Ana Sayfa => Ben yaptım oldu! *** => Konuyu başlatan: TB5X_SK - 14 Mayıs 2014, 23:04:20
Yeni bir projeden herkese merhabalar...
Devrenin kartları amatör bir abimizden hediye idi.
Fırsat bulup bir türlü hayata geçiremiyordum.
Sonunda el atabildim.
Projeye ait tüm bilgileri şu adresten edinebilirsiniz...
http://www.ik3oil.it/_private/Articolo_SWR_eng.pdf
Proje şimdilik bu aşamada.. İlerledikçe resim ve yorumları paylaşacağım..
(https://lh6.googleusercontent.com/-IW_kHWLrqAE/U3PFJW8xklI/AAAAAAAAE14/oY89CdsdJEw/w1278-h852-no/DSC_0519.JPG)
(https://lh4.googleusercontent.com/-6wK_4HhZXT4/U3PFI4IzYSI/AAAAAAAAE10/ocIA4bJiXeE/w1278-h852-no/DSC_0521.JPG)
(https://lh3.googleusercontent.com/-UB5i1JBu7N0/U3PFj2Ea6WI/AAAAAAAAE2A/Ozn2MbDKCs4/w1278-h852-no/DSC_0522.JPG)
(https://lh3.googleusercontent.com/-glr3t61QRg8/U3PF33zkx-I/AAAAAAAAE2I/8VyA33f6mpg/w1278-h852-no/DSC_0523.JPG)
(https://lh3.googleusercontent.com/-DJz1wPpIQk4/U3PF7-UeTRI/AAAAAAAAE2Q/8r5-mHakOn0/w1278-h852-no/DSC_0524.JPG)
(https://lh4.googleusercontent.com/-dXWA8xJFB-k/U3PGSMma5TI/AAAAAAAAE2Y/_aO9OlI2cbw/w1278-h852-no/DSC_0525.JPG)
(https://lh3.googleusercontent.com/-YJV0wk5oJ0s/U3PGmlk3ahI/AAAAAAAAE2g/ucPNmjk7Bl8/w1278-h852-no/DSC_0526.JPG)
(https://lh6.googleusercontent.com/-TLyMciA2kp0/U3PGryut3aI/AAAAAAAAE2o/JVam3eROqx4/w1278-h852-no/DSC_0527.JPG)
(https://lh4.googleusercontent.com/-ttQe-UkNOwE/U3PHF0d1p6I/AAAAAAAAE2w/9iiJdAcPLFM/w1278-h852-no/DSC_0528.JPG)
(https://lh5.googleusercontent.com/-ZFwq_8bDT5k/U3PHXIwVRII/AAAAAAAAE3A/YoU7lBr_6wY/w1278-h852-no/DSC_0529.JPG)
(https://lh4.googleusercontent.com/-OqnG3klW_VQ/U3PHXF9yyFI/AAAAAAAAE28/WveLGcj8O8g/w1278-h852-no/DSC_0530.JPG)
(https://lh5.googleusercontent.com/-D7bm5ho9d8k/U3PDhPff78I/AAAAAAAAE04/-1DBUYRaloM/w1278-h852-no/DSC_0001.JPG)
(https://lh3.googleusercontent.com/-YUyS58DEpSs/U3PDiZmaAPI/AAAAAAAAE1A/L26lyXrWQVk/w1278-h852-no/DSC_0002.JPG)
(https://lh4.googleusercontent.com/-gqaPaj7vO0s/U3PELnVk8_I/AAAAAAAAE1Q/JSKOK02Z4hs/w1278-h852-no/DSC_0004.JPG)
(https://lh6.googleusercontent.com/-5-_YtVT8Rj0/U3PEQMwOFPI/AAAAAAAAE1Y/TzkjbBq-o6I/w1278-h852-no/DSC_0005.JPG)
(https://lh6.googleusercontent.com/-_h66jPu4q2A/U3PEUFWg-EI/AAAAAAAAE1g/Hf9SfLa-k2Q/w1278-h852-no/DSC_0006.JPG)
(https://lh6.googleusercontent.com/-QOqCzKYXi4E/U3PE3Qkxg2I/AAAAAAAAE1o/WNfMxX_OVgk/w1278-h852-no/DSC_0007.JPG)
selam,
emeğine sağlık, usta eline değince bir başka güzel oluyor :)
usta bende isterim bir tane.
kolay gelsin 73
Maşallah hocam, lcd için açılan pencere ne kadar sabır gerektirir acaba ?
