Ana Sayfa => Haberiniz var mı? *** => Konuyu başlatan: TA5FA - 25 Haziran 2016, 02:46:37
Başlık: (YENİ) ICOM IC-7300
Gönderen: TA5FA - 25 Haziran 2016, 02:46:37
Diyeceksinizki yahu aylar oldu çıkalı neyin yenisi  haklısınız başlık olarak sadece bu cihaza yönelik paylaşımlar yapacağımdan yeni başlığını atma gereği duydum aslında pekte haksız sayılmam daha çıkalı 1 yıl olmadı.
(https://3.bp.blogspot.com/-u1uFbytRv58/V221NHe0waI/AAAAAAAAom8/dM4EMLl4kUw-X7grY0YaMNCcFdF693hgACLcB/s1600/IC-7300.jpg)
(http://www.ab4oj.com/icom/ic7300/images/ic7300rp.jpg)
(https://3.bp.blogspot.com/-5JvVkt4YTOM/V220aIdwUUI/AAAAAAAAomw/o46afB3BMHIwycS6fuigQNqoyWsTJY_ZgCLcB/s1600/2016-06-25_01-27-57.png)
HF/6m, kapsayan  tüm bandlarda 100W çıkış gücü
EU Avrupa versiyon: HF/6m/4m (50W > 4m)
SSB/CW alıcı hassasiyeti, preamp açıkken: (2.4 kHz, 10dB S+N/N): HF 0.15μV (-123 dBm), 6m 0.12μV (-125 dBm)
Birbirinden bağımsız HF ve 6m alıcı preamps (Preamp 1 > HF, Preamp 2 > 6m)
Modelar: SSB (J3E), CW (A1A), RTTY (F1B), AM (A3E), FM (F3E)
Frekans stabilliği : 5 * 10-7 (-10...+60°C)
Direct-sampling SDR (software-defined radio) receiver  Tamamen SDR  K3 - Flex Radio gibi SDR öncülerinin de önünde bir çalışma
ADC: Linear Technology LTC2208-14. ADC driver: Linear Technology LTC6401. FPGA: Altera EP4CE55F2317N. DSP: TI TMS320C6745 (375-456 MHz, low power consumption). DAC: Intersil ISL5857IAZ.
ADC sampling rate: 124.033 megasamples/sec
Receiver signal path: RF preselector - ADC - FPGA - DSP - DAC - AF stage
15 bandpass filters in RF preselector
New "IP+" feature turns on ADC dither and randomizer to extend ADC dynamic range when strong signals are present
Selectable 16 dB attenuator for LF/MF RX range (30 kHz - 1.6 MHz)
ADC overflow (clip) indicator: OVF displayed on screen
Turn down RF GAIN when OVF display appears
Digital up-conversion (DUC) transmitter architecture using FPGA driving DAC
Transmitter signal path: Baseband amplifier - ADC - DSP - FPGA - DAC - RF BPF - ALC - PA - LPF
FPGA also performs digital down-conversion, frequency control and decimation (RF sub-band to baseband) digitally
FPGA executes TX functions: digital up-conversion (baseband to RF band) and frequency control
Improved phase noise performance due to low-noise ADC clock source (typ. RMDR: 97 dB at 1 kHz offset)
Fully-digital FFT spectrum scope and digitally-generated screen image; FPGA drives display processor via digital bus
Real-time, high-resolution spectrum scope includes waterfall
Scope span range ±5 kHz to ±1 MHz; amplitude range 80 dB; peak hold (continuous or 10 sec. hold time)
Scope features: selectable reference level (-20 to +20 dB), sweep speed, averaging & VBW (video bandwidth)
Audio spectrum analyser/oscilloscope screen (as in IC-7851, IC-7800, IC-7700)
Large colour TFT touch-screen display; screen selection via menu
Frequency change by touching scope screen
Screenshot capture to SD card in PNG or BMP format by pressing POWER key (configurable via menu)
Multi-dial knob opens on-screen menus; menu items selected by touching screen
Band selection and 10-key numeric "keypad" via touch-screen menus
Familiar Icom NR, NB, Twin PBT, DSP filtering and notch controls
RTTY decoder/display function
Built-in relay-type high-speed autotuner with latching relays
Tuner matching range: 16.7 - 150Ω (3:1 VSWR)
"Enforced tuning" function for emergency operation with poorly-matched antennas (reduced output)
Rear-panel socket for AH-4 external autotuner
Acoustically-baffled speaker for excellent receive sound
Front-panel SD card slot
Rear-panel USB port for CI-V and audio/baseband/12 kHz DRM IF input/output
RS-BA1 compatibility (the spectrum scope with the waterfall can be observed on the PC screen)
Compact size: 240(W)×238(D)×95(H) mm, 4.1 kg.
FPGA ya dikkat !!!! ilerde çokça dinleyecez ve öğreneceğiz.
