; K8 Shareware Keyer Microchip PIC Source Code
; Copyright (C) 1998 Steven T. Elliott K1EL. All rights reserved.
; Permission is granted to use, modify, or redistribute this software
; so long as it is not sold or exploited for profit.
; http://k1el.tripod.com/freeware.html 
; THIS SOFTWARE IS PROVIDED AS IS AND WITHOUT WARRANTY OF ANY KIND,
; EITHER EXPRESSED OR IMPLIED.
; I am trying to keep track of how many shareware K8s there are out
; there. Please send me an email when you get yours working.
; email: steve@k1el.com or k1el@aol.com
; Original Program: MORSE9.ASM 
; Initial Date:     8 MARCH, 1997
;  12.24.98  ste	public release
;  11.01.01  imw	16f84a version
;  10.01.04  ewp	16f628 version
; Modified by Ian M. Wilson (imw) K3IMW for 16F84A 11/01/01 
; Modified by Eric Pierce (EWP)  www.va3ep.net  Jan 10, 2004
; - Remove 12C509 / 16F84A Conditional Compiles
; - Changes required for 16F628A, internal 4mhz clock
; - Cleaned up comments a bit
; Assemble this code with the Microchip MPASM assembler.
; The configuration word is defined in the code but if your
; programmer is unable to understand it, program the part 
; as per the parameter selected configuration word. 
; Be sure to select decimal as the default radix in your assembler
; This code will produce a working part if you follow the 
; guidelines. Until you fully understand the code, only change
; the values in the K8 customization header. 
; Any modifications must be done with extreme care.
; Download the K8 Manual from the K1EL website to learn how to
; build and operate a keyer using this chip. Note that the pinouts
; in the K8 manual do not apply to the 16F628A, use the pinouts below
; Pinout and notes on 16F628A K8 implementation imw/EWP
; 16F628A, 20 (or 4) MHz P-DIP part
; pin	name	connection
; 1     RA2		N/C
; 2     RA3		N/C
; 3     RA4		N/C
; 4     MCLR	10k pullup resistor to +5v
; 5     VSS		0v (ground)
; 6     RB0		KEY	(4.7 K res to base of oc trans keys tx)
; 7     RB1		N/C
; 8     RB2		ST	(sidetone, to piezo spkr)
; 9     RB3		STK (beacon sw, optional, see manual)
; 10    RB4		DIT (paddle dit contact)
; 11    RB5		DAH (paddle dah contact)
; 12    RB6		N/C
; 13    RB7		PB  (push button memory, hold 2 s for command)
; 14    VDD		+5v (can be 3.5 to 5.5 v)
; 15    RA6		N/C 
; 16    RA7		N/C
; 17    RA0		N/C
; 18    RA1		N/C
; A 0.01uF decoupling capacitor connects between pins 14 and 5.
; The unit can be powered from 3, 1.5v cells in series. You may want to
; add an on/off switch (this is also the only way to reset the unit).
 	TITLE "K1EL K8 Morse Keyer"
 	LIST P=16F628A, R=D
    #include        <P16F628A.INC>
;***************** K8 Customization Header ****************************
; The following defines setup the basic configuration of the K8
; take a look at how they are used in the code to get an understanding
; of how they work. If you leave them as they are here you will get
; a working K8 without beacon mode, code protect off.
; If you don't know what you are doing, only modify the 
; CALL, SPEED_DEFAULT, message selection, and AR_ON
; DON'T CHANGE MODE_DEFAULT, PERIOD, or SPD_CONST 
; unless you are thoroughly familiar
; with the code. 
; Define STANDARD, QRP, CQTEST, or CONTEST default operation
	#define STANDARD    ; can be: STANDARD, QRP, CQTEST, or CONTEST
; If debug is defined, the code protect if OFF
	#define DEBUG	; default is defined
; If BEACON is defined, beacon mode enabled. See manual
;	#define BEACON	; default is not defined 
; Number of seconds for beacon repeat
	#define BEACON_TIME 4
; Defining NO_DE modifies default messages (EWP?)
;	#define NO_DE
; Defining SETFARNS enables the Farnsworth option
;	#define SETFARNS
; AR or or off in message, change as required 
	#define AR_ON       ; comment this out if you don't want AR sent
; MODE_DEFAULT is a bitfield that sets the default mode
; Bit 0 = STEN, Sidetone enable, 1 is on
; Bit 1 = STRQ, Sidetone request, always 1 (EWP?)
; Bit 2 = always 0
; Bit 3 = SWAP paddles, 0 for normal
; Bit 4 = I_MODE, 1 for full IAMBIC mode, 0 DE mode (see manual)
; Bit 5 = IAM_A, Iambic Mode A flag (A=1, B=0)
; Bit 6 = SKM, Straight Key Mode enable when 1
; Bit 7 = ASP, Autospace enable bit, on when 1 
MODE_DEFAULT  EQU  013H		; IAM_B mode + ASP off (original)
; MODE_DEFAULT  EQU  0B3H 	; IAM_A mode + ASP on (alternate)
; Morse Equates Table  
; These need to be defined first but
; should NOT be changed
M_END   EQU     0x00    ; Ending delimiter
M_SKIP  EQU     0x01    ; Skip this entry
M_SP    EQU     0x02    ; Word space
M_USER  EQU     0x03    ; Toggle to USER RAM    
M_CALL  EQU     0x05    ; Toggle to USER Callsign
M_TO    EQU     0x80    ; Timeout return from GETCW
M_0     EQU     0xFC    ; 0 1111 1100 = DAH-DAH-DAH-DAH-DAH
M_1     EQU     0x7C    ; 1 0111 1100 = DI-DAH-DAH-DAH-DAH
M_2     EQU     0x3C    ; 2 0011 1100 = DI-DI-DAH-DAH-DAH
M_3     EQU     0x1C    ; 3 0001 1100 = DI-DI-DI-DAH-DAH
M_4     EQU     0x0C    ; 4 0000 1100 = DI-DI-DI-DI-DAH
M_5     EQU     0x04    ; 5 0000 0100 = DI-DI-DI-DI-DIT
M_6     EQU     0x84    ; 6 1000 0100 = DAH-DI-DI-DI-DIT
M_7     EQU     0xC4    ; 7 1100 0100 = DAH-DAH-DI-DI-DIT
M_8     EQU     0xE4    ; 8 1110 0100 = DAH-DAH-DAH-DI-DIT
M_9     EQU     0xF4    ; 9 1111 0100 = DAH-DAH-DAH-DAH-DIT
M_AR    EQU     0x54    ;   0101 0100 = DI-DAH-DI-DAH-DIT
M_SK    EQU     0x16    ;   0001 0110 = DI-DI-DI-DAH-DI-DAH
M_PER   EQU     0x56    ;   0101 0110 = DI-DAH-DI-DAH-DI-DAH
M_COM   EQU     0xCE    ;   1100 1110 = DAH-DAH-DI-DI-DAH-DAH
M_BT    EQU     0x8C    ;   1000 1100 = DAH-DI-DI-DI-DAH
M_QUE   EQU     0x32    ; ? 0011 0010 = DI-DI-DAH-DAH-DI-DIT
M_DN    EQU     0x94    ;   1001 0100 = DAH-DI-DI-DAH-DIT
M_A     EQU     0x60    ; A 0110 0000 = DI-DAH
M_B     EQU     0x88    ; B 1000 1000 = DAH-DI-DI-DIT
M_C     EQU     0xA8    ; C 1010 1000 = DAH-DI-DAH-DIT
M_D     EQU     0x90    ; D 1001 0000 = DAH-DI-DIT
M_E     EQU     0x40    ; E 0100 0000 = DIT
M_F     EQU     0x28    ; F 0010 1000 = DI-DI-DAH-DIT
M_G     EQU     0xD0    ; G 1101 0000 = DAH-DAH-DIT
M_H     EQU     0x08    ; H 0000 1000 = DI-DI-DI-DIT
M_I     EQU     0x20    ; I 0010 0000 = DI-DIT
M_J     EQU     0x78    ; J 0111 1000 = DI-DAH-DAH-DAH
M_K     EQU     0xB0    ; K 1011 0000 = DAH-DI-DAH
M_L     EQU     0x48    ; L 0100 1000 = DI-DAH-DI-DIT
M_M     EQU     0xE0    ; M 1110 0000 = DAH-DAH
M_N     EQU     0xA0    ; N 1010 0000 = DAH-DIT
M_O     EQU     0xF0    ; O 1111 0000 = DAH-DAH-DAH
M_P     EQU     0x68    ; P 0110 1000 = DI-DAH-DAH-DIT
M_Q     EQU     0xD8    ; Q 1101 1000 = DAH-DAH-DI-DAH
M_R     EQU     0x50    ; R 0101 0000 = DI-DAH-DIT
M_S     EQU     0x10    ; S 0001 0000 = DI-DI-DIT
M_T     EQU     0xC0    ; T 1100 0000 = DAH
M_U     EQU     0x30    ; U 0011 0000 = DI-DI-DAH
M_V     EQU     0x18    ; V 0001 1000 = DI-DI-DI-DAH
M_W     EQU     0x70    ; W 0111 0000 = DI-DAH-DAH
M_X     EQU     0x98    ; X 1001 1000 = DAH-DI-DI-DAH
M_Y     EQU     0xB8    ; Y 1101 1000 = DAH-DAH-DI-DAH
M_Z     EQU     0xC8    ; Z 1100 1000 = DAH-DAH-DI-DIT
; Code Speed Index Defines
; Each index points to a delay value in the
; code speed index table. Use the call IDX2SPD
; to convert index to speed delay.