Çok güzel olacak, şimdiden elinize sağlık. 73
Memet abi eline saglık linke baktım şeması herşeyi var işlemcinin HEX dosyası yok benmi göremedim saygılar..
merhaba.
güzelbir çalışma olmuş elinize saglık.
de ta7bb
(https://lh5.googleusercontent.com/-TkZzPnEuxdY/U3TpY6JDkGI/AAAAAAAAE4Y/6Nw2Cxl3paI/w1278-h852-no/DSC_0001.JPG)
(https://lh4.googleusercontent.com/-shiSopRkN6M/U3TpVQfY5DI/AAAAAAAAE4I/20sDvXo4s7o/w1278-h852-no/DSC_0002.JPG)
(https://lh6.googleusercontent.com/-4wd6FEh2S84/U3TpYPXpO5I/AAAAAAAAE4U/4aTO6kcNYdY/w1278-h852-no/DSC_0003.JPG)
(https://lh4.googleusercontent.com/-x9SkyTHimno/U3TqBlAL7cI/AAAAAAAAE4g/jaQ5S64A_es/w1278-h852-no/DSC_0004.JPG)
(https://lh4.googleusercontent.com/-8YHZCtQ6k2I/U3TqHSV6ZcI/AAAAAAAAE4w/SMygZf_in1w/w1278-h852-no/DSC_0005.JPG)
(https://lh4.googleusercontent.com/-Ms-yXNl2D_s/U3TqJCGJ2lI/AAAAAAAAE4s/sGmtwDfQoWg/w1278-h852-no/DSC_0006.JPG)
(http://)
Mehmet bey güzel işçilik çıkarmışsınız. Kalibrasyonuda yapıldımı kibar bir ölçü aleti olacak. Tebrik ederim.
merhaba.
bu projeyi bizde yapmak istesek, hex dosyasını nereden bulabiliriz.
de ta7bb
Ömer bey ;
Projeyi yapan İtalyan amatör arkadaşa mail attım.
Hex dosyasını bana yolladı ama hexte sorun var sanırım . Sorun çıkardı.
Tekrar mail attım düzeltip çalıştırınca buradan son halini paylaşacağım.
merhaba.
ilginiz için teşekkür ederim.
sonucu bekleyecegim.
de ta7bb
SWR Wattmetreyi tamamladım..
İstasyondaki yerini aldı..
Çok zor uğraştırıcı bi yönü yok. Resimlerde görüldüğü gibi ... Cabilrasyonunu da orijinal SWR metrem ile eşitleyerek yaptım.
Gayet güzel çalışıyor..
Kuplör katı ile PIC katı arasındaki bağlantıyı Filtre nüveleri ile filtrelemek gerekiyor . Arasını ayrı bir plaka ile kesinlikle yalıtmak gerekiyor.
Hex Dosyasını da ekliyorum..
Yapacak arkadaşlara başarılar dilerim..
