Ana Sayfa => Ben yaptım oldu! *** => Konuyu başlatan: TB5X_SK - 11 Haziran 2014, 18:17:21
Yarım kalan forty 2 nin PLL kartını iptal edip DDS li hale getirdim..
Kutulamayıda tamamlayarak bitirdim..
Videolarını da eklemeye çalışacağım..
(https://lh4.googleusercontent.com/-lezAN9O3jyc/U5hgFfkyYYI/AAAAAAAAFE0/XeCnnIElmGk/w1278-h852-no/DSC_0010.JPG)
(https://lh4.googleusercontent.com/-4xQ8fbkama0/U5hgLi9bDiI/AAAAAAAAFFI/-W3rc6uoHKY/w1278-h852-no/DSC_0011.JPG)
(https://lh5.googleusercontent.com/-MtcYQtXvJ_k/U5hgPWH5X0I/AAAAAAAAFFU/YhfH6y2zGC8/w1278-h852-no/DSC_0012.JPG)
(https://lh6.googleusercontent.com/-_fHNMKCfJAk/U5hgXBu_TBI/AAAAAAAAFFc/M5_MTiB8npQ/w1278-h852-no/DSC_0013.JPG)
(https://lh5.googleusercontent.com/-lHBJEb-EGXY/U5hgaPJmJbI/AAAAAAAAFFk/tUhBxLMDOIQ/w1278-h852-no/DSC_0014.JPG)
(https://lh5.googleusercontent.com/-Q2LBciK632c/U5hgjbKDR3I/AAAAAAAAFF0/XjhZKCeYDzw/w1278-h852-no/DSC_0015.JPG)
(https://lh4.googleusercontent.com/-HQujyOMEGTQ/U5hgtCeNLWI/AAAAAAAAFGI/k8yzcP8Fx0g/w1278-h852-no/DSC_0017.JPG)
(https://lh6.googleusercontent.com/-cs-E4kLWet8/U5hguJY5R0I/AAAAAAAAFGU/G5bCsKCpyQ4/w1278-h852-no/DSC_0018.JPG)
(https://lh6.googleusercontent.com/-02C3UDPuf9M/U5hgt3oAYnI/AAAAAAAAFGQ/If33OYznc3c/w1278-h852-no/DSC_0019.JPG)
(https://lh6.googleusercontent.com/-abxo50kWNCM/U5hg2S4eSiI/AAAAAAAAFGc/3AIJgDcCqcs/w1278-h852-no/DSC_0020.JPG)
(https://lh5.googleusercontent.com/-QurbWn9aWVo/U5hg8BXiRwI/AAAAAAAAFGo/38pzf6zEsfw/w1278-h852-no/DSC_0021.JPG)
(https://lh4.googleusercontent.com/-vxRHeCmFwYA/U5hhpGmxnXI/AAAAAAAAFG8/R_4gVyTsvn0/w1278-h852-no/DSC_0026.JPG)
(https://lh5.googleusercontent.com/-ViFLW_SoMCc/U5hhw2pn46I/AAAAAAAAFHE/Wz6FWyrlDhY/w1278-h852-no/DSC_0027.JPG)
(https://lh5.googleusercontent.com/-YDZa-KLk4I0/U5hiXRYFilI/AAAAAAAAFHU/dQ5BvFVeW54/w1278-h852-no/DSC_0029.JPG)
(https://lh6.googleusercontent.com/-2qwjYBce73g/U5hjns7xpmI/AAAAAAAAFIU/yzTyNvVikMg/w1278-h852-no/DSC_0040.JPG)
Mehmet bey forty-2 de dds'in çıkışını bağlarken ne gibi bağlantı ve modifiye yaptınız? ayrıca dds ile pll arasında aynı almaç kartında gözlemlediğiniz belirgin bir fark varmı? iyi çalışmalar..
mehmet bey merhaba
Qrp'nizde hangi dds devresini kullandınız,
Onur Bey;
DDS çıkışlarını Forty2 nin PLL girişine modifiyesiz direkt bağladım.
Bu haliyle 4 Watt çıkış veriyor.
Alpaslan Bey kullandığım DDS devresi AD9850 li devre.. Ayrıntılarına buradan ulaşabilirsiniz: http://www.telsizciler.org/index.php/topic,30824.0.html
Bu QRP nin çıkışına 2SC2078 taktım..
2sc1971 ve 2sc1972 ye göre daha kolay bulunuyor ve fiyatı da 2.5 lira gibi ucuz..
Aynı watı onunlada alıyorum..
Yalnız dikkat edilmesi gereken bacakları 1971 ve 1972 ye göre farklı takarken ona dikkat edilmeli..
QRP ler için 1972 1971 aramanıza gerek yok bilgi olsun diye ekleyeyim dedim..
Mehmet bey, bir süre once bende 2sc2078'i denedim ancak çıkış çok zayıf oldu yani 100mw gibi bir cıkıs aldim. Acaba transistorler sahtemi diyorum. Siz nereden almıştınız?
Hocam ben bluemaviden almıştım . Hem 14 Mhz Taurus 20m QRP de hemde forty de kullandım ikisinde de rahat 5 watt veriyor..