(https://3.bp.blogspot.com/-vticJhEd020/V221zDdjnsI/AAAAAAAAonI/zqynYJGbU10UadiejK3A_VNvZ998_eDGACLcB/s1600/RF-diagram-eng-ok.jpg)
Başlık: Ynt: (YENİ) ICOM IC-7300
Gönderen: TA5FA - 25 Haziran 2016, 03:00:52
(https://1.bp.blogspot.com/-UTrZP8a1Idk/V227Zt7o0MI/AAAAAAAAonY/_D3qCLeq2jwA2PibjU9Ci32M-tyvl_mKwCLcB/s640/g-gif-update%2B%25282%2529.gif)
Kullanıcı yorumları : https://yadi.sk/d/JLalxxlysmvPo    Adam Farson VA7OJ/AB4OJ
Şema  : https://yadi.sk/i/zwXMjtzxsmvPq
Giriş Manual : https://yadi.sk/i/1uklh3eVsmvRH
Detaylı Manual : https://yadi.sk/i/-NyzDLL9smvUW
Gönderen: TA8AT - 25 Haziran 2016, 10:24:25
Mehmet bey sdr tabanlı cihaz olması olası arızalarda onarım konusunda sorunlar çıkardığından bahsediyorlar. Bu konuda düşüncelerinizi öğrenebilirmiyim. Özellikle artıları ve eksilerini de dile getirelim derim. Yazılarınızı olağanüstü şartlarda bile ilgiyle takip ediyorum.
Gönderen: TA2IDE - 26 Haziran 2016, 02:49:34
Onur beye katılıyorum. ic7300 yeni çıkan bir ürün ve alan, almak üzere olan ve cihaz araştıran arkadaşlar için herkez kendi fikirinin bulunduğu bir konu olması çok faydalı olacağını düşünüyorum.
yazımı okuyan arkadaşlar için söylüyorum. Aldım kullanmadım - Kullanıyorum - Video veya bir kaynaktan okudum - v.s. bunun gibi yazılarına başlarlar ise çok faydalı olacaktır.
Gönderen: TA2HZ - 26 Haziran 2016, 03:14:11
Yeni radyo amatörü olmuş ve kısa dalga radyoya merakı olan arkadaşlar icin bicilmiş kaptan olabilir aksi halde bir DX cihazı olamaz büyük radyolar gibi bir İCOM meraklısı olarak ben şahsen almayı hic düşünmedim düşünmüyorumda.
Gönderen: TA5FA - 26 Haziran 2016, 04:33:03
Peşin karar vermeyin derim   Neden mi ?
En basit örnek Tüm DX ve Contest kovalayıcılarının cihazlarına bir göz atın  sonuç olarak hangi büyüklükte cihaz'a ulaşacaksınız.
Birkaç yön vereyim ;
--DX takipçilerine yön verecek TÜRKÇE sinide yayınladığımız  http://www.telsizciler.org/index.php/topic,32547.0.html   yazarı olan K7UA'nın masasındaki kullandığı cihaza bakın neyi göreceğiz ? hemde iki tane SO2R çalışıyor
-- Dxpedition aktivitelerini http://www.telsizciler.org/index.php/board,36.0.html adresinden duyuruyoruz oradaki ecnebi top sınıftaki  aktivitelerin fotoğraflarına bakınız hangi cihazları daha çok göreceğiz ?
-- Contest katlımcılarından en yakın Geçtiğimiz yıl Trabzon'a gelen Alman ve İngiliz amatörlerin yanlarında hangi cihazı getirdiklerine göz atın neyi göreceğiz ?
Kolaylık olması için Almanlar >: https://www.youtube.com/watch?v=e2cF91kxr2E   İngiliz >: https://www.youtube.com/watch?v=OhAZXcXk6cw
İşaret ettiğim cihaz sonucuna ulaştıysanız ben size karşılaştırma yapayım ; (Sıraladığım noktalara bakmadıysanız cihaz ismine ulaşılamaz)
ICOM-YAESU-KENWOOD top modelleri : 5000 - 10.000 dolar aralığındadır  (IC7700-7800  YAESU 5000-9000  KENWOOD 990  v.s)
Yukarıda sonuca ulaştığınız herkesin ulaşmak istediği cihaz : 3000 dolar  (ismini siz bulun)
Öte yandan ICOM 7300  tamamiyle  SDR tabanlı tüm filtreleri içeriğinde (yazılımsal) ve yukarıda ismini sizin bulacağınız cihazın da nesil olarak bir adım önünde  fiyatı  1400 dolarak - 1400 Euro aralığında ve tuneride içerisinde.
DX ve Contest kovalayıcıları neyi ister ;
1- İyi bir dinleme
2- İyi bir filtre daraltılıp açılabilir keskinlik
3- Hafif ve taşınabilir
4- Görselliği  2. hatta 3. planda olan
Tüm bunları şimdiye kadar işaret ettiğim cihazda buluyorlardı şimdi tahtını ICOM-7300 zorlayacak gibi belki ilk versiyonlarında yazılımsal hatalar olabilir ancak fiyat oranıyla aynı paraya ondan bir tane  ICOM-7300'den  iki tane almak mümkün.
Seçim yapmak gerekirse ; GÖRSELLİK Mİ ?  Masaların dolu dolu şenlendiği gözlerimizi doyuracak gösteri cihazımı ? (Hiç DX kovalamayacak sak ve contest yapmayacaksak isabetli davranış)
İŞLEVSELLİK Mİ ?   Duyan, duyuran, filteleriyler ön plana çıkan , hafif heryere götürülebilen , içerisinde kurdalanabilecek hiçbir ayar mekanizmasının olmadığı yazılımsal sade bir cihaz .
IC-7300  daha yeni gerçek kullanıcı yorumlarını takip ediyoruz  popüler bir plarformda  107 kişi  5 üzerinde 4,9 puanlama yapmış  mükemmel ötesi (kullanıcı yorumları arttıkça puanlama 4 altına düşerse işte ozaman tehlike çanlarını hep beraber çalarız)
Bulabildiklerimizi paylaşmaya devam edeceğiz.
