Ana Sayfa => Ben yaptım oldu! *** => Konuyu başlatan: TB5X_SK - 02 Mart 2011, 00:44:43
Bir şüredir uğraştığım QRP Forty1 devresini bitirerek nihayet kutulamayı da başardım. Yakışıklı bir cihaz oldu. 2 Watt çıkışı var. İlerde zaman bulursam Bir çıkış ekleyerek watını arttırmayı düşünüyorum. Bunun için kutuda bir yer bıraktım. Kutuyu el ile bükerek yapmaya çalıştım. Biraz hatalar oldu ama yinede idare eder. Dış kasaya birde boya yaparsam daha güzel olur sanırım..
İmalattan resimler:
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW1zt4thPMI/AAAAAAAAC_E/w97WVtHN5pE/s640/3.JPG)
(https://lh4.googleusercontent.com/_Yvs7Dm8Tvik/TW1zvEwy6YI/AAAAAAAAC_I/fPw-jyo3Apo/s640/5.JPG)
(https://lh3.googleusercontent.com/_Yvs7Dm8Tvik/TW1zwZ7QaAI/AAAAAAAAC_M/cMuEuYcdTLY/s640/2.JPG)
(https://lh4.googleusercontent.com/_Yvs7Dm8Tvik/TW1zxzbziuI/AAAAAAAAC_Q/TfZ1BnJ77yY/s640/1.JPG)
(https://lh5.googleusercontent.com/_Yvs7Dm8Tvik/TW1zzHovwiI/AAAAAAAAC_U/arMdW7bO-cA/s640/6.JPG)
(https://lh4.googleusercontent.com/_Yvs7Dm8Tvik/TW1z1vz4_hI/AAAAAAAAC_c/9y4wDup3TOY/s640/IMG_1916.JPG)
(https://lh3.googleusercontent.com/_Yvs7Dm8Tvik/TW1z3N-BGbI/AAAAAAAAC_g/lnNI7RpgB8c/s640/IMG_1917.JPG)
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW1z4sAuy3I/AAAAAAAAC_k/jmBSeOx-nPU/s640/IMG_1918.JPG)
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW1z7ed7NRI/AAAAAAAAC_s/qlDXg1_p48o/s640/IMG_1926.JPG)
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW1z83Z5jPI/AAAAAAAAC_w/g8CvY5S8pok/s640/IMG_1927.JPG)
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW1z99CZC9I/AAAAAAAAC_0/hDvVNkUmTzY/s640/IMG_1925.JPG)
(https://lh5.googleusercontent.com/_Yvs7Dm8Tvik/TW1z_XDyeYI/AAAAAAAAC_4/vfUMf9xN9F0/s640/IMG_1931.JPG)
(https://lh3.googleusercontent.com/_Yvs7Dm8Tvik/TW10AWRAWgI/AAAAAAAAC_8/GCTe09djLqQ/s640/IMG_1932.JPG)
(https://lh4.googleusercontent.com/_Yvs7Dm8Tvik/TW10BvzwgYI/AAAAAAAADAA/4VD1EuAwO1c/s640/IMG_1933.JPG)
(https://lh5.googleusercontent.com/_Yvs7Dm8Tvik/TW10C6KADxI/AAAAAAAADAE/EYCPxVT6FRw/s640/IMG_1937.JPG)
(https://lh5.googleusercontent.com/_Yvs7Dm8Tvik/TW10EFNf6rI/AAAAAAAADAI/UOozxYCSRCM/s640/IMG_1938.JPG)
(https://lh6.googleusercontent.com/_Yvs7Dm8Tvik/TW10FP7wdtI/AAAAAAAADAM/A6Yub4Q8sOc/s640/IMG_1939.JPG)
Yapacak arkadaşlara fikir verir diye yayınlıyorum.. Herkese 73 ler..
Mehmet DİVİLİ
www.tb5x.com
QRP çok güzel olmuş elinize sağlık, sormak istediğim birkaç şey var. Yardımcı olursanız çok sevinirim.
Pcb yi nerden aldınız veya nasıl yaptırdınız? Kaça mal oldu? Uzun süredir bir qrp yapmak niyetindeyim ancak sırf pcb yüzünden sürekli erteliyorum. Lazer printerla birkaç denemem oldu ama yapamadım, elle çizmek içinde fazla zor, PCB bulursam bende qrp'cilerin arasına katılcam :)
Frekans metrenin şemasını ve hex dosyasına link verebilir misiniz? benim yaptığım frekans metrelerin gösterim şekli biraz farklı sizinki daha hoş gözüküyor.
73, Mutlu
Sevgili TB2HL;
Baskı devreyi çıkartmak biraz zahmetli evet. Hatlar birbirine çok yakın olduğundan ütüleme yönteminde sıkıntılar olabiliyor. Benim elimde birkaç tane hazır plaket vardı. Onları kullandım.. Kendim hazırladığım plaketler de var.
Sahibinden.com da bir arkadaş hazırlamış satıyor aşağıdaki linkten ulaşabilirsiniz. Biraz fiyatlı geldi bana ama uğraşamam diyenler için iyi olabilir
LİNK:
http://www.sahibinden.com/ilan/alisveris-elektronik-lisanssiz-telsiz-40m-forty-2b-qrp-le-forty2-synthesized-baski-devreleri-43562483/detay?
http://www.sahibinden.com/ilan/alisveris-elektronik-lisanssiz-telsiz-40m-forty-1b-qrp-baski-devreleri-43538569/detay?
