
* CTCSS/DCS Encode & Decode
* Weather Receiving with Weather Alert
* Wideband Receive
* Dual Receive
* Submersible IPX57
* Dot Matrix LCD
* Hi-Rez Spectrum Analyzer
Fiyatı şimdilik çok uçuk 999.99 $ dır.
http://www.radioinc.com/oscmax/catalog/product_info.php?products_id=1578 (http://www.radioinc.com/oscmax/catalog/product_info.php?products_id=1578)
FCC Certification: Pending (henüz beklemede )
Pricing: Not yet available - you can bet it will be incredibly competitive!
Delivery: We plan to have the VX-8R available July 2008
Cihaz henüz FCC den olur almadığını için satışı Amerikada söz konusu değil.
1000 $ fiyat ise karaborsa fiyatıdır.
Temmoz 2008 beklemek lazım. Ama fiyatı 650 - 800 $ gibi olması lazım.
This device has been approved by the Federal Communications Commission. This new model is expected late August 2008. Pricing will be announced shortly. Information showns is preliminary and subject to change. [07/10/08] K6620295X20
FCC'den onay almış olan bu cihazın, Ağustos sonunda piyasaya sürülmesi öngörülüyor. Fiyatı kısa zamanda ilan edilecektir.
almanyadaki linkteki siteyede girmiş
http://www.thiecom.de/yaesu-vx8r.html
İLGİLİ ARKADAŞLARIN DİKKATİNE;
Cihaz bilgileri incelediğimde TX konusunda bir fark gördüm
VX-7 lerde TX: FM ve AM olarak tanımlanabilmekte
VX-8 lerde ise TX: sadece FM olarak tanımlanmaktadır.
Sonuç Olarak Vx-7 özellikle AM bantlarda üstün olduğunu göstermekte siz ne dersiniz?
VX-7 AM' de Tx yapıyorda kaç watt pardon miliwatt çıkıyor ?
Aslında Yaesu VX-7 kullanılmayacak kadar kötü bir cihaz.
sub-mersible özelliği yüzünden sorun yaşatan, dış kasası sorunlu çok fazla frekansta faal gibi gözüken ama sadece göz boyamaya yönelik çalışan bir el cihazı.
Ayrıca bu göstermelik özelliklerinden dolayıda bataryası çok çabuk bitiyor.
Yaesu bence hatalarını düzeltmek ve NOKIA nın taktiğini kullanarak yeni imaj çalışmasıyla parası bol amatörleri avlamak için önce VX-3 çıkardı. Hemen arkasından VX-8 geldi.
Temel özellikler aynı bir kaç opsiyon eklenmiş onlarda deli pahalılar. Dediğim gibi imaj için parası olan alır.... :)
Bencede herkes kullandığı cihazın kendisine göre iyi ve kötü yanlarını yazarsa sorun kalmayacaktır hatta bu konuda insanlar kullanma kitapcıklarında yazan yazılar yerine birebir gercek sıkıntı ve güzellikleri göreceklerdir kenwood icom ve yaesu diğerleri pek tutulmuyor kımınde ssb kımınde gps kımınde sözde ful tx kımınde 50 mhz bence bunları anlatıp arkadaşları dogruya yönlendirilmeli tabii herkesin doğrusuda bir başka ya oda ayrı konu ben su an icin en cok v8 ve ic92ad yı merak ediyorum örneğin yokmu kullanan anlatsınlar bizde kafamızda bir şeyler tasarlıyalım (sözüm meclisten dışarı ama bir amatör gibi en azından kırıcı olmadan ) en iyi cihazlar bizlerin olması dileği ile saygılarımla 73
Arkadaşlar Merhaba;
Icom IC-92 modeli inceledinizmi?
http://www.icomamerica.com/en/products/amateur/handheld/92ad/default.aspx (http://www.icomamerica.com/en/products/amateur/handheld/92ad/default.aspx)
http://www.icomamerica.com/en/downloads/DownloadDocument.aspx?Document=332 (http://www.icomamerica.com/en/downloads/DownloadDocument.aspx?Document=332)
Sevgili Alp abi,
Senin yazının art bir niyet taşıyacağını neden düşüneyim ki ?
Hayat bir yol ve bu yolda ilerlemeye çalışırken, kullandığımız aracımız biz istemeden kimine çamur, kimine taş fırlatabiliyor.
Önemli olan bu yolculuk esnasında bilerek ve isteyerek aracımızı başkasının üzerine sürmemek ve zarar vermemektir.
Arada sıçrayan su ve çamur olaylarınıda anlayışla karşılamak ilişkilerimizi koruyabilmek en önemlisidir. :)
Bu kısa edebiyattan sonra konuya gelecek olursak, sizde haklısınız.
Her radyo amatörünün ilgi ve profesiyonellik alanları farklılık göstermektedir.
Normal olarak kullanacağı cihazlarda ona göre kabiliyetlere sahip olması, kullanıcısını daha çok memnun edecektir.
Radyo amatörlerini 3 ayrı segmente toplanıyor.
1. Acemiler
2. Orta seviyeler
3. Ustalar *****
Bu durumda 1. ve 2. segmentte yer alan radyo amatörleri cihazlarının özelliklerinin pek farkında olmayan ve cihazını başkasına ayarlatıp kullanan kişilerdir. Bu kişiler ortalıkta en çok hangi cihaz varsa yada hangi cihaz yeni çıktıysa o cihazı alıp kullanan kişiler.