; These need to be defined first but should
; NOT be changed
WPM_5   EQU     00D
WPM_6   EQU     01D
WPM_7   EQU     02D
WPM_8   EQU     03D
WPM_9   EQU     04D
WPM_10  EQU     05D
WPM_11  EQU     06D
WPM_12  EQU     07D
WPM_13  EQU     08D
WPM_14  EQU     09D
WPM_15  EQU     10D
WPM_16  EQU     11D
WPM_17  EQU     12D
WPM_18  EQU     13D
WPM_19  EQU     14D
WPM_20  EQU     15D
WPM_21  EQU     16D
WPM_22  EQU     17D
WPM_23  EQU     18D
WPM_24  EQU     19D
WPM_25  EQU     20D
WPM_26  EQU     21D
WPM_27  EQU     22D
WPM_28  EQU     23D
WPM_29  EQU     24D
WPM_30  EQU     25D
WPM_31  EQU     26D
WPM_32  EQU     27D
WPM_33  EQU     28D
WPM_34  EQU     29D
WPM_35  EQU     30D
WPM_36  EQU     31D
WPM_37  EQU     32D
WPM_38  EQU     33D
WPM_39  EQU     34D
WPM_40  EQU     35D
WPM_41  EQU     36D
WPM_42  EQU     37D
WPM_43  EQU     38D
WPM_44  EQU     39D
WPM_45  EQU     40D
WPM_46  EQU     41D
WPM_47  EQU     42D
WPM_48  EQU     43D
WPM_49  EQU     44D
MAXSPDIDX EQU   WPM_49
; ------------Callsign default, change as required -------------
CALL_0  EQU  M_T		; Put your call here, letter by letter
CALL_1  EQU  M_A		; No more than 7 characters
CALL_2  EQU  M_1
CALL_3  EQU  M_C
CALL_4  EQU  M_D	
CALL_5  EQU  M_END
CALL_6  EQU  M_END
CALL_7  EQU  M_END
; - Speed default, change as required to any defined WPM_** symbol --
SPEED_DEFAULT  EQU  WPM_20  ; can be WPM_5 to WPM_49
;**************** End of Customization Header ***********************
; Modify below this point only if you REALLY understand the code
; Configuration word selection, based on configuration parameters
 ifdef BEACON
  ifdef DEBUG
   ;development mode, code protect off, watchdog on
;   __CONFIG _CP_OFF & _WDT_ON & _XT_OSC ; original EWP
	__CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _CP_OFF & _LVP_OFF & _BODEN_OFF
  else
  ;manufacture mode, code protect on, watchdog on
;   __CONFIG _CP_ON & _WDT_ON & _XT_OSC ; original EWP
	__CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _CP_ON & _LVP_OFF & _BODEN_OFF
  endif
 else
 ifdef DEBUG
   	; manufacture mode, code protect off, watchdog off
	; _lvp_off & _boden_off are required for strict '84 compatibility EWP
	;   __CONFIG _CP_OFF & _WDT_OFF  & _XT_OSC; Original EWP
	__CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _CP_OFF & _LVP_OFF & _BODEN_OFF
  else
   ;manufacture mode, code protect on, watchdog off
;   __CONFIG _CP_ON & _WDT_OFF  & _XT_OSC; Original EWP
	__CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _CP_ON & _LVP_OFF & _BODEN_OFF
  endif
 endif
PERIOD  EQU 120D
SPD_CONST  EQU 212D
;       PIC Specific Equates
; standard register defines are taken from the include file
PC9     EQU     Z       	; makes BSF STATUS, PC9 (etc) no-ops
PC		EQU	PCL		; for 8-bit PC adds, etc
;       File Register Assignments
GPIO    EQU	PORTB	; I/O Port - see below for changed pin assignments
	CBLOCK 0x20		; Registers, changed from '84 X0C EWP
	PROCLAT         ; Process Latch
	DELAYHI         ; High delay counter register
	DELAYLO         ; Low delay counter register
	TIMEBASE        ; Morse Time Base
	CURMSG          ; Currently Selected Message
	MODEREG         ; Mode Bits
	WTEMP			; for loading PCLATH
	SPEEDIDX        ; Current speed table index
	FARNS           ; Letterspacing
	BX              ;
	AL              ; General Purpose Registers
	AH              ;
	CL              ;
	CH              ;
	DL              ;
	DH              ;
	USRCALL: 8    ; User Callsign
	USERRAM: 16   ; User Message
	ENDC
;       MPU Bit Assignments
;    ** 16F84A uses port B **
; These bits also used in PROCLAT, differ from port assignments
DITPDL      EQU  00H     ; IN  DIT Paddle
DAHPDL      EQU  01H     ; IN  DAH Paddle
PB          EQU  03H     ; IN  Message/Config Push Button
XDITPDL     EQU  04H     ; RB4, IN  DIT Paddle
XDAHPDL     EQU  05H     ; RB5, IN  DAH Paddle
KEY         EQU  00H     ; RB0, OUT Keyed Output
XPB         EQU  07H     ; RB7, IN  Message/Config Push Button
TONE        EQU  02H     ; RB2, OUT Sidetone Output
 ifdef BEACON
BCON        EQU  03H     ; RB3, OUT Beacon Request Output
 else
STK         EQU  03H     ; RB3, OUT Keyed Sidetone Output
 endif
;       Mode Bit Assignments
; Note: The STEN bit *must* be enabled in 
; MODE_DEFAULT so the signon character will
; be audible, it gets setup properly at the
; beginning of SERVICE.
STEN       EQU  00H     ; Sidetone enable
STRQ       EQU  01H     ; Sidetone request
SWAP       EQU  03H     ; Swap paddles enable bit
I_MODE     EQU  04H     ; Full iambic mode enable (no auto DE message)
IAM_A      EQU  05H     ; Iambic Mode A flag (A=1, B=0)
SKM        EQU  06H     ; Straight Key Mode enable bit
ASP        EQU  07H     ; Autospace enable bit
STRQBIT    EQU  02H     ; Use this to XORF STRQ
SWAPBIT    EQU  08H     ; Use this to XORF SWAP
IAMBIT     EQU  10H     ; Use this to XORF I_MODE
IABBIT     EQU  20H     ; Use this to XORF IAM_A
SKMBIT     EQU  40H     ; Use this to XORF SKM
ASPBIT     EQU  80H     ; Use this to XORF ASP
;       PROCLAT  Equates
PDLMASK    EQU  03H     ; Mask: Paddle input bits
PROCMASK   EQU  0FCH    ; Mask: Process bits
INLAST     EQU  02H     ; Last input flag, 1 means Dit was just entered
USERON     EQU  03H     ; Use USERRAM as message source when set
CONVERSE   EQU  04H     ; Conversational mode flag (for DE message)
OUTLAST    EQU  05H     ; Last output flasg, 1 means Dit was sent last
BOTH_ON    EQU  06H     ; Both paddles were pressed, used in iambic mode B
TXSQ       EQU  07H     ; Transmit Key Squelch bit in PROCLAT
;       Miscellaneous Equates
SELDELAY_H EQU  120D    ; Delay constants for
SELDELAY_L EQU  240D    ; SELDELAY routine
GC_TO_L    EQU  220D    ; GETCW timeout inside loop
GC_TO_M    EQU  170D    ; GETCW timeout middle loop
GC_TO_H    EQU   3D     ; GETCW timeout outside loop
SPEEDCNT   EQU   4D     ; Number of characters sent in SPEED loop
;       RESET ENTRY
	ORG     0
	GOTO    INIT
	ORG	4
INTVEC	GOTO	INTVEC
;       Subroutines
; Must reside in first
; 256 bytes of codespace
; (probably not necessary on the '628 EWP)
;       Sample and Latch Input State
SAMPLE
	CALL   NSAMPLE
	RETLW   0
NSAMPLE
 ifdef BEACON
	CLRWDT			; Reset watchdog timer
 endif
	BTFSC   GPIO, XDITPDL
	GOTO    RIGHT_TEST
	BTFSC   MODEREG, SWAP
	GOTO    NS_DAH1
LEFT_TEST
	BSF     PROCLAT, DITPDL
	BSF     PROCLAT, INLAST	  ; Set on DIT
	GOTO    RIGHT_TEST
NS_DAH1
	BSF     PROCLAT, DAHPDL
	BCF     PROCLAT, INLAST	  ; Clear on DAH
RIGHT_TEST
	BTFSC   GPIO, XDAHPDL
	GOTO    NS_DONE
	BTFSS   MODEREG, SWAP
	GOTO    NS_DAH2
	BSF     PROCLAT, DITPDL
	BSF     PROCLAT, INLAST	  ; Clear on DAH
	GOTO    NS_DONE
NS_DAH2
	BSF     PROCLAT, DAHPDL
	BCF     PROCLAT, INLAST	  ; Set on DAH
NS_DONE
	RETURN
;       Send DIT
DITOUT
 ifndef BEACON
	BTFSC   MODEREG, STEN	; Sidetone enabled ?