Gönderen: TA5FA - 26 Haziran 2016, 04:50:32
Onur Bey Olağanüstü şartlar da  Allah yardımcınız olsun gönlümüz sizler le Kolaylıklar dilerim.
Cihaz tamamen yazılımsal olsada elbette Hardware ekipmana sahip  Çıkış ve Tuner kritik noktalar.  Ancak Özellikle Avrupa ve Amerika kullanıcılarını takip ediyoruz bakalım sonuç ne çıkacak.
Sağlıcakla  73
Gönderen: TA8A - 27 Haziran 2016, 13:39:09
Onur amca önce affına sığınıyorum,
Şu güne kadar yeni tip cihazlarda pek bozulma görmedim. Pardon, kendiliğinden bozulma görmedim. Benim gördüklerimde ise amatörün cihazının bozulma sebepleri aşağıdaki gibi.
- Merak ediyorum, kapağını açıyorum, tamam!!! Dur işte! Yoook! devam ediyorum, kurcalıyorum ve bozuyorum. Çünkü dediler ki L103'ü iki tur sağa çevir, 150 watt oluyor!!!
- Antenim dandik, araya koymuşum bir tuner, hem de cihazın yanı başına, illaki dandik antenle cihazı kullanacağım. O sırada RF bir yerlere geziye gidiyor, dönerken cihazıma uğruyor ve cihazı bozuyor.
- Kitabında diyor ki en az 23 amper güç kaynağı kullan. Ama onu bulamıyorum. Elimdeki 15 amper ile deniyorum. Güç kaynağı bayılıyor, bayılırken voltaj kontrolü kalmıyor cihazım bozuluyor.
- Elimde dandik bilgisayar güç kaynağı var. Onu kullanıyorum. Bu güç kaynağı RF üreten yüklerde denenmediği için artık ne oluyorsa bir şeyler oluyor, benim cihazım bozuluyor.
- Kitabında diyor ki ALC ayarı şu şekilde yapılır. Ben ALC ayarını yapıyorum. Ama Wattmetrede YETERLİ WATT GÖREMEDİĞİMDEN mic gaini açıyorum, öyle devam ediyorum. Üstelik arkadaşlarım "ABİ ARTIK GÜMBÜR GÜMBÜR GELİYORSUN" diyorlar. Hem modülasyonum bozuluyor, hem de cihazımı biraz aşırı kullanmış oluyorum. Sonra cihazıma bir şeyler oluyor.
- Cihazım toz almasın diye örtüsü var. (Bazen dantelli oluyor) Çalışırken bu örtüyü açmam uzun oluyor. Çünkü üzerinde SWR var, wattmetre var falan. Böyle çalışıyorum. Sonra cihaz isyan ediyor, beni bırakıp gidiyor.
- İstasyonum güzel görünsün diye afilli bir masa yaptırmışım. Cihazların her birinin ayrı ayrı gözü var. Ama havalandırma diye bir şeyi unutmuşum. Başlıyorum çalışmaya, cihazlar dayanıyor bir yere kadar. Sonra mevta!!
Sonra bir köşeye geçip "Artık cihazları çok nazik yapıyorlar" diyorum. Bende hiç suç yok!!! Onur amca, yine affına sığınıyorum.
Emrah beye katılıyorum. Yeni cihazlarda bazı sıkıntılar olabiliyor. Firmalar bunu düzeltiyor ama biraz zaman alıyor. O sebeple heyecanımızı bastırıp, yazılanları takip edip, yeni cihazları biraz geç satın almakta fayda var diye düşünüyorum.
Sağlıcakla kalınız, 73
Gönderen: TA4AWS - 27 Haziran 2016, 16:59:17
Biz para biriktirip yetirip alasıya zaten 5-10 sene geçer. O zamana kadar da cihaz bütün göreceği güncellemeleri görür. Sıkıntı kalmaz. :)
Bundan sonra cihazlar artık SDR tabanlı olacak galiba. Amatör telsizcilikte yeniyim. Öğrendiğim kadarıyla ilgi gören kullanımı kolay daha ulaşılabilir cihazlar SDR cihazlar gibi geldi bana.
Gönderen: TA4SO - 27 Haziran 2016, 17:38:52
Benim gibi düşük güçler veya s/n oranının düşük olduğu modlarda çalışıyorsanız sdr kullanan istasyonların avantajını görüyorsunuz. Bu sene ilk defa orjinalinde marin cihaz da olsa Icom deneyimim oldu ve bazı konularda takdir ettim. SDR konusunda da başarılı olacaklarını umuyorum. Ben SDR konusuna biraz daha geliştirme kartı benzeri yapılarla başlamayı düşünüyorum. Mehmet hocam çok önemli bir konuya parmak basıyor; FPGA. Sizle popüler bir FPGA bordu paylaşmak istiyorum http://redpitaya.com/ (http://redpitaya.com/). Çevre birim veya ek kartlarla ister sdr yapın ister RLC metre ister empedans analizörü. Yakında uzaktan baktığımız bir çok laboratuvar cihazı evlerimizde yer alabilir üstelik tek bir kart üzerinde. Bir daha ki sefere ömür yeter ve Allah imkan verirse alacağım sdr olmayan cihaz ise bir Elecraft olur sanırım çünkü karşıdakini duyabilmek her şeymiş bunu öğrendim :)
Diğer yandan cihazlarda yaşanan sorunlar konusunda Bilal amca da benim düşündüklerimi yazmış. Sadece telsiz değil işim gereği bir çok cihazla yıllardır haşır neşir olan biri olarak bir cihazın özellikle profesyonel olarak üretilmiş ve satışı yapılan bir cihazın yaşadığı sorunların %99'u beslemeden tutun da havalandırmaya kadar kullanıcı hatasından kaynaklı oluyor. Zaten bir çok testten geçen ve uluslararası yeterlilikleri sağlaması gereken bir cihazda fabrikasyon bir hata varsa ilk kullanım zamanlarında hemen fark ediyorsunuz. SDR cihazların genelinde statik elektrikle ilgili sorunlardan bahsediliyor ama yıldırım başta olmak üzere tüm cihazlarımızı statik elektrik boşalmalarından korumak da dikkat etmememiz gereken konulardan yeni sistemler bu konularda daha hassas.