(https://lh6.googleusercontent.com/-HRey7UNguTg/U3nsKhhmujI/AAAAAAAAE5Q/AudtA10tgEQ/w1278-h852-no/DSC_0001.JPG)
(https://lh4.googleusercontent.com/-Buyge2O9JaE/U3nsK1JJQ3I/AAAAAAAAE5U/RSdI1UaOQso/w1278-h852-no/DSC_0002.JPG)
(https://lh3.googleusercontent.com/-f-goR_E79-c/U3nsM_M0GPI/AAAAAAAAE5c/sa5Yn3xGOYk/w1278-h852-no/DSC_0003.JPG)
(https://lh5.googleusercontent.com/-TIU5k7RGpTo/U3ntcQqQyNI/AAAAAAAAE54/KlUtulbB2iE/w1278-h852-no/DSC_0010.JPG)
(https://lh5.googleusercontent.com/-XTn45Rb6uOY/U3numt7FKPI/AAAAAAAAE6E/XKnLgmMqQEg/w1278-h852-no/DSC_0011.JPG)
(https://lh5.googleusercontent.com/-9yuFX61jdC8/U3nur4G63xI/AAAAAAAAE6U/n2FVqp7n5rE/w1278-h852-no/DSC_0012.JPG)
(https://lh4.googleusercontent.com/-i2amha2J_Vc/U3nvO8NPTMI/AAAAAAAAE6c/LpXGFbfX6w0/w1278-h852-no/DSC_0016.JPG)
(https://lh4.googleusercontent.com/-NBawAPnWsAU/U3nv8eNP7EI/AAAAAAAAE60/8DIWpoZpI6c/w1278-h852-no/DSC_0017.JPG)
(https://lh6.googleusercontent.com/-J3QoEqnB9Ao/U3nwGcdbaCI/AAAAAAAAE68/kcATYEREjg4/w1278-h852-no/DSC_0018.JPG)
(https://lh4.googleusercontent.com/-AqlhtNaiwpI/U3nw6XflTmI/AAAAAAAAE7U/tIfw_ldOtkw/w1278-h852-no/DSC_0021.JPG)
(https://lh4.googleusercontent.com/-DsEtAeznkXk/U3nxY6ivf-I/AAAAAAAAE7k/aGi8c39JeYI/w1278-h852-no/DSC_0023.JPG)
(http://)
Bu arkadaş yaesu da felan çalışan bir mühendis olmasın karadan tanıyanınız varmı gerçekten hocamı ? 73
Ben Şahidim abi gerçekten hoca her yaz beraberiz ayrıca çok iyi kokoreç ısmarlar en güzel yerden :)))
Memet abi merhaba bu hex son halimi yani düzelmiş hali..
Hocam üstteki haliyle çalışıyor sıkıntı yok..
Hilmi Hocam ;
Her zaman beklerim.. Kokoreçler benden sen gel yeterki.. :)
Hocam bu projeyi kit halinde satın mı aldınız veya PCB yi kendiniz mi bastırdınız?
Ellerinize sağlık çok güzel olmuş. Güle güle düşük SWRli yüksek Wattlı çıkma dileğiyle. 73s
Kartları istanbuldan bi abimiz epey zaman önce göndermişti..
Kim bastırdı, ne zaman yaptırıldı inanın bilmiyorum..
Ütü yöntemi ile kolayca çıkarılabilir hocam. Pdf dokümanında PCB si var.....
mehmet bey çalışma için teşekkürler bu pcb lerden basabilecek arkadaşımız varmı acaba ayrıca
bu hf swr metremiz kaç wata kadar tahammül edebilir.yine bu aparatı yapmak isteyen arkadaşlarımız
için bir çalışma başlatılabilirmi.73
Mehmet hocam merhabalar, bu projeyi yapmak için harekete geçmiş bulunmaktayım. Malzemelerin siparişini geçeceğim
ama bluemavide 1N 5711 bulamadım. Onun yerine başka birşey kullansak olurmu muadili veya eşleniği araştırdım ama bulamadım.
Ali Rıza bey BAT42 veya 1n5819 diyotları işinizi görürse gönderebilirim tabi Mehmet hocama da sormak gerek orjinalmi kullanmış muadilmi muadilse ne? Araştırmalarımda Diyotu SCHOTTKY isminde biri keşfetmiş ve ismini vermişler. bende elemanları temin ettim troide kaldı bulabilirsem işe koyulcam nasipse saygılar.
Serdar bey merhabalar bende uzun bir süre bekledikten sonra sağolsun İzmir`de bulunan Hatfon (www.hatfon.com) firması gönderdi.
Montajı bitirdim. Kalibrasyonu bugün yaptım. Herhangi bir problem yok gibi EFE QRP üzerinde 2SC1971 var 7 Watt çıkış vermesi gerekiyor. Ben SWR/Watt metrede 6.5 Watt görüyorum. gayet güzel çalışıyor.
Ben daha evvel Efe QRP yapacağım vakit ebay üzerinden gr_makis adlı Yunan bir amatör telsizciden satın almıştım. Link http://www.ebay.com/itm/Ferrite-Toroid-type-FT50-43-Lot-of-5-pcs-NEW-/201061949458 (http://www.ebay.com/itm/Ferrite-Toroid-type-FT50-43-Lot-of-5-pcs-NEW-/201061949458)
İsterseniz buradan satın alabilirsiniz 5 adedi 5$ başka toroidler ve değişik malzemelerde var incelerseniz görürsünüz.