	BSF     GPIO, STK	; Key Sidetone
 endif
	BTFSS   PROCLAT, TXSQ	; Transmit Key Squelch ?
	BSF     GPIO, KEY
	CALL   NDITDELAY
 ifndef BEACON
	BCF     GPIO, STK        ; Unkey Sidetone
 endif
	BCF     GPIO, KEY
	CALL   NDITDLY_NT
	BCF     PROCLAT, DITPDL  ; Clear DIT bit in paddle register
	BSF     PROCLAT, OUTLAST ; Mark that Dit was sent
	RETLW   0
;       Send DAH
DAHOUT
 ifndef BEACON
 endif
	BSF     GPIO, KEY
	MOVLW   3
	MOVWF   BX
NDLP
	CALL   NDITDELAY
	DECFSZ  BX, F
	GOTO    NDLP
 ifndef BEACON
 endif
	BCF     GPIO, KEY
	CALL   NDITDLY_NT
; if (I_MODE is off &&
;   we are in conversational mode &&
;     both paddles are pressed) 
;       then GOTO TRAILER
	BCF     PROCLAT, DAHPDL    ; Clear DAH bit in paddle register
	BCF     PROCLAT, OUTLAST   ; Mark that Dah was sent
	BTFSS   MODEREG, I_MODE    ; Is DE mode allowed ?
	BTFSC   PROCLAT, CONVERSE  ; Not in converse or iambic modes
	RETLW   0                  ; No, return
	BTFSS   GPIO, XDAHPDL
	BTFSC   GPIO, XDITPDL       ; if both paddles pressed goto TRAILER
	RETLW   0                  ; else return
;       Send Trailer Message
TRAILER
;       BCF     PROCLAT, CONVERSE  ; End conversational mode
 ifdef NO_DE
	CALL    DITOUT             ; Send rest of 'K'
	CALL    DAHOUT
 else
	CALL    DITOUT             ; Send rest of 'D'
	CALL    DITOUT
 endif
	CALL    LETTERSPACE
TRAIL0
	BTFSC   GPIO, XDITPDL    ; Wait till both paddles
	BTFSS   GPIO, XDAHPDL    ; are released
	GOTO    TRAIL0
	MOVLW   MSG7-MSGBASE    ; Point to 'DE'+1 message
	GOTO    L_SENDMSG       ; We will return to caller from there
; Wait sidetone delay with transmitter
; keyed. Used by TUNE & KEYDIRECT
; TUNE and KEYDIRECT call NDITDELAY thru
; STCLK, which sets an outside loop count
; of 1 and a reduced sidetone "low" time.
; This gives us a better match between
; KEYER and TUNE/KEYDIRECT sidetone.
STCLK
	MOVLW   10D             ; Ten passes
	GOTO    DITDEL
;       Dit Delay
; Set delay period to be 1.15mSec to give a
; sidetone frequency of 800Hz.
NDITDELAY
	MOVF    TIMEBASE, W     ; Get interval
DITDEL
	MOVWF   DELAYHI
	MOVLW   PERIOD-4	; Compensate for NSAMPLE
	GOTO    DITDEL15
DITDEL0
	MOVLW   PERIOD          ; 1/2 Period High, 575 us
DITDEL15
	MOVWF   DELAYLO
DITDEL1
	GOTO	DTL0
DTL0
	DECFSZ  DELAYLO, F      ; Inner Loop 1 Test 
	GOTO    DITDEL1
	BSF     GPIO, TONE      ; Key Sidetone
	MOVLW   PERIOD          ; 1/2 Period Low, 575 us
	MOVWF   DELAYLO
DITDEL2
	GOTO	DTL1
DTL1
	DECFSZ  DELAYLO,F       ; Inner Loop 2 Test
	GOTO    DITDEL2
	BCF     GPIO, TONE      ; Unkey Tone
	DECFSZ  DELAYHI,F       ; Outer Loop Test
	GOTO    DITDEL0
	GOTO    NSAMPLE         ; Latch early input
				; RETURN from there
;       Dit Delay without Sidetone
NDITDLY_NT
	MOVWF   DELAYHI
DD_NT0
	MOVWF   DELAYLO
DD_NT1
	GOTO	DNT0
DNT0
	GOTO	DNT1
DNT1
	GOTO	DNT2
DNT2
	NOP
	DECFSZ  DELAYLO, F      ; Inner Loop  Test
	GOTO    DD_NT1
	GOTO    DD_NT0
				; RETURN from there
;       Autospace Handler
; The idea is to keep the morse "pipe" full,
; that means that there should always be 
; something in PROCLAT to send after the 
; current dit or dah is sent. If not it is
; interpreted as an intercharacter space
; and a pause is inserted to fill out the 
; remainder of a letterspace period.
; Any paddle events will be recorded in
; PROCLAT and issued in the order received
; thanks to the INLAST bit.
AUTOSP
	CALL    SAMPLE           ; Refresh PROCLAT
	BTFSS   MODEREG, ASP     ; Leave if autospace disabled
	GOTO    SERVLOOP
	BTFSS   PROCLAT, DITPDL  ; Check if any in latch
	BTFSC   PROCLAT, DAHPDL
	GOTO    SERVLOOP         ; Yes: go send
	CALL    LETTERSPACE      ; No:  wait full letterspace
	GOTO    SERVLOOP         ; before allowing more sending
;       Word and Letter Spacing
; Remember that all characters have one
; dit delay tacked on automatically so
; only two are needed to provide a three
; bit letterspace. Six are needed for a
; seven bit word space. Extra letterspace
; is added via the value FARNS.
WORDSPACE
	MOVLW   6
	GOTO    WLSPAC0
LETTERSPACE
	MOVLW   2
WLSPAC0
	BTFSS   PROCLAT, CONVERSE ; no extra space in converse mode
	ADDWF   FARNS, W
	MOVWF   BX
WLSPAC1
	CALL   NDITDLY_NT
	DECFSZ  BX, F
	GOTO    WLSPAC1
	RETLW   0
;       Output Single Morse Character
; Uses AL
OSCHAR
	MOVWF   AL              ; Copy character
OSLOOP
	MOVF    AL, W           ; Get coded morse
	ADDWF   AL, F           ; AL*2, if (Z==0) DONE else C=DIT/DAH
	BTFSS   STATUS, Z       ; Skip if zero
	GOTO    OSCONT
	CALL    LETTERSPACE     ; Inter-letter space
	RETLW   0               ; All done, return
OSCONT
	BTFSC   STATUS, C       ; (C==1) then DAH else DIT
	GOTO    OSDAH
	CALL    DITOUT
	GOTO    OSLOOP
OSDAH
	CALL    DAHOUT
	GOTO    OSLOOP
; Decimal to Morse Conversion Table
DEC2CW
	MOVWF	WTEMP
	MOVLW	HIGH($)
	MOVWF	PCLATH
	MOVF	WTEMP,W
	ADDWF   PC, F   ; Jump through table
DECTBL
	RETLW   M_0
	RETLW   M_1
	RETLW   M_2
	RETLW   M_3
	RETLW   M_4
	RETLW   M_5
	RETLW   M_6
	RETLW   M_7
	RETLW   M_8
	RETLW   M_9
;       Cross Page Jumps                    
; Note 1: Routines in high page assume they
; called from low page and clear PC9 before
; they return. It is not possible to call
; a high page routine from the high page.
; Note 2: Subroutines above the 256 byte
; boundary are called through this interface.
; A call is converted to a jump, the called
; subroutine in high page ends with a return
; which pops the full 10 bit return address
; of the low page caller.
; (This is probably not necessary for the '628
; but appears to work EWP)
L_SENDMSG
	BSF     STATUS, PC9      ; Set PAGE bit for long GOTO
	GOTO    SENDMSG
L_CW2IDX
	GOTO    CW2IDX
L_IDX2SPD
	GOTO    IDX2SPD
L_GETCW
	GOTO    GETCW
L_CONV_HI
	GOTO    CONV_HI
L_CONV_LO
	GOTO    CONV_LO
;       Long delay for user prompts
; Uses: CL
; Returns: 
;       CL MSB=1 if paddle pressed, 0 if not
SELDELAY
	MOVLW   SELDELAY_H      ; Set high select delay
	MOVWF   DELAYHI
SELD0
	MOVLW   SELDELAY_L      ; Set low select delay
	MOVWF   DELAYLO
SELD1
	CALL    SAMPLE          ; Latch paddle press
	GOTO    SLD0
SLD0
	GOTO    SELD1
	DECFSZ  DELAYHI, F      ; Inner Loop 1 Test
	GOTO    SELD0
	BTFSS   PROCLAT, DAHPDL ; DAH closed ?
