Ana Sayfa => Ben yaptım oldu! *** => Konuyu başlatan: TB5X_SK - 11 Mart 2012, 01:36:41
Eldeki artık malzemelerden yaptığım QRP ciler için ihtiyaç bir alet.
Yapımı oldukça basit resimler her şeyi anlatıyor sanırım.
20 adet 1 K lık 2watt direncin paralel bağlanması ile size 50 OHM 'luk bir sunu yük oluşuyor.
Gerisi el becerisi maharet..
Anlık olarak 60 70 Watta kadar test ettim. Biraz ısınsa da dayanıyor..
Yapacak arkadaşlara başarılar dilerim..
73..
(https://lh4.googleusercontent.com/-r886TOlKidc/T1vidIZQTOI/AAAAAAAADVM/_PWpNaB0_1Q/s720/DSC_0642.jpg)
(https://lh6.googleusercontent.com/-uARKi7_hfRc/T1vidHqSOQI/AAAAAAAADVU/db6M09fWABI/s720/DSC_0643.jpg)
(https://lh6.googleusercontent.com/-eEok0eX2RRw/T1vidaZtMqI/AAAAAAAADVQ/fchEUi3FLBw/s720/DSC_0644.jpg)
(https://lh6.googleusercontent.com/-4i7KcEPv9Os/T1vieamRR7I/AAAAAAAADVo/pmOza2XbQoI/s720/DSC_0645.jpg)
(https://lh3.googleusercontent.com/-j9poaPlPAhA/T1viece2bMI/AAAAAAAADVs/g0p3uX7QK5Y/s720/DSC_0646.jpg)
(https://lh5.googleusercontent.com/-mImNaEeI-3w/T1vieuE7uqI/AAAAAAAADVk/_Ybpw7JAwbU/s720/DSC_0647.jpg)
(https://lh5.googleusercontent.com/-3KRGPXtUO3A/T1vifiJ32JI/AAAAAAAADV0/i4OoIG1Rj3M/s720/DSC_0648.jpg)
(https://lh5.googleusercontent.com/-Cj0zNAN9oFQ/T1vif0761JI/AAAAAAAADV8/M8U84zFQA-A/s720/DSC_0649.jpg)
(https://lh4.googleusercontent.com/-INw17l6j63w/T1vigO5AyKI/AAAAAAAADWA/lwIGx0VcFCg/s720/DSC_0650.jpg)
(https://lh5.googleusercontent.com/-tAgfCVYNG-g/T1vigVHMnBI/AAAAAAAADWI/mJBNJ4DDonM/s720/DSC_0652.jpg)
(https://lh4.googleusercontent.com/-WimmMWdfe-U/T1vig2Jh3nI/AAAAAAAADWQ/HhgHsufHgh0/s720/DSC_0653.jpg)
(https://lh5.googleusercontent.com/-6NijiGjREEg/T1vihH_xVBI/AAAAAAAADWo/PXqEmbiLthM/s720/DSC_0654.jpg)
(https://lh6.googleusercontent.com/-wbxrllc2JlM/T1viheVxR4I/AAAAAAAADWk/pld_UzQ9zNo/s720/DSC_0655.jpg)
(https://lh5.googleusercontent.com/-Ka5ezGdxWa4/T1vih9mGyYI/AAAAAAAADWg/3CnIwkJllCY/s720/DSC_0656.jpg)
(https://lh3.googleusercontent.com/-qqK-RdUXLjI/T1viikuxkpI/AAAAAAAADW0/ScWQ7g-mCjM/s720/DSC_0657.jpg)
(https://lh6.googleusercontent.com/-o0Lswvfcj0Q/T1vijPoinFI/AAAAAAAADW4/qxHOPSbDSHA/s720/DSC_0658.jpg)
(https://lh5.googleusercontent.com/-KQaednkIqKs/T1vijO7tMUI/AAAAAAAADXA/k8v0AFMmIz8/s720/DSC_0659.jpg)
(https://lh6.googleusercontent.com/-u15728l5e3M/T1vij9UP2LI/AAAAAAAADXU/5Peb8okRs6M/s720/DSC_0660.jpg)
(https://lh3.googleusercontent.com/-EQ2GloRoJuY/T1vijxj4UfI/AAAAAAAADXQ/llOyk8_siec/s720/DSC_0661.jpg)
(https://lh6.googleusercontent.com/-zK3FdxplH_0/T1vikPmmAiI/AAAAAAAADXY/sfBuLNDLB8c/s720/DSC_0662.jpg)
Başka projelerde görüşmek üzere 73 ler...
Tebrikler..
Çok güzel anlatım.
Maalesef dummy load kullanmayı bilmiyoruz. Frekansta görüşme varmı demeden onun yerine ıslık, olaaa ile testlerimizi havaya yapıyoruz. (istisnalar hariç)
Mehmet bey dirençleriniz yok kaliteli değil yok öyle yok böyle demiyorum bence çok ihtiyaç duyulacak güzel bir çalışma. Kutuda çok güzel olmuş. Atıl malzemeden en güzel bu olurdu. TEBRİKLER..
Mehmet Hocam,
Elinize sağlık güzel çalışma olmuş.
Saygılar, 73...
Mehmet abi yine cok guzel bir iscilik cikarmissin. Ellerine saglik.
Hocam gerçekten çok güzel yapmış, çok da güzel anlatmışsınız. Amatörden çok profesyonel işi bir çalışma olmuş. Tebrikler ve paylaşım için teşekkürler.