Kız kardeşim A.Ü. Bilgisayar Müh. okuyor. Acelem yok ve Eskişehir merkezdeyim beklerim diyorsanız Kurban bayramı dönüşü kardeşimle gönderebilirim 1 adet.
Ekte benim yaptığımın resimlerini görebilirsiniz. PCB yi kendim bastım ilk defa vs vs.
73s.
Ali Rıza bey inanın çok makbule geçer bayram sonuda olsa işimi görür bende bu arada pcb mi basar diğer elemanları dizerim. ilk olarak deneme yapmak istiyorum bu zamana kadar yaptığım devrelerde genelde hep başarısız oldum:( yada ufak bir elemana takıldım. bir kaç gün önce üniversal telsiz proğramlama ribi yaptım bir rus amatörün dizaynı birkaç elemanı muadil kullandım sanırım onun için takıldım yine. firma 1n5711in orjinalinimi gönderdi veyahut muadilmi? muadilse kodunu paylaşırmısınız?bu arada ilk baskı devre olarak gayet güzel olmuş tebrik ederim sizi.bende yaptığım devreleri aktif hale getirebilirsem resimlerini yükleyeceğim eskişehire gelirseniz beklerim saygılarımla.
Merhaba Serdar bey, Eskişehirdeki eski amatörler beni bilir yaklaşık 6 sene kaldım. Okul ve iş dolayısıyla.
Firma orjinal 1N5711 gönderdi onun yerine sinyal diyodu 1N90 gibi herhangi biri olabilir.
73s
ali bey çok teşekkürler troid için çok teşekkürler.
Hayati Bey :
Bu SWR/Watt Metre 5 ila 120 Watta kadar ölçüm yapabiliyor..
Frekans olarak ta 50 Mhz kadar da ölçüm yapıyor..
Mehmet bey, tebrikler takdirle karşılıyorum. 73
Buradan tüm arkadaşlara selam..
Milas/Ören'den yakında TS440S ile HF'de onair olacağım inşallah.(Anten ve yer sıkıntısını aştık sayılır).
Evet,gerçekten güzel bir devre.Sizleri tebrik ediyorum.
Kemerköy Termik Santralı'nda İSG Uzmanı ve Eğt-İSG Başmüh olarak çalışıyorum.
Ben, bu devrede işten güçten fırsat buldukça Sampling unit hariç diğer kısımları bitirdim.
Sıra geldi örneklemeye.
FT50-43 Toroid elinde fazladan olan arkadaşımız varmı? Yada temin konusunda yardımcı olabilecek arkadaş varsa minnettar kalırım.
Ücreti hiç önemli değil..
Şimdiden hepinize sevgiler,saygılarımla
ta2cj de Şafak..
Şafak bey merhabalar, ülke içinde bulmak biraz zor. Ama Yunanistanda bir amatör arkadaşımız ebay üzerinden satış yapıyor. Ben zamanında 5 tane almıştım. 1 tane EFE-QRP de kullandım. 1 tane bu SWR/watt metrede kullandım. 2 tane eskişehirdeki amatör arkadaşlara gönderdim. Elimde 1 adet kaldı o da kenarından hafif bir kırık var o şekilde verimli çalışırmı bilemiyorum. O yüzden gönderme niyetinde değilim.
Ama sağlamını aşağıdaki linkten incelerseniz satın alabilirsiniz. Takribi 5 tanesi 20TL ye geliyor kargo ücreti dahil.
http://www.ebay.com/itm/Ferrite-Toroid-type-FT50-43-Lot-of-5-pcs-NEW-/201061949458?pt=LH_DefaultDomain_0&hash=item2ed039e012 (http://www.ebay.com/itm/Ferrite-Toroid-type-FT50-43-Lot-of-5-pcs-NEW-/201061949458?pt=LH_DefaultDomain_0&hash=item2ed039e012)
selam,
FT50-43 Toroid sipariş eden oldu mu ? fazla var ise alabilirim.