	BTFSC   PROCLAT, DITPDL ; DIT closed ?
	GOTO    SDYES
SDNO
	BCF     CL, 0           ; Timed out w/no paddle pressed
	GOTO    SDRET
SDYES
	BSF     CL, 0           ; A paddle was pressed
SDRET
	RETLW   0
;       Push Button Switch Handler
; Converse mode is defined as the phase
; where the user is actually entering some
; morse letters. We want letterspace off
; to improve response, and we want DE mode
; off to prevent undesired output.
CONFIG
; ------- Disable Letterspace Here -----------
	BSF     PROCLAT, CONVERSE ; Start converse mode
	BSF     PROCLAT, TXSQ   ; Disable Key
	BSF     MODEREG, STEN   ; Force sidetone
	MOVLW   M_R             ; Signal user to enter code
	CALL    OSCHAR
CONFWT
	CLRWDT
	BTFSS   GPIO, XPB        ; Still closed ?
	GOTO    CONFWT          ;  wait till released
	CALL    L_GETCW         ; Get user response
	CALL    L_CW2IDX        ; Translate CW to table index
	BCF     STATUS, PC9     ; Clear page bit
 	MOVWF	WTEMP
	MOVLW	HIGH($)
	MOVWF	PCLATH
	MOVF	WTEMP,W
	GOTO    SIDETONE        ; A=Sidetone enable
	GOTO    LOADCALL        ; C=Load new callsign
	GOTO    FARNSWORTH      ; F=Farnsworth Adjust
	GOTO    IAMBIC          ; I=Iambic mode toggle
	GOTO    KEYMODE         ; K=Keyer mode
	GOTO    LOADUSER        ; L=Load user RAM
	GOTO    SPEED           ; S=Speed
	GOTO    TUNE            ; T=Tune
	GOTO    ASP_TOGGLE      ; U=Autospace Toggle
	GOTO    SWAP_TOGGLE     ; X=Swap Paddles Toggle
	GOTO    DE_TOGGLE       ; Z=DE Mode Toggle
; ------- Allow Letterspace for below ---------
	GOTO    DUMPUSER        ; D=Play user RAM
	GOTO    MSGSELECT       ; M=Message select
	GOTO    PRACTICE        ; P=Practice mode
	GOTO    OUTWPM          ; W=Report Morse speed
	GOTO    QUERET          ; Unknown entry !?!?
				; Use common return
;	Wake Up Handler
; BX is used as a beacon timer, it is 
; initialized at the end of QVRET.
; The OPTION register is setup so that WDT
; will cause a reset every 2 seconds. From
; INIT we will get vectored here. Where
; BX will be checked to see if it is zero.
; If so pin 2 will be configured as an output
; and asserted low true. If BX is not zero
; it is is decremented. Note that a pin
; change will be handled in the same manner
; as a WDT timeout but this is moot since
; the beacon enable switch will be off in
; non-beacon mode. BX will normally rest at
; a value of zero courtesy of the DAHOUT and 
; LETTERSPACE routines.
 ifdef BEACON
WAKEUP
	MOVF    BX, W        ; Test beacon timer
	BTFSC   STATUS, Z    ; If zero: Beacon ON
	GOTO	BEAC_ON
	DECF	BX, F	     ; Else: Decrement beacon timer
	GOTO	SERVICE	     ; Continue in case it was 
			     		;   a pin change wakeup
BEAC_ON
	BCF	GPIO, BCON   ; Insure that GP5 reg is zero
	MOVLW   B'11110000'  ; Make RB3 an output
	BSF	STATUS, RP0
	MOVWF	TRISB ^ 0x80 ; to assert beacon request
	BCF	STATUS, RP0
 endif
;*      MAIN GPIO Service Routine          *
SERVICE
	BCF     MODEREG, STEN   ; Restore user's 
	BTFSC   MODEREG, STRQ   ;   sidetone
	BSF     MODEREG, STEN   ;     preference.
	CLRF    PROCLAT         ; Clear TXSQ and any latched inputs
SERVLOOP
	CALL    SAMPLE
	BTFSS   MODEREG, SKM    ; Straight key mode ?
	GOTO    KEYER           ;  No: Go keyer
	BTFSC   PROCLAT, DAHPDL ; DAH paddle pressed ?
	GOTO    KEYDIRECT       ;  Yes: Go straight key
	GOTO    PBTEST          ;  No:  Test pushbutton
; Iambic operation: If iambic mode is enabled the following state
; machine outputs alternating dits and dahs when both paddles are 
; pressed at the same time. DIT_PADDLE = GPIO, DIT_PADDLE_L = PROC_LAT
;           if ((DIT PADDLE && DAH PADDLE) && (I_MODE == TRUE)
;               set BOTH_ON         "ref. Mode B"
;               if (DIT LAST) {
;                   send DAH
;                   clear DIT LAST
;               else {  
;                   (this also handles odd case where both paddles
;                    hit simultaneously)
;                   send DIT
;                   set DIT LAST
;           else if (BOTH_ON == TRUE) {  "ref: Mode B, BOTH_ON is 
;               clear BOTH_ON                  never set in MODE A"
;               if (DIT LAST)
;                   send DAH
;               else
;                   send DIT
;           else {
;               if (L_DIT_PADDLE && L_DAH_PADDLE) {
;                   if (INLAST) {
;                       send DAH
;                       clear DIT LAST
;                   else {
;                       send DIT
;                       set DIT LAST
;               if (DIT PADDLE) {
;                   send DIT
;                   set DIT LAST
;               else if (DAH PADDLE) {
;                   send DAH
;                   clear DIT LAST
;               else {
;                  (if neither paddle is set, do nothing)
KEYER
	BTFSS   MODEREG, I_MODE  ; DE mode ?
	GOTO    CHK_SINGLE        ; Yes: Skip
; Iambic mode A and B operation depend on PROCLAT, BOTH_ON and current
; state of the paddles. In mode B PROCLAT is used to check if the
; both paddles were pressed at the end of toggle mode to see if an 
; extra dit or dah are sent.
; In mode A the PROCLAT is cleared when leaving toggle mode to
; prevent any additional dits or dahs from being sent.
; We check GPIO here since we need to monitor real time paddle
; status, the case where both are set in PROCLAT must be
; handled specially since order must be observed.
	BTFSS   GPIO, XDITPDL      ; DIT paddle *and*
	BTFSC   GPIO, XDAHPDL      ;     DAH paddle pressed ?
	GOTO    CHK_BOTH_ON       ;  No: Go check if both is pending
; Both Paddles are pressed
	BSF     PROCLAT, BOTH_ON  ; Set both paddles on flag
TOGGLE
	BTFSC   PROCLAT, OUTLAST  ; If LAT==1 (dit was last) then DAH
	GOTO    LPDAH             ; 
	GOTO    LPDIT             ; else, always DIT. This addresses
				  ; the case where both paddles hit at
				  ; the same time.
; Both paddles aren't pressed, check if they just were
; and if in MODE B, issue alternate. Otherwise just
; check for single dit or dah request.
CHK_BOTH_ON
	BTFSS   PROCLAT, BOTH_ON
	GOTO    CHK_SINGLE
	BCF     PROCLAT, BOTH_ON
	BTFSS   MODEREG, IAM_A
	GOTO    TOGGLE            ; Mode B, send one more
	CLRF    PROCLAT           ; Mode A, kill any in latch
	GOTO    AUTOSP
; First check to see if both bits are set, if they are we
; need to figure out which one to send first. INLAST tells
; the last paddle input received, so the opposite is sent.
CHK_SINGLE
	GOTO    CHK_S1
	BTFSC   PROCLAT, INLAST   ; INLAST = 1 if DIT was last
	GOTO    LPDAH
				  ; Fall thru, and a DIT gets sent
CHK_S1
	BTFSC   PROCLAT, DITPDL   ; DIT Paddle closed when = 1
	GOTO    LPDIT
	BTFSS   PROCLAT, DAHPDL   ; DAH Paddle closed when = 1
	GOTO    PBTEST
LPDAH
	CALL    DAHOUT
	GOTO    AUTOSP
LPDIT
	CALL    DITOUT  
	GOTO    AUTOSP
PBTEST
	BTFSS   GPIO, XPB           ; Push Button closed when = 0
	GOTO	PBHANDLE	    ; changed logic of skip (imw)
;       Go into sleep mode until one
;       of the switches are hit or 
;       Watchdog timer times out.
	SLEEP			; RB change will wake us up. Since GIE not enabled, arrive
	NOP			; here.