Bu dirençlerin bir yerlerinden uç alıp, ucuna bir küçük panelmetre vb bağlayıp dummy load + güç ölçer şekline getirmeyi de düşünmez misiniz?
Mehmet bey, ellerinize sağlık. 73 ler
Mehmet hocam ellerine sağlık güzel olmuş. Kendi ihtiyaç duyduğunuz malzemeleri teker teker zamana yayılmış olarak tamamlıyorsunuz. Ne güzel!
TA3EN Hüseyin KARAGÖZ
Merhaba güzel işçilik,
Birgün Hurdalığın birinde gezerken ayağımıza bunun açık modeli bir donanım takıldı.Baktık, hesapladık hemen aldık.Eve gelince ben bnc dişi konnektör monte ettim.Aman gezinirken dikkat edin.
TA2JU
mehmet bey merhaba sizden esinlenerek bende 1 tane yaptım.aliminyum bulamadım ,eski pertinaksları kullanarak kutuladım.ancak fazlası ile işimi görüyor.
teşekkürler.
Yalın Bey,
Süper olmuş elinize sağlık. QRP ile uğraşanlar için çok işe yarıyor.
Güle güle kullanın..
73 ler...
Arkadaşlar ,
El becerileriniz için kutlarım ve başarılarınızın devamını dilerim .
Diğer arkadaşların yanlış bilgilenmesine mahal vermemek adına dummy load imalatlarında kullanılan dirençlerin (non-inductive) karbon direnç olması gerektiğini hatırlatmakta fayda görüyorum .
BENDEKİ DİRENÇLERİN ÜZERİNDEKİ BİLGİLER;
DALE NHL-50-02Z
600 OHM 5%
50W 7728
GÖRÜNÜME GÖRE KARBON DİRENÇ
İNTERNETTE TAM BİLGİLERİ BULMADIM
Aziz bey uyarınızı okudum,
Kullanılan dirençlerin yanlış olduğunu gördüğünüz için mi uyardınız,yoksa bir eksik noktayı tamamlamak için mi ?
Uygulamada bir yanlışlığım bilgi eksikliğim var ise tamamlamak isterim.
İlginize teşekkür ederim.
Aziz beyin uyarısı doğru.
Karbon olmayan dirençler indüktör gibi davranacağından suuni yük olarak kullanılmazlar.
Bilgi için tekrar teşekkürler 73..
Aydınlatma ve uyarılar için teşekkür ederim.
Mehmet bey;
Yalın bey;
Gerçekten ellerinize sağlık böle resimle antatım yaratıcılığınızı sunmak bizler için iyi fırsat olmuştur. Çok sağolun.
Nihayet havyamı çıkardım ve montaj sezonunu başlattım :) Yeni FT-857 mi denemek için ben de en kısa yoldan bir dummy load imal ettim. Malzemeler 2 adet bakırlı plaket, 20 adet 1k/5W metal oksit film direnç, bir adet eski PL-259 fiş.
20 adet direnci paralel bağlanacak şekilde plaketlere lehimledim, böylece toplam direnç 50 ohm, toplam dayanma gücü de 100 W olan bir dirençler dizisi imal etmiş oldum. Dirençler biraz toleranslı idi, toplamda 49.8 ohm oldu ama sanırım idare edecek, deneyince göreceğiz.
Sıra geldi denemeye. Önce TA2PW Mustafa abiden devir aldığım Forty ile başlıyorum. Sonuç gayet iyi, hiç sıkıntı yok. 40 m bandında antensiz dummy load ile bir CQ Contest çağrısını çok net olarak duyuyorum, birileri yarışma ayağına lineerini ateşlemiş anlaşılan :) Bu güzel cihazı bana kazandırdığın için çok teşekkürler Mustafa ağabey, inşallah amatör olarak senin yüzünü kara çıkartmam.
İlk göz ağrılarımdan Midland 8001'e takıyorum ve güç 12 W'a çıkıyor. Benim dummy'de tık yok, aslanlar gibi dayanmakta.
Sıra geldi Yaesu FT-857D yi denemeye... Switch beslemeyi ve Yaesu'yu tezgaha koyup bağlıyorum. Gücü kademeli olarak arttıraraktan denemelere devam ediyorum. 100W güçte sürekli ıslık çalınca dirençler biraz ısınıyor ama koku yok, duman yok. Olmuş :) Artık sıra ekran görevi yapacak bir metal kutu bulup dummy loadı içine yerleştirmeye geldi, yarın bitpazarına bir çıkayım bakalım :)
Bu da benim 50 ohm Sunni yük uygulamalarımdan.
50 ohm sunni yük ün açık şeması ve konu ile ilgili linkte açıklama mevcuttur.
http://www.amatortv.com/rxtxayar.htm
Vesile olduğunuz için çok teşekkür ederim.
Kutu olarak sakız kutusunu beyaza boyadım, delerken ''ufak'' bir hata yaptığım için kapak elden çıktı ama böyle de konnektör tam oturdu ☺ Isıdan sanırım tam 50 Ohm gösteriyor, montajdan önce 49.3 idi. İşimi fazlasıyla görecektir. ☺
Uzun zaman önce yapmış olduğum dummy
Karbon dirençler trafo yağı kullanılarak soğuyor 200 watt yazdığıma bakmayın çok daha fazla güçlerle sorunsuz çalısmıştır.Ellerinize saglık.73
Bu da benim küçük "dummy load"
Yapım aşamalarını gösterir fotoğrafları kullanmaya çalıştım.
TA3AS