Onur bey ben de görevinizde kolaylıklar diliyorum, 73...
Gönderen: TA8A - 27 Haziran 2016, 18:17:11
Şadan Hocam,
http://www.ebay.com/itm/AX309-Xilinx-FPGA-development-Spartan6-XC6SLX9-Spartan-6-Xilinx-FPGA-/311432139307 adresindeki kart ve A/D D/A kartı 2 ay önce geldi. Masamda duruyor. Hala okumaya devam ediyorum. Bir gün bir şeyler yazıp yükleyip bir ledi yakıp söndüreceğimi düşünüyorum. Ya da VGA ekrana "Merhaba Dünya"
Gelecek SDR gibi görüyoruz. Aslında gelecek çoktan geldi. Biz kendi telsiz cihazlarımızı görüyoruz. Fakat SDR başka alanlarda çok daha hızlı ilerliyor.
Not: Bana bir kargo adresi verirseniz size bir SDR kit paket göndereyim.
Gönderen: TA4SO - 27 Haziran 2016, 18:35:10
Bilal Amca ne güzel fpga'ya el atmışsınız. Benim ofiste de pic denetleyicilerden tutunda 32 bitlik pic geliştirme kartlarına, TI'nin msp30 larından  Launchpad'lerine, ST'nin Discovery ARM boardlarına, beagle bone'dan rasperry pi ye kadar geniş bir yelpaze var ama daha fpga'ya el atamadım :)  Bazılarında sadece led yakıp söndürürken bazılarına epey ileri ADC ve PWM v.s. gitmişim. Dünyaya baktığımızda DSP, görüntü işleme v.s. öğrenilecek çok şey var fakat zaman az. Merhaba dünyaya alternatif olarak geçenlerde genç bir arkadaş paylaştığı uygulama notunda ekrana "Zalım Dunya" yazmış çok hoşuma gitti :)
SDR konusunda meraklandım, bilgi almak için size özel mesaj atıyorum, saygılar, selamlar, 73...
Gönderen: TA2L - 02 Temmuz 2016, 01:21:53
İnş bir aksilik olmazsa Temmuz ayında elimde olacak. Amerikan versiyonu 1499 dolar olarak cihaz alındı. Lakin bizim tatilciler temmuzda gelecekler... O zamana kadar beklemekten başka şansım yok.
Gönderen: TA3E - 02 Temmuz 2016, 13:18:48
Merhaba.
Bilal amca ve diğer tüm arkadaşların yazılarına katılıyorum.
Bu sene katıldığımız ham radio 2016 fuarında en çok ilgi gören cihaz icom 7300 du.
hem bu cihazı hemde diğer modelleri yakından inceleme fırsatım oldu.
gerçekten çok güzel bir cihaz fuarın en çok satılan cihazıydı
bu kadar ilgi gören bir cihazın çok satılması tesadüf olamaz.
bizde fuara gitmeden önce cihazı araştırmıştık
bu ilgi diğer marka hf cihazların fiyatına indirim olarak yansımıştı.
TA dan yaklaşık 10 arkadaşım bu cihazdan aldı ortalama 1350 ile 1380 euro fiyat vardı
birde cihazı getiren arkadaşlar dönüşte %19 vergi iadesi aldılar ki fiyat tadından yenmez oldu.
Ali-TA3EL
Gönderen: TA3E - 02 Temmuz 2016, 13:29:19
icom 7300
Gönderen: TA3EP - 02 Temmuz 2016, 15:02:02
Onur bey görevinizde başarılar ve kolaylıklar diliyorum. Görüşünüze katılmakla beraber teknolojinin artık yıl bazında değil, ay hatta gün bazında çok hızla geliştiğini vurgulamak istiyorum. "Kaydırmalı ekranlı" dokunmatik cep telefonlarına kuşku ile bakan bendeniz bile, geçen yıldan beri dokunmatik ekranlı cep tel kullanıyorum ve çok memnunum. Bu telefonların tek işlemcili ilk modelleri gerçekten çok kötüydü, ekran kilitlenir açılmaz, dokunmatik çalışmaz vb idi. Ancak yeni 4 hatta 8 çekirdek işlemciye sahip modelleri gerçekten birer şaheser gibiler. Ekran takılmıyor, uygulamalar şakır şakır açılıyor ve çalışıyor, mükemmel fotoğraf ve video çekiliyor, güçlü bir bilgisayar gibi her işlemi yapıyorlar. Dahası ayda 15-20 TL ücretle sınırsız internet, bilmem kaç bin dakika bedava konuşma imkanı veren telefon hat fiyatları da mevcut olunca, bu telefonları hala daha kullanmamakta ısrar edenler çok şey kaçırıyor olacaklar.