	BCF	INTCON, 0	; clear RBIF
	GOTO	SERVICE		; resume
PBHANDLE			; jump logic changed for jump around sleep, etc
 ifdef BEACON
	MOVLW   B'11111000'      ; Restore Pin 2 as an input
	BSF STATUS, RP0          ; to cancel beacon request
	MOVWF	TRISB ^ 0x80
	BCF	STATUS, RP0
 endif
	CALL    SELDELAY
	BTFSC   GPIO, XPB         ; Is Push Button closed ? (==0)
	GOTO    PBMSG		 ;  No: output message
	CALL    SELDELAY	 ;  Yes: wait again
	BTFSS   GPIO, XPB         ; Is Push Button closed ? (==0)
	GOTO    CONFIG		 ;  Yes: do config routine
	MOVF    CURMSG, W        ; Point to 'current' message
	GOTO    QVRET
;       Key transmitter for tuning
TUNE
	BTFSS   MODEREG, STRQ   ; Restore sidetone
	BCF     MODEREG, STEN   ;   preference.
 ifndef BEACON
 endif
	BSF     GPIO, KEY       ; Key transmitter
TUNELP
	CALL    STCLK           ; Key XMTR and delay w/sidetone
	BTFSC   PROCLAT, DAHPDL ; DAH paddle ends tune
	GOTO    WAIT4OFF
	BTFSS   PROCLAT, DITPDL ; DIT paddle ends tune
	GOTO    TUNELP
				; Fall through
;       Wait for paddle release
WAIT4OFF
	MOVLW   25D             ; debounce count
	MOVWF   AL
WAIT4LP
 ifdef BEACON
 endif
	BTFSC   GPIO, XDITPDL    ; Make sure paddles
	BTFSS   GPIO, XDAHPDL    ; remain unpressed
	GOTO    WAIT4OFF
	DECFSZ  AL, F
	GOTO    WAIT4LP
 ifndef BEACON
 endif
	BCF     GPIO, KEY       ; Unkey transmitter
	GOTO    SERVICE
;       Key XMTR for straight key mode
; We only look at one paddle for straight
; keying but the user can select which one
; with the swap command. 
KEYDIRECT
 ifndef BEACON
 endif
KEYDLP
	BCF	PROCLAT, DAHPDL  ; Clear latched DAH
	BTFSC   PROCLAT, DAHPDL  ; DAH paddle still pressed ?
	GOTO	KEYDLP		 ; Yes: Loop
	GOTO	WAIT4OFF	 ; No: Leave via debounce
;       Set Extra Letterspace
; Uses: AH, CL
FARNSWORTH
	MOVLW   M_E             ; Ask for Number
	CALL    OSCHAR
	CALL    L_GETCW         ; Get user response in AH
	MOVLW   M_TO            ; Did user just sit there ?
	SUBWF   AH, W
	BTFSC   STATUS, Z
	GOTO    QUERET          ; Yes, end it
	MOVLW   80H             ; Validity check value
	MOVWF   CL              ;   save it for later
	CALL    L_CONV_LO       ; Convert AH to 1's
	ADDWF   CL, W           ; Check value
	BTFSS   STATUS, C       ; Valid if Carry = 1
	GOTO    QUERET
	MOVWF   FARNS           ; Set new Farnsworth adj.
	GOTO    COMRET_R
;       Set New CW Sending Speed
; Uses: AH, CL, CH
SPEED
	CLRF    CH              ; Init pass count
SPLOOP
	CALL    OSCHAR
	SUBWF   AH, W
	BTFSC   STATUS, Z
	BTFSC   CH, 0           ; Skip on 1st pass
	GOTO    SPSUM
	CALL    L_CONV_HI       ; Convert AH to 10's
	MOVWF   CL              ; Save MSN
	BSF     CH, 0           ; Set pass flag
	GOTO    SPLOOP
SPSUM
	ADDWF   CL, F           ; Add in MSN
	BTFSS   STATUS, C       ; If both are valid both MSBs = 1
	GOTO    QUERET          ; So if Carry=1 we have good values
	MOVLW   -5D             ; Adjust for indexing
	ADDWF   CL, W           ; And verify low limit 
	BTFSS   STATUS, C       ; C==1 if >= 5, error if not
	GOTO    QUERET
	MOVWF   SPEEDIDX
	CALL    L_IDX2SPD       ; Convert index to delay constant
	MOVWF   TIMEBASE        ; Store it away
	GOTO    COMRET_R
QUERET
	MOVLW   M_QUE           ; Send ? for error
	GOTO    COMRET
;       Message Selection
MSGSELECT
	CALL    SELDELAY
MSGLOOP
	MOVLW   MSG2-MSGBASE    ; Select message 2: Short CQ
	MOVWF   CURMSG
	MOVLW   M_C             ; C
	CALL    OSCHAR
	MOVLW   M_Q             ; Q
	CALL    OSCHAR
	CALL    SELDELAY
	BTFSC   CL, 0           ; Paddle closure ?
	GOTO    MSGDONE         ; Yes, all done
	MOVLW   MSG1-MSGBASE    ; Select message 1: Variable
	MOVWF   CURMSG
 ifdef CQTEST
	MOVLW   M_C             ; C
	CALL    OSCHAR
	MOVLW   M_Q             ; Q
	CALL    OSCHAR
	MOVLW   M_T             ; T
	CALL    OSCHAR
 endif
 ifdef CONTEST
	MOVLW   M_T             ; T
	CALL    OSCHAR
	MOVLW   M_S             ; S
	CALL    OSCHAR
	MOVLW   M_T             ; T
	CALL    OSCHAR
 endif
 ifdef QRP
	MOVLW   M_Q             ; Q
	CALL    OSCHAR
	MOVLW   M_R             ; R
	CALL    OSCHAR
	MOVLW   M_P             ; P
	CALL    OSCHAR
 endif
 ifdef STANDARD
	MOVLW   M_C             ; C
	CALL    OSCHAR
	MOVLW   M_Q             ; Q
	CALL    OSCHAR
	MOVLW   M_L             ; L
	CALL    OSCHAR
 endif
	CALL    SELDELAY
	MOVLW   MSG3-MSGBASE    ; No, select message 3
	MOVWF   CURMSG
	MOVLW   M_D             ; D
	CALL    OSCHAR
	MOVLW   M_X             ; X
	CALL    OSCHAR
	CALL    SELDELAY
	MOVLW   MSG4-MSGBASE    ; No, select message 4
	MOVWF   CURMSG
	MOVLW   M_C             ; C
	CALL    OSCHAR
	MOVLW   M_Q             ; Q
	CALL    OSCHAR
	MOVLW   M_C             ; C
	CALL    OSCHAR
	CALL    SELDELAY
	MOVLW   MSG5-MSGBASE    ; No, select message 5
	MOVWF   CURMSG
	MOVLW   M_M             ; M
	CALL    OSCHAR
	MOVLW   M_S             ; S
	CALL    OSCHAR
	MOVLW   M_G             ; G
	CALL    OSCHAR
	CALL    SELDELAY
	BTFSS   CL, 0           ; Paddle closure ?
	GOTO    MSGLOOP         ; No: loop till user picks one
MSGDONE
	MOVLW   M_R             ; Yes: Send an 'R' for acknowledgement
	CALL    OSCHAR
	GOTO    WAIT4OFF        ; Common "wait then return"
;       Paddle Swap Toggle
SWAP_TOGGLE
	MOVLW   SWAPBIT
	GOTO    COMXOR          ; Shared XOR
;       Sidetone Toggle
SIDETONE
	MOVLW   STRQBIT
;       Toggle Keyer Mode
; Default is keyer mode, everytime this
; is called the mode will toggle between
; keyer and straight key mode.
KEYMODE
	MOVLW   SKMBIT
COMXOR
	XORWF   MODEREG, F      ; Shared XOR
	GOTO    MSGDONE         ; Common return, R for ack
;       Toggle Iambic Mode
; Toggle the iambic mode between Mode A 
; which is not self completing and Mode B
; which is. Self completing means an extra
; alternate element is sent after both
; paddles are released.
IAMBIC
	MOVLW   IABBIT
	XORWF   MODEREG, F
	MOVLW   M_A             ; Assume Iambic mode A
	BTFSS   MODEREG, IAM_A  ; A=1, B=0
	MOVLW   M_B             ; Assumed wrong, it's B
	GOTO    COMRET
;       Autospace Toggle 
ASP_TOGGLE
	MOVLW   ASPBIT
	XORWF   MODEREG, F
	MOVLW   M_A             ; Assume Autospace mode
	BTFSS   MODEREG, ASP    ; Autospace=1, Normal=0
	MOVLW   M_N
	GOTO    COMRET
;       Toggle DE Mode
; Toggle the user defined iambic enable
; In iambic mode, when both paddles are
; pressed alternating dits/dahs are sent.
; I_MODE off will allow the use of the
; automatic 'DE' message.
DE_TOGGLE
	MOVLW   IAMBIT
	XORWF   MODEREG, F
	MOVLW   M_D             ; Assume DE mode
	BTFSC   MODEREG, I_MODE
	MOVLW   M_I             ; Assumed wrong, it's iambic mode
	GOTO    COMRET          ; Use shared return
;       Code Practice
; Send a stream of random CW characters
PRACTICE
	GOTO    PRAC_RUN
;       Load RAM Routine
; Two entry points, one for loading callsign
; and a second for loading user message.