Mehmet bey devrede hiçbir değişiklik yapmadanmı 5 watt veriyor?
Evet onur hocam aynen.. sadece bacak bağlantıları farklı.. bağlarken buna dikkat ediniz..
datasheet lerini incelerseniz 2078 in çalışma frekansı 27 mhz oysa 1971 ve 1972 175 mhz..
veya 2098 de olur hocam çalışma frekansı 28 mhz ve 13 watt çıkışı var datasheedinde belirtilen...
küçük bir bilgi
(https://lh3.googleusercontent.com/-wKxdfQgu1AU/VFJsub8e6RI/AAAAAAAAFxc/O1bgO7R9HXE/w1277-h889-no/DSC_0179.JPG)
Mehmet hocam, ellerine sağlık çok güzel olmuş. Peki şöyle bir sorum olacak ?
2SC1971 malum 175Mhz de çalışıyo ve cihaz çıkışı ona göre ayarlanıyor. Toroid sarımı vs.
Diğer söylediğiniz transistör için ayara gerek varmı ? Yoksa direk takıp kullanalımmı ?
Kış geldi Mehmet hocam içimizdeki sönmeyen qrp ateşine bir odun attı ateş yine alevlendi malzemeleri ortalığa cıkarmanın zamanı gelmiş .
Mehmet hocam elinize sağlık cok guzel işler ve bilgiler ortaya dökmüşsünüz teşekkürler .73
ALİ RIZA HOCAM
Bu transistörün 1971 ve 1972 nin yani gerçek çalışma frekansı 175 mhz..
Bu transistörler 7 mhz dede çalışır ama gerçek performansını ancak 175 mhz de verir.
175 mhz de 15 watt alırsın 7 mhz de 4 5 wat ancak alırsın..
Arkadaşlar.2098 den ben randıman alamadım.ama 2078 gayet güzel.Benim çalışmam 27 mhz de.Bilginize.
Mehmet hocam, sizi yine rahatsız edeceğim. Bu 2078 transistörden 1,5 yıl önce ve 10 ay önce iki ayrı dönemde bende bluemavi'den almıştım. Doğru bağladığım halde sonuç alamamıştım. Belki o seri uygunsuzdu, birde şimdi alıp deneyeceğim. Bakalım ne olacak. Çalışmalarınız takdire şayan. Hoşcakalın. 73
Mehmet hocam bir şeyi daha sormak ve paylaşmak isterim. Forty2 transceiveri hem 20m ve hemde 80m icin modifiye ettim. 20m transceiverden su anda 5W temiz cıkış alıyorum. PA ile 10W çıkışım var. Pek çok qso yaptım. Sorum şu: ssm2165 benim transceiverlerde mandala basinca dinamik mikrofonda 2sn de yavaş yavaş devreye giriyor. Buna condansator mic. taktim aninda devreye giriyor. Sendede böylemi? Böyle ise bir çözümün varmı? 73
Hulusi hocam bu entegre kompresörlü olduğundan yükses sesi bastırıyor..
resimdeki gibi 6 nolu bacaktan kompressörü ayarlayabiliyoruz..
Ben condansatör mic ile denemedim..
İlk mandala basınca alma hassasiyeti önce bastırılmış olarak başlayıp sonra giderek hassaslaşıyor.. Sizin sesi 2 sn sonra almanızın sebebi bu bence.. Ortam sessiz ise hassasiyet eşiği ona göre yükseliyor..
yüksek bir ses girerse mic ten, hassasiyet düşerek bastırma başlıyor.. tekrar sessizlik olunca hassasiyet otomatik artıyor..
Sizdeki olan olay bu sanırım..
Mehmet hocam mantıklıdır. Teşekkürler. 73
Hulusi Hocam:
Ben fortylerdeki mic giriş preanfisini SSM 2165 leri iptal edip ,
EFE QRP deki nin aynısı ile değiştirdim..
Modülasyon daha düzgün ve daha olumlu raporlar alıyorum öneririm...
Mehmet hocam, aynen onuda denedim. Bir cihazda oda var . Gayet güzel çalışıyor. 73.
Selamlar:
40 metrede şartlar yavaş yavaş düzeliyor.
Bu QRP cihazımla bu gün birkaç QSO yaptım.
Bir tanesini kaydetme şansım oldu linkte paylaşıyorum.
Ta3AMR/7 Sivas ----- TB5X Mehmet Niğde - Bor
http://youtu.be/xTRuhBZUwdE
Bugün Niğde Aladağlardan Ankara görüşmesi.
TA7N/2 - TB5X/QRP
https://www.facebook.com/mehmet.divili/videos/vb.639216697/10153743168071698/?type=2&theater¬if_t=like
Mehmet hocam çalışmalarınızda başarılar dilerim.
Mehmet bey cihazlarınız gerçekten çok güzel. Çalışmalarınızı ilgi ve beğeni ile izliyorum. Hem açık havada sportif çalışmalarınızda hem de amatörlük çalışmalarınızda başarılarınızın devamını dilerim. 73