Bu SDR cihazlarda da aynı durum söz konusu. Bilgisayar alanındaki gelişmeler bu tip cihazların da gittikçe daha güzel ve kusursuz hale gelmesine yaradı. Artık ekranlar takılmıyor, ana işlemciler ve yan destek birimleri kusursuz olarak problemsiz bir şekilde işliyor, HF enerjiden etkilenmiyor ve bozulmuyorlar. Bilal beyin dediği gibi biz israrcı olursak bozulabilirler, ama ehil ellerde artık pek bir şey olmuyor. Yine de bozulurlarsa, eh, cep tel veya ince ekran LED TV lerimiz bozulunca ne yapılıyorsa o yapılacak, usta bir tamirci bulunup yaptırılmaya çalışılacak, bulunamazsa cihaz HEK e ayrılıp yenisi alınacak...
Icom 7300 ü ben de yakın takibe aldım, bir çok internet paylaşım gurubunda takip ediyorum. Yazılımla ilgili bir kaç minik sorun rapor edildi, onlar da kısa sürede çözümlendi. Donanımsal büyük bir problem hiç izlenmedi. Ayrıca yahoo ve Google gruplarında "ben bu cihazdan memnun değilim, satıyorum" diyeni de hiç görmedim daha. Uygun bir fırsat bulunca bu cihazı envanterime katmak istiyorum.
73, Mete, TA3EP
Gönderen: TA6P - 03 Temmuz 2016, 00:41:31
Değerli amatör arkadaşlar,herkese merhaba
        Icom ic-7300 ü 27.05.2016 tarihinde almanyadam aldım.Haziran ayının ilk günlerinden bu yana da kullanmaktayım.Benim satın aldığım sıralarda almanyada çeşitli firmalar satın almak isteyenleri sıraya yazıyordu zira ellerinde cihaz yoktu.
     Cihaz  kurulduktan sonra menülerinin basitliği ve kolay ulaşımı ile dikkat çekiyor.Ben deki cihazın yazılım versiyonu 1.3.spectrum ekranı  ic-7600 ün ki ile aynı.Ekran boyutlarının küçük olması nedeni ile sanki çözünürlük daha iyiymiş etkisi yaratmakta.Açılışta tıpkı ic-7600 gibi hızlı.Tabii bu konuda ic-756 pro 3 ten benim gibi illallah diyenler için.Aynı antende  zayıf istasyonlarda seçiciliği nasıl diye merak edip ic-756 proIII, ic-7600 ile birlikte denemeler yaptım onlardan geri kalmadığını gördüm.Tuner oldukça hızlı ve cihazda ısınma tesbit etmedim.Uzun saatler boyu cihaz açık kaldı ,ara sırada görüşme yaptığım halde herhangi bir anormallik görmedim.Arkasında büyükçe boyutlarda olan fan ve el maykı  made in chine.Bu beni şaşırttı. Ancak yurt içi ve yurt dışı yaptığım görüşmelerde modülasyon konusunda oldukça olumlu raporlar aldım.Dokunmatik ekranı benim gibi klasik cihazları kullanan birini zorlasada menülere geçişte büyük kolaylık.  Bir an için insan kendini akıllı telefon kullanır gibi hissettiriyor.
                        Bu cihazı almadan önce bende herkes gibi araştırmaya çalıştım.Birçok  cihaz ile karşılaştırılmış videolara göz attım.Örneğin CW de tartışmasız önde olduğu kabul gören  electraf K3 ile bile kıyaslanmıştı. https://www.youtube.com/watch?v=85wvhriXPmM .Ben bu konuda K3 de bariz bir üstünlük göremedim.Benzer bir dolu video seyrettikten sonra almaya karar verdim.Boyutları diğer cihazlara göre daha ufaktı.Ama olsun marifet işlevi idi.Bu bana portable çalışmalarda kolaylık sağlardı.Benzer birkaç düşünce sonrası kararım kesinleşti.Cihaz Almanyadan 1359 euroya  alındı.Ancak türkiyede kullanacağım için vergi iadesi şansım olduğunu bilmediğimden 220 euro civarı param vergi olarak gitti.Bunu bilse idim 1100 euro civarı bana malolacaktı.
                   Özetle ben Icom markalı cihazlara biraz sempati ile bakan biri olarak bu cihazdan memnunum.İlerde yazılımdan doğan hatalar olduğunda veya eksiklik görüldüğünde zaten yazılım yenileniyor.Çok büyük laflar ederek şöyle cihaz böyle cihaz demek istemiyorum.Ancak oldukça güzel bir cihaz olduğunu düşünüyorum.İlerde tesbit ettiğim farklılıklar olursa sizlerle paylaşmayı düşünüyorum.Çünkü testlere devam etmekteyim.Herkese selam ve saygılar.
     TA6P
Ali  Zümrüt
SAMSUN
Gönderen: TA4CS - 24 Temmuz 2016, 17:38:23
  Cihaz için hafıza kartı alacak arkadaşların dikkat etmesini rica ederim.
Marka olarak tavsiye edilen SanDisk  başka markada oluyor ben kullanıyorum SD 2 GB veya SDHC 4 & 8 & 16 & 32 GB Destekliyor
Not: Yanlış kullanımlardan oluşabilecek hatalardan sorumlu değilim saygılarımla AYDIN'dan 73.
Gönderen: TA8AT - 24 Temmuz 2016, 20:55:04
Coskun bey öncelikle yeni cihazınız hayırlı olsun.
Hafıza kartını ses kayıt işlemi içinmi kullanıyorsunuz
Gönderen: TA4CS - 24 Temmuz 2016, 22:13:38
   Onur bey teşekkür ederim Allah size de nasip etsin inşallah özellikle contest de qso için kullanmaya düşünüyorum devamlı CQ CONTEST çağrısı ses kayıtda yapabilirim cihaz bir kaç gün oldu tanımaya çalışıyorum AYDIN'dan 73.