; Uses AH, CL
LOADCALL
	MOVLW   USRCALL         ; Point to start of callsign string
	MOVWF   FSR
	MOVLW   08H             ; Max callsign length (8 decimal)
	GOTO    LU00
LOADUSER
	MOVLW   USERRAM         ; Point to start of user string
	MOVLW   0FH             ; Max string length (15 decimal)
LU00
	MOVWF   CL              ; Length in reg CL
;       CLRF    INDF            ; In case nothing is entered
LULOOP
	MOVLW   M_E             ; Signal user to enter code
	CALL    OSCHAR
	CALL    L_GETCW         ; Get a letter in AH
	MOVLW   M_PER           ; Did user explicitly end ?
	SUBWF   AH, W
	BTFSC   STATUS, Z
	GOTO    LUDONE          ; Yep, leave
	SUBWF   AH, W
	BTFSS   STATUS, Z
	GOTO    LU0             ; No, we have a valid character
	MOVLW   M_SP            ; Yes, they want a space
	GOTO    LU1
LU0
	MOVF    AH, W           ; Get char
LU1
	MOVWF   INDF            ; Store in RAM
	INCF    FSR, F          ; Bump counter
	MOVLW   M_END           ; Append an EOS token
	DECFSZ  CL, F           ; Decrement length count
	GOTO    LULOOP          
LUDONE
							; Fall thru to common return
;       Common Return
COMRET_R
	MOVLW   M_R             ; Send a "roger" 
COMRET
	CALL    OSCHAR
	GOTO    SERVICE
;       Dump User String
DUMPUSER
	MOVLW   MSG5-MSGBASE    ; Point to USER message
QVRET
	CALL    L_SENDMSG       ; We will return to caller from there
	MOVLW   BEACON_TIME
	MOVWF   BX
	GOTO    SERVICE
;       Report Morse speed
OUTWPM
	MOVLW   5D              ; Slowest speed
	ADDWF   SPEEDIDX, W     ; Add index
OUTDEC
	CLRF    CH              ; Clear tens register
	MOVWF   CL              ; Copy decimal number
	MOVLW   10D             ; Base 10
ODLOOP
	SUBWF   CL, F           ; Extract 10's
	BTFSS   STATUS, C       ; C==0 : Underflow
	GOTO    ODNEG
	INCF    CH, F           ; Incr 10's
	GOTO    ODLOOP
ODNEG
	ADDWF   CL, F           ; Restore ones to positive
	MOVF    CH, W           ; Output 10's first
	BTFSC   STATUS, Z       ; Suppress leading zero 
	GOTO    ODONES
	CALL    DEC2CW
	CALL    OSCHAR
ODONES
	MOVF    CL, W           ; Output 1's
	CALL    DEC2CW
	CALL    OSCHAR
	MOVLW   MSG8-MSGBASE    ; Send WPM string
	GOTO    QVRET           ; Use shared return
;*      Initialization Routine             *    
INIT	BCF	STATUS, RP0		;on '628 for '84 compat on Bank0
		MOVLW H'07'			;Init CMCON for digital IO
		MOVWF CMCON			;on PORTA
 ifdef BEACON 
	MOVLW   B'11111000'     ; IN:RB7,6,5,4,3 OUT:RB2,1,0
 else
	MOVLW   B'11110000'     ; IN:RB7,6,5,4 OUT:RB3,2,1,0
 endif
	BSF	STATUS, RP0
	MOVWF	TRISB ^ 0x80
	MOVLW	0
	MOVWF	TRISA ^ 0x80	; A = all outputs
	MOVLW   B'00001110'     ; Enable PUs, Pscl->WDT
	MOVWF	OPTION_REG ^ 0x80   ; Timer Clk=Internal, Prescale=1:64
	BCF	STATUS, RP0
	CLRF	GPIO		; Note: Beacon Request is asserted
						; but not active since RB3 is an input
	MOVLW	B'00001000'	; Enable RB port change interrupt (but NOT GIE)
	MOVWF	INTCON
 ifdef BEACON
	BTFSS   STATUS, PD      ; Is this is a power up or dead man WDT ?
				; Finish reset if so
	GOTO	WAKEUP		; else: Go do wakeup stuff
 else
	; TODO - implement wake-on-interrupt
 endif
 ifdef SETFARNS
        MOVLW	1		; CAN ONLY USE THIS IN NON_BEACON MODE !!!
        MOVWF	FARNS
 else
	CLRF    FARNS           ; Initialize Farnsworth adj.
 endif
	MOVLW   SPEED_DEFAULT   ; Initialize Morse Timebase
	MOVWF   SPEEDIDX
	MOVLW   MODE_DEFAULT    ; Load MODEREG default
	MOVWF   MODEREG         
	MOVLW   USERRAM
	MOVWF   FSR             ; Use indirect addressing
	CLRF    INDF            ; To init user message empty    
	MOVLW   USRCALL         ; Load callsign into RAM
	GOTO    XFRSTUB 
XFRRET
	MOVWF   CURMSG          ;  as default
	BSF     PROCLAT, TXSQ   ; Don't transmit, just run sidetone
				; SERVICE will reset TXSQ
	MOVLW   M_R             ; Send R for hello
	BTFSS   GPIO, XDAHPDL    ; Hook to get version
	MOVLW   M_G             ; Send Version ID
	GOTO    COMRET          ; Use common return entry
;      Page Boundary
	ORG 0300h  	; change from 200 to make 
				; room for extra 628 code EWP
;       Move W to (FSR++)
XFRIDX
	MOVWF   INDF
	INCF    FSR, F
	RETLW   0
; Message Table
; Call with message pointer in DH reg
; Table entry *DH++ is returned in W.
; We start at a new page to allow us to have
; a long message table which we can be sure 
; will never cross a page boundary. 
; Note: CALLs and computed jumps will always
; clear the PC[8] bit. PC[9] is sourced from
; STATUS reg bit 5.
GETMSG
	MOVF    DH, W
	INCF    DH, F
	MOVWF	WTEMP
	MOVLW	HIGH($)
	MOVWF	PCLATH
	MOVF	WTEMP,W
MSGBASE
MSG1
 ifdef CONTEST
	RETLW   M_T     ; Contest Message
	RETLW   M_E
	RETLW   M_S
	RETLW   M_T
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_E
	RETLW   M_S
	RETLW   M_T
	RETLW   M_SP
	RETLW   M_END
 endif
 ifdef CQTEST
	RETLW   M_C     ; CQ TEST
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_T
	RETLW   M_E
	RETLW   M_S
	RETLW   M_T
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_T
	RETLW   M_E
	RETLW   M_S
	RETLW   M_T
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_K
	RETLW   M_END
 endif
 ifdef QRP
	RETLW   M_C     ; QRP
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
;	RETLW   M_SP
	RETLW   M_DN
	RETLW   M_Q
	RETLW   M_R
	RETLW   M_P
	RETLW   M_SP
 ifdef AR_ON
	RETLW   M_AR
	RETLW   M_SP
 endif
	RETLW   M_K
	RETLW   M_END
 endif
 ifdef STANDARD
	RETLW   M_C     ; Long CQ Message
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
 endif
MSG2
	RETLW   M_C     ; CQ Message
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
;	RETLW   M_CALL  ;extra
;	RETLW   M_SP    ;extra
 ifdef AR_ON
	RETLW   M_AR
	RETLW   M_SP
 endif
	RETLW   M_K
	RETLW   M_END
MSG3
	RETLW   M_C     ; CQ DX Message
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_C
	RETLW   M_Q
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_X