3. segmente yer alan kullanıcılar uzun yılların verdiği tecrübeyle kendi kullanıcı profilini tanımlayabilmiş, ihtiyaçlarınını bilen ve ona göre cihaz tercih ederel alan kişiler.
Cihazlar içinde işimizi görecek cihaz hangisi derseniz, böyle bir cihaz yok derim.
Nedeni ise, faal bir radyo amatörünün ihtiyaçlarını tamamen karşılayacak bir cihaz yokta ondan.
Her cihazın eksiklikleri ve işe yaramayan fazlalıklarından dolayı ortaya çıkan eskileri var.
Kenwood TH-F7:
Güzel hafif ve kullanışlı bir cihaz. Fazla (gereksiz) özellikleri yok.
0-1300MHz arası all mode bir alıcı olarak çok süper olmasada cüssesine göre oldukça iyi. Özellikle harici antenle.
VHF & UHF Performansı gayet güzel dinleme ve gönderme sorunsuz.
Kullanıcı dostu menüleri sayesinde kullanmak çok ama çok kolay.
Eksi yönleri: Bu cihazın iki eksi notu var. 1. cihazın masaüstü şarj imkanı yok. 2. Bu cihazın yanında başka bir cihazla TX yaparsanız cihazın anten
anten girişindeki korumasına zarar veriyorsunuz ve dinleme sağırlaşıyor. Bu sorun bazı arkadaşların başına geldi.
Yaesu VX-7 :
Tasarım olarak güzel bir görüntüsü var. Ben kaya gibiyim imajı veriyor. Siyah modelleri öyle ama gümüş renkli modelin boyası hemen sorun veriyor.
Sub-mersible özelliğinden dolayı rakım değişimlerinde CPU sapıtıyor ve cihaz çalışmaz hale geliyor.
Geniş spektrumda RX ve TX yapıyor gibi gözüksede labratuarda yaptığımız ölçümlerde TX durumunun göstermelik olduğu ortaya çıktı. En azından mantık olarak
üzerindeki anten yetersiz kalıyor.
Eksi yönleri: Şaşalı özellikleri kullanmak bataryanın dayanma süresini düşürüyor. Batarya bir gün zor gidiyor. Gümüş renkl modelde boya sorunu. Rakımlar
arası gezintilerde CPU dengesizliği cihaz 45-60 dk arası devre dışı kalıyor.
Yaesu VX-2 :
Ben keyif amatörüyüm ağırlığı sevmem diyorsanız tam size göre bir cihaz.
İngiliz polisleri gibi arabınaz bir dual mobil cihaz koyarsanız ve rölelere yakındaki arabanız üzerinden kros yaparak ulaşırsanız sizden rahatı yok.
Ama cihaz küçük yapısından dolayı watt larını kayıp etmiş. Eee hem minik hem wattlı olmuyor.
Eksi yönleri: Batarya dayanma süresi düşük, TX gücü düşük, menüsü çok ama çok karışık.
ICOM markası için pek fazla sözüm yok. Cihazın dijital yönü amatörlerce hiç ilgi görmedi. Nedeni basit çok pahalıydı. Onun için pek tutulmayan bir cihaz
olarak E91 modeli başarısız bir grafik çizdi. Şimdi sahneye E92 çıkıyor ve özellikleri VX-8 yakın.
Bu sene eğer Kenwood yeni model çıkarmazsa sahnede Yaesu VX-8 ve ICOM IC-E92AD kapışacak gibi gözüküyor. Bu cihazlarıda test etme imkanım olunca sizlerle
görüşlerimi paylaşmaktan mutluluk duyacağım.
Korhancım maksat üzüm yemek .yazacağız konuşacağız tek problemimiz konuşmamak zaten.kusurları dökelim kimse gücenmesin güzellikleride yazalım herkes bilsin en az hata ile insanlar doğruyu bulsun.çok kolay alınmıyor bu tür malzemeler.huzur dolu günler dilerim. TB1CMR ALP
Merhaba Alp abi,
Elbette üzüm yemek zevkli olur. :)
Ayrıca bağcıyla muhabeti ilerletirsen çok güzel çilingir sofrasıda kurarlar. hi hi hi.
Ben elimden geldiğince kullandığım ve tecrübe ettiğim cihazlar hakkında fikirlerimi paylaştım.
Faydalı olacağını sanıyorum. Seninde dediğin gibi ülkemiz ekonomik şartlarında cihaz almak, özellikle yeni cihaz almak çok zor.
Merhabalar evet tüm arkadaşlara selamlar.Hocam resimler konunun yan tarafından bir atak ile girilmiş..Cihaz ile ilgili bilgimiz yok aydınlatıcı biligiler için arkadaşlara teşekkürler.Yalnız hocam biraz milliyetçilik yapmışsın,kardeşinin, muhtarın resimlerini yaınlamışsın bağlarbaşlılar hep.(Bu karelerde olmak isterdim)Kendi resminin üzerine çağrı işaretini yazsaydın daha güzel olurdu saygılarımla 73 ler
Cihazla ilgili ayrıntı ve dökümanlar nihayet Yaesu'nun sitesinde...
172 sayfalık bir kullanım kılavuzu var. Bakalım performansı nasıl olacak. Cihaz 15 Kasımdan itibaren satışta...
heyacanla bekliyorum ne kadar ayrıntılı bakalım
Cihaz satılmaya başladı.
Yumuşak eller yeşil dolarcıkları hazılasın bakalım !!!! ( Dolarda aldı başını gidiyor...)