Gönderen: TA2IDE - 25 Temmuz 2016, 12:41:55
coşkun abi hayırlı olsun.
Gönderen: TA4CS - 25 Temmuz 2016, 17:25:01
Teşekkürler EMRAH  bey darısı sizlerinde inşallah Aydın'dan 73.
Gönderen: TA4CS - 25 Temmuz 2016, 17:48:29
  Cihazı antenna analyser gibi kullanma imkanı var arkadaşlar.Video yükleme yapamadığım için :-) Mehmet beye yollayacağım gereğini yapar Aydın'dan 73.
Gönderen: TA5FA - 25 Temmuz 2016, 21:14:26
SWR Analiz Video
https://vimeo.com/176197608
Gönderen: TA1LC - 26 Temmuz 2016, 17:27:05
icom mühendisleri boşta durmuyor hep yenilikler karşımıza getiriyor.
lakin yakın geçmişteki cihazlarda bazı teknik kusurlar sahiplerini üzmüştü. örnegin statik elektrik zafiyeti v.s nette şikayetler mevcut. bu bir şirket politikasımıdır acaba ?- eski cihazı geliştirmeden hemen yeniliklerle karşımıza çıkıverip ayıplarını bir nevi perdelemek.
 ben icom kullandım fakat şimdiki aklım olsaidi kenwood derdim. kenwood firmasında proje kısmında çalışanlar neyin ne oldugunu ve nasıl yapıldıgını sanki daha iyi biliyorlar. 100% degil ama adı üstünde- amatör cihazı.Şimdi elektonikten anlayan, merak edene açıklayayım bir örnek.bildigimiz gibi 13.8 v kablo üzerinde iki adet 20 amper sigorta var ve bunlar eger cihaz 20 amperden fazla talep eder ise yanmak ile görevli.peki 20 degil de 8 amper talep eder ise ?(olur ya arıza yaptı sürücü katı yandı ve sürücü katın devresinde sigorta -yok !)ve 20 A sigortalar yanmadı ve sizde etrafta degilsiniz - ne olur?- cihaz 13,8Vx8A=110.4 W ısı üretir ve 1saate  icom degil ütü olur ve erir.işte sadece bir mühendislik hatası örnegi. kimbilir daha bunun gibi kaçı vardır.lafı uzatmayacagım.saygılar.
Gönderen: TA3ON - 27 Temmuz 2016, 23:32:45
Sayın Arkadaşlar,
QST dergisinin Ağustos sayısında ICOM - 7300 değerlendirildi. ARRL'in QST dergisi üzerinden yaptığı değerlendirmelerin gerçekten objektif olduğu bilinir ve bu değerlendirmeler önemli bir referanstır. İlgili arkadaşların bakmasını öneririm. Tartışma kısmında (Conclusion), SDR teknolojisini desteklemesine ve ergonomik dizaynına atıfta bulunularak orta derecedeki fiyatı ile tüm gereksinimleri karşıladığından bahsediliyor. Bu tarzın, yaklaşımın, bundan sonra yapılacak diğer alt modeller de dahil,  ICOM'da bir öncü olacağından bahsediliyor. Makaleyi yayın hakları nedeniyle yayımlayamıyorum. Ancak ilgilenen arkadaşlar internette araştırırlarsa bir kısmını veya tamamını bulabilirler. Son olarak şunu eklemek isterim: QST dergisinin 2006 yılından beri yaptığı HF makine değerlendirmelerini 2 kHz 3rd- order dynamic range değerine göre sıralarsak 47 makine içerisinde 23. sırada yer almaktadır.  http://www.remeeus.eu/hamradio/pa1hr/productreview.pdf  Selamlar, 73.
Gönderen: TA2NC - 28 Temmuz 2016, 11:07:25
Cihaz gercekten cok ilgi cekici..
Ev ve mobil kullanimda cok buyuk artilarinin olacagi bir gercek.
Hatta evdeki 480-HX i satip bir tane bundan almayi bile dusunmekteyim ciddi ciddi.
Gorebildigim eksigi, sadece tek anten girisine sahip olmasi..
Alis hassasiyeti cok cok iyi olmasina karsin, ozellikle contest gibi ortamlarda bir receive-only anten girisinin olmamasi sıkıntı olacak gibi, sirf bu ozelligi icin 590SG bir adim one geciyor sanki SDR olmamasina ragmen.
 tabii ki bunun icin roleli devreler mevcut. Manual bir sekilde cihaza bu ozellik kazandirilabilir ama o da olsaydi samda kayisi olurdu...
Gönderen: TA3EP - 28 Temmuz 2016, 18:34:56
Oğuzhan bey o özellik bir sonraki modelde kesin olacaktır eminim.
Coşkun bey cihazınız hayırlı olsun, iyi günlerde kullanın.
Bu cihazdan bir kaç arkadaş daha aldı sanıyorum, onların da güle güle kullanmalarını dilerim. Ben de almayı planlıyorum, elden çıkarmayı düşünen varsa haber versin :)
73 de Mete TA3EP
Gönderen: TA4CS - 28 Temmuz 2016, 20:30:15
Teşekkür ederim Ahmet Mete bey darısı sizlerin inşallah Aydın'dan 73.