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_X
	RETLW   M_SP
 ifdef AR_ON
	RETLW   M_AR
	RETLW   M_SP
 endif
	RETLW   M_K
	RETLW   M_END
MSG4
	RETLW   M_USER  ; Custom Contest Message
	RETLW   M_SP
	RETLW   M_D
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
	RETLW   M_CALL
	RETLW   M_SP
 ifdef AR_ON
	RETLW   M_AR
	RETLW   M_SP
 endif
	RETLW   M_K
	RETLW   M_END
MSG5
	RETLW   M_USER  ; User Message
	RETLW   M_SP
	RETLW   M_END
MSG7
 ifdef NO_DE
	RETLW   CALL_1
	RETLW   CALL_2
	RETLW   CALL_3
 else
	RETLW   M_E
	RETLW   M_SP
	RETLW   M_CALL
 endif
	RETLW   M_SP
	RETLW   M_END
MSG8
	RETLW   M_SP    ; WPM suffix
	RETLW   M_W
	RETLW   M_P
	RETLW   M_M
	RETLW   M_END
; Randomized Code Practice Table
GETPRAC
	MOVWF	WTEMP
	MOVLW	HIGH($)
	MOVWF	PCLATH
	MOVF	WTEMP,W
CWTBL
	RETLW   0xE4    ; 8 8  1110 0100 = DAH-DAH-DAH-DI-DIT
	RETLW   0x20    ;25 I  0010 0000 = DI-DIT
	RETLW   0x70    ;39 W  0111 0000 = DI-DAH-DAH
	RETLW   0x50    ;34 R  0101 0000 = DI-DAH-DIT
	RETLW   0xA8    ;19 C  1010 1000 = DAH-DI-DAH-DIT
	RETLW   0xD8    ;33 Q  1101 1000 = DAH-DAH-DI-DAH
	RETLW   0x32    ;15 ?  0011 0010 = DI-DI-DAH-DAH-DI-DIT
	RETLW   0x3C    ; 2 2  0011 1100 = DI-DI-DAH-DAH-DAH
	RETLW   0x94    ;16 /  1001 0100 = DAH-DI-DI-DAH-DIT
	RETLW   0x60    ;17 A  0110 0000 = DI-DAH
	RETLW   0x68    ;32 P  0110 1000 = DI-DAH-DAH-DIT
	RETLW   0xFC    ; 0 0  1111 1100 = DAH-DAH-DAH-DAH-DAH
	RETLW   0x78    ;26 J  0111 1000 = DI-DAH-DAH-DAH
	RETLW   0xCE    ;13 ,  1100 1110 = DAH-DAH-DI-DI-DAH-DAH
	RETLW   0x0C    ; 4 4  0000 1100 = DI-DI-DI-DI-DAH
	RETLW   0x10    ;35 S  0001 0000 = DI-DI-DIT
	RETLW   0x8C    ;14 BT 1000 1100 = DAH-DI-DI-DI-DAH
	RETLW   0x54    ;10 AR 0101 0100 = DI-DAH-DI-DAH-DIT
	RETLW   0x28    ;22 F  0010 1000 = DI-DI-DAH-DIT
	RETLW   0xD0    ;23 G  1101 0000 = DAH-DAH-DIT
	RETLW   0x90    ;20 D  1001 0000 = DAH-DI-DIT
	RETLW   0x04    ; 5 5  0000 0100 = DI-DI-DI-DI-DIT
	RETLW   0x88    ;18 B  1000 1000 = DAH-DI-DI-DIT
	RETLW   0x18    ;38 V  0001 1000 = DI-DI-DI-DAH
	RETLW   0xF4    ; 9 9  1111 0100 = DAH-DAH-DAH-DAH-DIT
	RETLW   0x56    ;12 .  0101 0110 = DAH-DAH-DI-DI-DAH
	RETLW   0xC0    ;36 T  1100 0000 = DAH
	RETLW   0x30    ;37 U  0011 0000 = DI-DI-DAH
	RETLW   0xB8    ;41 Y  1101 1000 = DAH-DAH-DI-DAH
	RETLW   0xE0    ;29 M  1110 0000 = DAH-DAH
	RETLW   0xC4    ; 7 7  1100 0100 = DAH-DAH-DI-DI-DIT
	RETLW   0x84    ; 6 6  1000 0100 = DAH-DI-DI-DI-DIT
	RETLW   0x16    ;11 SK 0001 0110 = DI-DI-DI-DAH-DI-DAH
	RETLW   0x1C    ; 3 3  0001 1100 = DI-DI-DI-DAH-DAH
	RETLW   0x08    ;24 H  0000 1000 = DI-DI-DI-DIT
	RETLW   0x98    ;40 X  1001 1000 = DAH-DI-DI-DAH
	RETLW   0xC8    ;42 Z  1100 1000 = DAH-DAH-DI-DIT
	RETLW   0x48    ;28 L  0100 1000 = DI-DAH-DI-DIT
	RETLW   0x7C    ; 1 1  0111 1100 = DI-DAH-DAH-DAH-DAH
	RETLW   0xB0    ;27 K  1011 0000 = DAH-DI-DAH
	RETLW   0xA0    ;30 N  1010 0000 = DAH-DIT
	RETLW   0x40    ;21 E  0100 0000 = DIT
	RETLW   0xF0    ;31 O  1111 0000 = DAH-DAH-DAH
; Code Speed Table
;       TIMEBASE Defaults
; Using ARRL Handbook as a reference, a 5 WPM dit
; is 240 msec, a dah is 720 ms. 
; Formula:
; Count= (((5/WPM) * 240) / SIDETONE_PERIOD)
; For Sidetone Freq of 870 Hz (1.15 ms):
; Count = ((5/WPM) * (240/1.15))
SVAL   EQU      (5D * SPD_CONST)    ; Fudged By oscilloscope verification
IDX2SPD
	MOVWF	WTEMP
	MOVLW	HIGH($)
	MOVWF	PCLATH
	MOVF	WTEMP,W
; endif
SPEEDTBL
	RETLW   SVAL/5D  ; WPM_5
	RETLW   SVAL/6D  ; WPM_6
	RETLW   SVAL/7D  ; WPM_7
	RETLW   SVAL/8D  ; WPM_8
	RETLW   SVAL/9D  ; WPM_9
	RETLW   SVAL/10D ; WPM_10
	RETLW   SVAL/11D ; WPM_11
	RETLW   SVAL/12D ; WPM_12
	RETLW   SVAL/13D ; WPM_13
	RETLW   SVAL/14D ; WPM_14
	RETLW   SVAL/15D ; WPM_15
	RETLW   SVAL/16D ; WPM_16 
	RETLW   SVAL/17D ; WPM_17
	RETLW   SVAL/18D ; WPM_18
	RETLW   SVAL/19D ; WPM_19
	RETLW   SVAL/20D ; WPM_20
	RETLW   SVAL/21D ; WPM_21
	RETLW   SVAL/22D ; WPM_22
	RETLW   SVAL/23D ; WPM_23
	RETLW   SVAL/24D ; WPM_24
	RETLW   SVAL/25D ; WPM_25
	RETLW   SVAL/26D ; WPM_26
	RETLW   SVAL/27D ; WPM_27
	RETLW   SVAL/28D ; WPM_28
	RETLW   SVAL/29D ; WPM_29
	RETLW   SVAL/30D ; WPM_30
	RETLW   SVAL/31D ; WPM_31
	RETLW   SVAL/32D ; WPM_32
	RETLW   SVAL/33D ; WPM_33
	RETLW   SVAL/34D ; WPM_34
	RETLW   SVAL/35D ; WPM_35
	RETLW   SVAL/36D ; WPM_36
	RETLW   SVAL/37D ; WPM_37
	RETLW   SVAL/38D ; WPM_38
	RETLW   SVAL/39D ; WPM_39
	RETLW   SVAL/40D ; WPM_40
	RETLW   SVAL/41D ; WPM_41
	RETLW   SVAL/42D ; WPM_42
	RETLW   SVAL/43D ; WPM_43
	RETLW   SVAL/44D ; WPM_44
	RETLW   SVAL/45D ; WPM_45
	RETLW   SVAL/46D ; WPM_46
	RETLW   SVAL/47D ; WPM_47
	RETLW   SVAL/48D ; WPM_48
	RETLW   SVAL/49D ; WPM_49
; SENDMSG:
;    Sends message pointed to by W
; Be careful of case where message table 
; grows so large that it pushes this code
; above 0xff or a CALL instruction will 
; not be able to reach it.
; Uses AL, DH (DH = MSGIDX)
SENDMSG
	MOVWF   DH              ; Store index
S0LOOP
	BTFSC   PROCLAT, USERON ; Determine data source
	GOTO    S0USER
	CALL    GETMSG          ; Get *DH++ in W
	GOTO    S0CONT
S0USER
	MOVF    INDF, W         ; Get *USERRAM++
	INCF    FSR, F
S0CONT
	MOVWF   AL
	MOVLW   M_END           ; End delimiter ?
	SUBWF   AL, W
	BTFSS   STATUS, Z       ; Skip if no compare
	GOTO    S1CONT
	BTFSS   PROCLAT, USERON ; End of user or end of message ?
	GOTO    S1DONE
	BCF     PROCLAT, USERON
	GOTO    S0LOOP
S1DONE
	BCF     STATUS, PC9     ; Clear PAGE bit, we are done here
	BCF     PROCLAT, USERON ; Clear User mode (case: user msg aborted)
S1CONT
	MOVLW   M_USER          ; Toggle to User Mode ?
	SUBWF   AL, W
	BTFSC   STATUS, Z       ; Skip if no compare
	GOTO    S1USER
	MOVLW   M_CALL          ; Toggle to Callsign Mode ?
	SUBWF   AL, W
	GOTO    S1CALL
	MOVLW   M_SKIP          ; Skip entry ?
	SUBWF   AL, W
	GOTO    S0LOOP
	MOVLW   M_SP            ; Word space ?