Şu an işyerindeyim. Frekansmetre katı ile ilgili hex ve baskı devre materyallerini akşama buradan paylaşırım..
Kolay gelsin ... 73 ler..
İşte bu , elinize sağlık 73
Mehmet hocam tertemiz ve özenli çalışmanızdan ötürü tebrik ederim. her zaman söylediğim gibi amatör ufkumuzu açıyorsunuz. teşekkürler...
Cihaz konusunda ellerinize sağlık.
Frekansmetre ile ilgili bir bilgi vermek istiyorum. Internette pek çok şema ve bilgi var, çeşit çeşit de kit satılıyor. Ben en son şu adresteki frekansmetre kitini getirttim ve çok memnun kaldım, 80 MHz'e kadar gayet güzel çalışıyor, fiyatı da uygun (posta dahil 20 küsur dolar), tavsiye ederim. Plaketin boyutları tam 16x2 LCD ekran kadar olduğundan her yere sığıyor, ayrıca birkaç tane ara frekans (I.F.) ayarlamanıza da izin veriyor. Isterseniz seri bağlantılı LCD'ler ile de (16x1, 8x2 vb) kullanmak için de bağlantı yerleri hazır.... Montajı 15 dakika sürüyor, ilgilenen arkadaşlara duyurulur:
http://www.pongrance.com/ddfc-cc.html
Yorum yazan arkadaşlara tek tek teşekkür ediyorum.
Benim kullandığım frekansmetre ve hex dosyasını aşağıdaki linkten indirebilirsiniz.
1x16 veya 2x16 LCD ekran ile kullanabiliyorsunuz ikiside doluyor.
Bunda da arafrekansı el ile istediğiniz değeri girebiliyorsunuz.
LİNK: http://hotfile.com/dl/108342584/d37cbed/frekansmetre_tb5x.com.rar.html
Yapacak arkadaşlara başarılar... 73 ler...
çok güzel olmuş elinize sağlık.
neosid ve toroid filtre temini konusunda yardımcı olabilirmisiniz?değerlerini bir türlü tutturamadım hazırları var ise bu konuda yardım istiyorum.
sizin kullandıklarınız nasıl?
başarılı çalışma..iyi günlerde kullanın.
Çok güzel olmuş, tebrikler..
Havada karşılaşabilmek ümidiyle. 73!
Atila
Ellrine saglık gerçekten güzel bi çalışma olmuş
benim cihazın ufak defek eksikleri kaldı inşallah tam bittiginde son haliyle resmi gönderirim
Elinize sağlık .. çok güzel olmuş.. Çalışmanızda kullandığınız frekansmetre ve 4x16 lcd li sinyalmetre ve watt metre katının da dokumanlarını paylaşırsanız seviniriz.. İncelemek isterim..
73 ler...
bu nasıl bir güzelliktir. ellerinize sağlık TA3QJ. 73's
yorumlarınız için teşekkürler frekans metre kullanmadım program ve yazılımı kendim yazdım ekranda frekans okumuyo
direk hangi frekansa gidersek o frekans da pll entegresine o frekans ın data bilgisini gönderiyo
işlerimin yogunlugundan dolayo çok vakit ayıramıyorum ama bittiginde tüm belgeleri buradan yayınlarım
herhangi bir yerden alıntı degildir tamamen kendi tasarımım ve yazılımım dır bittiginde inşallah tüm arkadaşlar faydalanır
izmir den 73 ler
Ali bey çok güzel bir tasarım olmuş elinize sağlık uzun zamandır 439.200'ede giremiyorum bölgedeki arkadaşlara selamlar.
merhaba.
teşekkürler.
hex dosyası güzel çalıştı.
elinize saglık.
(daha önce plaketi hazırdı)
de ta7bb
Mehmet hocam Maşallah berekallah.Çalışmanızı çok beğendim. Ellerinize sağlık. Güzel olmuş.
TB 5X...TA3QJ..HARİKA ÇALIŞMALARINIZ GERÇEKTEN ÖVGÜYE DEĞER...TEK KELİME İLE """BRAVO"""..
BU ARADA TB1CIG ARKADAŞIN DA HAKKINI YEMEMEK LAZIM..AMATÖRCE ÇALIŞMALARI CİDDEN TAKDİRE ŞAYAN..
ANCAK KENDİ REKLAMINI YAPMIŞ OLDUĞU SPOT...""BİR HARİKA""..SİZİN ÇALIŞMALARINIZI GÖLGEDE BIRAKACAK CİNSTEN..
SAYGILARIMLA...
TB3ATA...M.TURGAY...73
Cihazın çalışmasını merak edenler için..
http://www.youtube.com/watch?v=JNHe3_dzsBE&feature=g-upl
Herkese 73 ler...
mehmet hocam elinize sağlık cok güzel bi çalışma olmuş.Bu günkü görüşmemizi sanırım bu cihaz ile yaptınız.Tekrar tebrik ediyorum.73..
Evet Ali Bey bu cihazdı..
Sizden 2 3 dk sonra da TA5CO Orçun beyle QSO yaptım..
Ayrıca Trabzon Pervaneköy TA7CA Emin abi ile de bu gün bu cihaz ile QSO yapma şansım oldu..
Teşekkürler, 73 ler...