Gönderen: TA5FA - 28 Temmuz 2016, 21:42:45
Daha alamasakta haydi hep beraber almış gibi kutusunu açalım : )  20. dakikaya gidiniz...
https://www.youtube.com/watch?v=3NtaHC5G2GY
Gönderen: TA2L - 28 Temmuz 2016, 23:00:43
Cihazimiz geldi. Gelir gelmez ayagimin tozuyla marmaris e geldim. Ilk olarak 10 m sag 10 m sol a 1/1 balunla cihazimi aktif ettim. Menuleri guzel kullanimi kolay geldi. Yaklasik 10-15 gorusmeler yaptim. Gayet guzel simdilik. Izin donusu daha detayli bilgi verebilirim.
Gönderen: TA2L - 28 Temmuz 2016, 23:03:57
Nihayet cihazim geldi. Tatilde oldugumdan dolayi yorum yapamiyorum. Izin donusu detayli bilgileri paylasiriz.
Gönderen: TA2FE - 29 Temmuz 2016, 12:37:41
Mehmet Ağabey,
Beni sürüklediğiniz için teşekkür ederim . Dün akşam itibari ile TELSAN firmasına 1 adet ICOM 7300 sipariş geçtim . Orhan bey onayını verdi. Malzemeyi beklemek kaldı. :) :) :)
Aslında zor olanı da o  ama ne yapalım sabır iyidir. Malzeme gelene kadar artık yazıları okuyup yorumları takip edeceğim .
Yazıyı ilk çıkardığın günden itibaren olduğu gibi.
Tüm arkadaşlara iyi günlerde kullanmaları dileği ile :9
Saygı ve sevgilerimle
Gönderen: TA2IDE - 29 Temmuz 2016, 12:40:43
abi ne kadar fiyat
taksit olabiliyor mu?
Gönderen: TA8A - 29 Temmuz 2016, 12:45:49
Mehmet Abi,
Ben de TELSAN firmasına sipariş verdim. Emin amcam ile beklemedeyiz. 73
Gönderen: TA8A - 29 Temmuz 2016, 12:48:25
Emrah Bey,
TELSAN'ın taksit yapmadığını biliyorum. Fakat TELSAN'ın ithal ettiği ürünlerin www.mobilcom.com.tr adresinde zaman zaman taksitle satıldığını görüyorum. Fiyatını ise belirlenince söyleyecekler. İyi çalışmalar dilerim. 73
Gönderen: TA2IDE - 29 Temmuz 2016, 12:51:09
anlaşılmıştır. Fiyat konusunda bilgi edinilmesi halinde ben ve diğer arkadaşlar içinde faydalı olacağını düşünmekteyim.
Gönderen: TA8A - 29 Temmuz 2016, 13:11:29
Yüksel Bey (TA1EH),
Yukarıdaki yazınızda bahsettiğiniz mühendislik hatasının çözümünü merak etmekteyim. 73
Gönderen: TA1LC - 01 Ağustos 2016, 17:27:46
Sayın TA8A uzun araştırmalar sonucunda orjinal 2SC1972 transistötlerini kullanmamaya karar verdim. Piyasada sahtesi fazladan ve üretümi olmayan bir ürün. Matchet pair tutturmak ise zor. Şimdi acaba fabrikası matcet pair mi takıyor diye şüpe ediyorum yoksa niye sıkıntı olsun sebepsiz? İCOM746.
Yapılan işlerin basitçe açıklaması resimlerde görülüyor. Önakım ayar öncesi power dügmesi tamamen kapatılıyor. TX 8Volt tek tek veriliyor. Ampermetre ile işimiz bittigi zaman yerine 6.3 A sigorta lehimliyoruz. Alıntı FT847  PA devresinden.
Gönderen: TA8A - 01 Ağustos 2016, 17:34:15
Yüksel Bey,
Benim sorduğum bu değil. Siz yukarıdaki mesajınızda şöyle demiştiniz.
"örnek.bildigimiz gibi 13.8 v kablo üzerinde iki adet 20 amper sigorta var ve bunlar eger cihaz 20 amperden fazla talep eder ise yanmak ile görevli.peki 20 degil de 8 amper talep eder ise ?(olur ya arıza yaptı sürücü katı yandı ve sürücü katın devresinde sigorta -yok !)ve 20 A sigortalar yanmadı ve sizde etrafta degilsiniz - ne olur?- cihaz 13,8Vx8A=110.4 W ısı üretir ve 1saate  icom degil ütü olur ve erir.işte sadece bir mühendislik hatası örnegi."
Bu mühendislik hatasının nasıl çözüldüğünü merak etmiştim. 73
Gönderen: TA1LC - 01 Ağustos 2016, 18:22:47
Bilal bey iki resimde aynı devre (PA) biri İcom biri Kenwood. İcomda  LR-143 Trafo üzerindeki iki ferit nüveyi ayırıp sigorta takmak gerekiyor tedbirli olmak için. Diger resimde Kenwood mühendisleri zaten takmış- turuncu renkteki sigorta -5A.....
  Özellikle kabloda hata aramamız gerekiyor ise -sigorta yuvaları presli olmaları zaman içinde drenç oluşturuyor.
Mutlaka açıp lehimllemek gerekiyor kabloları ve maşaları.
Artı bu sigortalar çok önemli eger artı eksi yanlış verilir işe çihazın içindeki diod sayesinde akımı keserler.İptal etmeye gelmez.