	SUBWF   AL, W
	BTFSS   STATUS, Z       ; Skip if compare
	GOTO    S2LOOP
	BCF     STATUS, PC9     ; Clear PAGE bit for low page call
	CALL    WORDSPACE       ; Word Space = 7 time bits
	BSF     STATUS, PC9     ; Set PAGE bit on return
	GOTO    S0LOOP
S1CALL
	GOTO    S100
S1USER
S100
	MOVWF   FSR
	BSF     PROCLAT, USERON
	GOTO    S0LOOP
S2LOOP
	BTFSS   GPIO, XDAHPDL
	GOTO    ABORT1  
	BTFSC   GPIO, XDITPDL
	GOTO    NOABORT
ABORT1
 ifdef BEACON
 endif
	CLRF    PROCLAT
	BTFSC   GPIO, XDAHPDL    ; Wait till hands off paddle
	BTFSS   GPIO, XDITPDL
	GOTO    ABORT1
	GOTO    S1DONE
NOABORT
	GOTO    S2CONT
	GOTO    S0LOOP
S2CONT
	GOTO    S2DAH
	CALL    DITOUT
	GOTO    S2LOOP
S2DAH
	CALL    DAHOUT
	GOTO    S2LOOP
; Get a Morse Character from User
; Value returned in AH
; Uses AL, DH
GETCW
	CLRF    AH              ; Start with empty frame
	MOVLW   08H             ; Init bit count
	MOVWF   AL
	MOVLW   GC_TO_L         ; Init timeouts
	MOVWF   DELAYLO
	MOVLW   GC_TO_M         ; Init timeouts
	MOVWF   DELAYHI
	MOVLW   GC_TO_H         ; Init timeouts
	MOVWF   DH
GCLOOP
	CALL    SAMPLE  
	BSF     STATUS, PC9     ; Set PAGE bit back for high access
	BTFSS   PROCLAT, DITPDL  ; Both Dit
	GOTO    GCSINGLE
	BTFSC   PROCLAT, DAHPDL  ;          and Dah ?
	GOTO    GCTOGGLE
GCSINGLE
	GOTO    GCDIT
	BTFSC   PROCLAT, DAHPDL  ; DAH Paddle closed when = 1
	GOTO    GCDAH
	DECFSZ  DELAYLO, F      ; Inner loop test
	GOTO    GCLOOP
	MOVLW   GC_TO_L         ; Reset inner loop
	MOVWF   DELAYLO
	DECFSZ  DELAYHI, F      ; Middle loop Test
	GOTO    GCLOOP
	MOVLW   GC_TO_M         ; Reset middle loop
	MOVWF   DELAYHI
	DECFSZ  DH, F           ; Outer loop Test
	GOTO    GCLOOP
	GOTO    GCJUST          ; Timed out, we are done, now justify
GCTOGGLE
	GOTO    GCTOGL1
	MOVLW   PROCMASK        ; Mode A, kill any in latch
	ANDWF   PROCLAT, F
GCTOGL1
	BTFSC   PROCLAT, OUTLAST ; If Dit was last send a DAH
	GOTO    GCDAH
GCDIT
	CALL    DITOUT
	BCF     STATUS, C       ; DIT is 0
	GOTO    GCLOAD
GCDAH
	CALL    DAHOUT
	BSF     STATUS, C       ; DAH is 1
GCLOAD
	RLF     AH, F           ; Shift left 1, CARRY->LSB
	DECFSZ  AL, F           ; Decrement bit count
	GOTO    GCLD1
	GOTO    GCERR           ; Overflow, treat as null
GCLD1
	MOVLW   GC_TO_L         ; Restart timeouts
	MOVWF   DELAYLO
	MOVLW   GC_TO_M         ; 
	MOVWF   DELAYHI
	MOVLW   1               ; set a shorter 2nd timeout
	MOVWF   DH
	GOTO    GCLOOP
GCJUST
	BSF     STATUS, C       ; Add tag bit
	GOTO    GCJ2
GCJ1
	BCF     STATUS, C       ; Fill in bottom
GCJ2
	RLF     AH, F           ;   with zeroes
	DECFSZ  AL, F           ; Keep going till left justified
	GOTO    GCJ1
GCDONE
	BCF     STATUS, PC9     ; Clear PAGE bit for low page return
	RETLW   0
GCERR
	MOVLW   M_TO            ; Overflow error treated as a timeout
	MOVWF   AH
	GOTO    GCDONE
; This was moved here from the low page to
; free up some code space. It's function is
; to load fixed callsign into RAM.
XFRSTUB
	MOVLW   CALL_0
	CALL    XFRIDX
	MOVLW   CALL_1
	CALL    XFRIDX
	MOVLW   CALL_2
	CALL    XFRIDX
	MOVLW   CALL_3
	CALL    XFRIDX
	MOVLW   CALL_4
	CALL    XFRIDX
	MOVLW   CALL_5
	CALL    XFRIDX
	MOVLW   CALL_6
	CALL    XFRIDX
	MOVLW   CALL_7
	CALL    XFRIDX
	BCF     STATUS, PC9     ; Clear PAGE bit for low page goto
	GOTO    XFRRET
;       Code Practice
; Generates pseudo random numbers by hopping
; though a morse character table with a constantly
; incrementing index. The index is incremented on
; every pass by an odd valued skip factor. A new
; skip factor is used periodically. The interval
; of the period is "randomly" read from the timer.
; Note that by virtue of the fact that the skip
; can cause a table bounds wrap, both positive
; and negative moves occur.
; DH = Skip,  DL = Running index, AH = Loop count
PRAC_RUN
	CLRF    DL              ; Clear index
PRCLP0
	MOVF    TMR0, W       ; Get an initial skip factor
	MOVWF   AH              ; save loop count
	IORLW   01H             ; make it odd
	ANDLW   01FH            ; 1 -> 31
	MOVWF   DH
PRCLP1
	MOVF    DH, W           ; Get skip value in W
	ADDWF   DL, F           ; Add to index
	MOVLW   -43D            ; If > 42 wrap around
	ADDWF   DL, W           ; Carry will be set on wrap
	BTFSS   STATUS, C       ; Value wrapped, use wrapped value
	MOVF    DL, W           ; Value was within limits, use it as is
	MOVWF   DL              ; Update index in case we wrapped
	CALL    GETPRAC
	BCF     STATUS, PC9     ; Clear page bit for low page call
	CALL    OSCHAR
	BTFSC   GPIO, XDITPDL    ; loop till paddle hit
	BTFSS   GPIO, XDAHPDL    ; loop till paddle hit
	GOTO    PRCDONE         ; paddle hit: leave
	DECFSZ  AH, F           ; decrement loop count
	GOTO    PRCLP1          ; NZ: Continue
	GOTO    PRCLP0          ; Z:  Get new skip factor & loop count
PRCDONE
; Convert CW Character Into Table Index
; Input: CW in AH
; Return: Index in AH
; Uses: AL, AH
; Note: A timeout code (M_TO) will be handled
; the same as an illegal code, .ie it won't
; be found in the table.
CW2IDX
	MOVF    AH, W           ; Transfer AH to AL
	MOVWF   AL
	MOVLW   M_A             ; A ?
	SUBWF   AL, W           ; Compare
	RETLW   0
	MOVLW   M_C             ; C ?
	RETLW   01D
	MOVLW   M_F             ; F ?
	RETLW   02D
	MOVLW   M_I             ; I ?
	RETLW   03D
	MOVLW   M_K             ; K ?
	RETLW   04D
	MOVLW   M_L             ; L ?
	RETLW   05D
	MOVLW   M_S             ; S ?
	RETLW   06D
	MOVLW   M_T             ; T ?
	RETLW   07D
	MOVLW   M_U             ; U ?
	RETLW   08D
	MOVLW   M_X             ; X ?
	RETLW   09D
	MOVLW   M_Z             ; Z ?
	RETLW   10D
	BCF     PROCLAT, CONVERSE ; End converse mode
	MOVLW   M_D             ; D ?
	RETLW   11D
	MOVLW   M_M             ; M ?
	RETLW   12D
	MOVLW   M_P             ; P ?
	RETLW   13D
	MOVLW   M_W             ; W ?
	RETLW   14D
	RETLW   15D             ; Unknown command
; Convert to ONES
; Valid numbers are returned with MSB set,
; Input: AH  Output:W
CONV_LO
	MOVLW   M_1             ; 1 ?
	SUBWF   AH, W           ; Compare
	RETLW   01D+80H
	MOVLW   M_2             ; 2 ?
	RETLW   02D+80H
	MOVLW   M_3             ; 3 ?
	RETLW   03D+80H
	MOVLW   M_4             ; 4 ?
	RETLW   04D+80H
	MOVLW   M_5             ; 5 ?
	RETLW   05D+80H
	MOVLW   M_6             ; 6 ?
	RETLW   06D+80H
	MOVLW   M_7             ; 7 ?
	RETLW   07D+80H
	MOVLW   M_8             ; 8 ?
	RETLW   08D+80H
	MOVLW   M_9             ; 9 ?
	RETLW   09D+80H
				; fall thru to pick up 0 or T
				; or error
; Convert to TENs
CONV_HI
	MOVLW   M_T             ; T for 0 ?
	RETLW   00D+80H
	MOVLW   M_0             ; 0 ?
	RETLW   00D+80H
	MOVLW   M_1             ; 1 ?
	RETLW   10D+80H
	MOVLW   M_2             ; 2 ?
	RETLW   20D+80H
	MOVLW   M_3             ; 3 ?
	RETLW   30D+80H
	MOVLW   M_4             ; 4 ?
	RETLW   40D+80H
	RETLW   00D             ; Error for value > 49 or non-numeric
	END