Ben 2 gün önce sipariş verdim 10 güne gelir.
tamam usta, bi tane ayrı banada :)
mehmet hocam, şemadaki up / down / set bu tuşları siz kullandınız mı ? resimlerde göremedim, ve bu tuşlar ne için kullanılacak ?
(http://i.hizliresim.com/pYdRLq.jpg)
yine şemadaki programmer çıkışları var ya, onları kullanmıyoruz sanırım, kullanıyorsak ise nereye bağlayacağız ? yoksa direk pic programlama devresine bağlantı yapıp programlama yapmak için kısa yol mu yapmış ?
(http://i.hizliresim.com/kYqjmr.jpg)
Hocam ;
İlk resimdeki set butonları kalibrasyon için. Ben ön panele bu butonları koymadım içeriden yapabilirsiniz.
İkinci resimdeki programlama için. PIC i zaten programlayıp taktığınız için gerek yok o kısma..
anladım hocam, kutuya göre set tuşlarını dişarıya takmaya çalışırım, tabi bu projeyi becerebilirsem :)
selam,
şemayı yağlı kuşe kağıda tonerli yazıcı ile çıkarttım, A4 kağıdı büyüklüğünde levha alıp komple çıkartacağım,
bana kolay gelsin :)
(http://i.hizliresim.com/4R7YEA.jpg)
Resimleri buraya yükleseniz daha iyi olur Kadir hocam, sitelere yüklenenler bazı pc`lerdeki web filtrelerinden dolayı gözükmüyuor :( Kolay gelsin.
selam,
hocam ben word dosyasını ekliyeyim, mutlaka lazım olan arkadaş olur, çıktı alabilirler.
ustalar,
bugün pbc leri bastım, ama pdf dosyasındaki resime göre basınca, PIC 16F876 entegrenin olduğu pbc ters oldu, sanırım o şemayı ters çevirip yazdırmamız gerekiyor :(
yukarıda baskı şemasını vermiştim indiren arkadaşların dikkatine,
yeni hali ektedir.
bilal amca yukardaki dosya eklentisini silermisin sana zahmet. 73
baskı devre çıktısının düzgün hali ektedir,
devre bitmek üzere, bakalım çalışacak mı :)
http://i.hizliresim.com/J7YO5n.jpg
Hocam resimi buraya atarmısın göremiyorum ben malum şirkette olduğumdan filtre sistemi :(
Çalışır çalışmaz değil. Kalibrasyonunu yaptıktan sonra 10 numara çalışıyor.
ali hocam, foruma eklediğimde forum veri tabanına yüklenme olduğu için, resimleri foruma eklemiyorum, boşuna foruma yük olmasın.
facebook (https://www.facebook.com/ta2iky/media_set?set=a.385924828242691.1073741882.100004755312157&type=3) profilimden bakabilirsiniz.
Kadir amca,
Hassasiyetin için teşekkür ederim. Fakat sınırlar dahilinde pek sıkıntı çıkmıyor. Resim boyutunu küçültüp. Ekleyebilirsiniz. Ben yukarıdaki mesajınıza ekledim. Başka yere yükleyip link verdiğinizde oradan silinince bütün emekler boşa gidiyor.
Kıymetli Arkadaşlar,
http://www.telsizciler.org/index.php/topic,20697.0.html linkindeki mesajda çok basit resim küçültme programı ile ilgili bilgiler bulunmaktadır.
Kadir hocam eline koluna sağlık. Yalnız şu 3 ayaklı trimmeri nereden buluyorsunuz bir türlü bulamadım ben. 60pF lık değilmi o?
Delab ta var hocam 70 pf
http://www.delab.net/70-pF-Ceramic-Trimmer,PR-180.html
ali hocam, benden evvel mehmet hocam direkt ürüne ışınlamış :)
bende oradan almıştım, 70p
Mehmet hocam selamlar,
Bu projeyi elimden geldiğince bende yapmaya çalışıyorum ama son noktada kalibrasyon konusunda sıkıntı yaşıyorum. 15 watt ile kalibre ediyorum devreyi, cihaz üzerinden watt artırdıkça SWR-WATT metre üzerinde okuduğum değer çok farklılık gösteriyor. Bir türlü aynı yada yakın değerleri okumayı beceremedim.
Genel olarak nerede yanlış yapıyor olabilirim acaba?
73.
Can EKLER / TB2BCE