Gönderen: TA2AEY - 15 Ağustos 2016, 12:14:04
Herkese Merhaba,
Cihazı 2016 Dayton Hamvention TA2ID ile fuardan aldık.Şuan kullandığım cihazlarla karşılaştırdığımda özellikle dinleme ve çıkış konularında problemsiz (IC-7600 ü zorluyor hatta kimi zaman daha iyi- IC-7700 yetişemese de pek geride kalmıyor) ...Beraberinde gelen mikrofon oldukça tatminkar.Ayrıca yeni nesil arayüzü ile kullanım kullanımı çok kolay.Dokunmatik ekran ulaşılabilirliği kolaylaştırıp,hızlandıyor.
Tuner yeterli hızda ayarlamarı yapıyor ve analyzer özelliği fikir vermesi açısından güzel.Isınma sorunu yaşamadım zaten göstergeden takip edebildiğiniz gibi uyarı mekanizması da mevcut.
Cihazı düşünenler var ise yeni teknolojisiyle fiyatının hakkının üstüne bir performansı mevcut.73's
Gönderen: TA4CS - 15 Ağustos 2016, 16:32:06
  WAE CW CONTEST de CW de 100 WATTS da yaklaşık hiç ara vermeden 7 saat kullandım devamlı CQ ve QSO da ısınma konusunda hiç bir sıkıntı görmedim banamısın demedi ekrandan takipde 1 çubuk artdı o da hiç bir şey değil bu cihazla 24 saat yarışabilirim diye hiç şüphem yok Allah olmayana nasip etsin 73.
Gönderen: TA1LC - 16 Ağustos 2016, 17:22:33
https://youtu.be/CuLsOTOCEiM?t=263 (https://youtu.be/CuLsOTOCEiM?t=263)   Allah sahibine bağışlasın.
Gönderen: TA5FA - 23 Ağustos 2016, 01:08:08
7300 <> N1MM setup   http://www.k0pir.us/icom-7300-n1mm-logger-plus-setup/
Gönderen: TA5FA - 06 Ekim 2016, 23:59:11
https://www.youtube.com/watch?v=IOJNDODBmbY  7300 ve K3  CW modunda  dinleme karşılaştırması
Gönderen: TA5FA - 07 Ekim 2016, 00:03:02
https://www.youtube.com/watch?v=kobPg3GKA0I   İcom 7300 ve Flex 6300 karşılaştırması
Gönderen: TA5FA - 07 Ekim 2016, 00:08:17
https://www.youtube.com/watch?v=s_muf9QF4-I   İcom 7300 ve IC 756 pro III karşılaştırması
Gönderen: TA5FA - 07 Ekim 2016, 00:12:27
https://www.youtube.com/watch?v=681uaZYJXJQ    İcom 7300 ve TS 990 karşılaştırması
Gönderen: TA5FA - 07 Ekim 2016, 00:15:42
https://www.youtube.com/watch?v=d1o-xfSaVPQ    İcom 7300 ve IC 7600 karşılaştırması
Gönderen: TA5FA - 21 Ekim 2016, 18:37:25
Set hoparlörü piyasada  SP-38
Gönderen: TA5FA - 07 Kasım 2016, 19:15:49
Tüm sonuçlar kullanıcısına aittir. Full TX
https://www.youtube.com/watch?v=AGhPLpifAoU
Gönderen: TA5FA - 03 Nisan 2017, 20:18:26
RX anten girişi eklemek
bazı üst model cihazlarda ilaveten RX anten girişi vardır. Ancak malesef 7300'de koymayı unutmuşlar her nekadar tühh deselerde olmuş bitmiş.
Firmanın birisi bunu fırsat bilip RX girişi eklemek için soket yapısı piyasaya sürmüş .
İyi seyirler https://www.youtube.com/watch?v=HBajms1EnuA
Yanlız bunu yaparken External Tuner soketinden feragat etmeniz gerekiyor.
(https://2.bp.blogspot.com/-PWudqZDKx-k/WOJ19dyfJvI/AAAAAAAApgc/_f6ZwdpykRkIzeklblwgTgraanq_JMwDgCLcB/s1600/2017-04-03_19-13-10.bmp)
Gönderen: TA5FA - 22 Haziran 2017, 00:55:06
IC-7300 service manual https://yadi.sk/i/JYw8Ikbg3KLjYH
(https://4.bp.blogspot.com/-R5WTN6e5gLE/WUrdRuMCNMI/AAAAAAAAqlc/jTRuEKT8kpwtQqLcGscTROpzwmmHa_SIgCLcBGAs/s1600/2017-06-21_23-55-15.jpg)
Gönderen: TA2DJ - 29 Aralık 2017, 22:39:56
Herkese merhaba,
TRAC Kadıköy Şubesi üyeleri imece usulü bir çalışma ile bu telsiz cihazını aldılar. Şu ana kadar herhangi bir sorunu yok, genel
kullanıma açık olduğu için telsizin imkan ve kabiliyetlerini de test etmiş oluyoruz.
Erhan TA2DJ
73's..
Gönderen: TA2LG - 31 Aralık 2017, 00:49:56
Erhan bey.
güle güle kullanin..  cihazın 1.20 firmware yazılımı çıktı güncelleminizi öneririm..
güzel bir cihazdır..
TA5FA mehmet abi tesekkürler.. 73
Gönderen: TA2DJ - 31 Aralık 2017, 23:15:13
Halil bey,
İkazınız için teşekkür ederim, Şube yönetimine iletiyorum..
Erhan TA2DJ
Gönderen: TA5FA - 10 Mayıs 2021, 00:19:47
IC-7300  Pile-Up  dan sıyrılmak için denenebilir diyor video yayıncısı;
https://www.youtube.com/watch?v=cXrh7DDkQSY
