Olay Elecraftın modeline benzerliğe doğru gidiyor
Move Up from 20W
Step up to full 100W HF operation without building the station around a separate amplifier. The G7250 puts full-power output in the radio itself, reducing the extra equipment, cabling, and power connections needed around the operating position.
A Cleaner Station Layout
Keep the display, tuning knob, buttons, and touchscreen where you operate, while placing the RF unit where it best fits the station. The split RF unit and control head give you more flexibility without turning the desk into a stack of boxes.
Digital and CW Ready
A built-in USB sound card and USB interface support a one-cable FT8 computer connection. CW and digital-mode tools are integrated into the radio, so CE-19 and DE-19 interfaces are not required for the G7250's supported digital-mode connectivity.
Two Antennas, One Radio
Keep two HF/6m antennas connected and select between them through the built-in antenna switch. The internal automatic tuner adds practical matching support without requiring another tuner on the desk in many station setups.
Core Features
100W HF / 90W 6m Output
Full-power operation is built into the radio: up to 100W on HF and 90W on the 50MHz band. It is a direct step up for operators who want more output than a 20W-class radio without adding a separate amplifier.
Split RF Unit and Control Head
The RF main unit and 7-inch control head can be positioned independently. Keep the controls within easy reach and place the RF unit where it works best for your station layout.
7-Inch Touchscreen + Physical Controls
The high-resolution capacitive touchscreen makes the spectrum and waterfall easy to read, while dedicated physical buttons and an optical tuning knob remain available for the controls operators use most often.
Direct RF Sampling SDR
Incoming RF is converted and processed through an A/D and FPGA signal chain. Multi-stage filtering and high-Q inductors support signal selection across the covered bands.
Built-In ATU with Tuning Memory
The internal automatic antenna tuner covers a specified 20–150Ω matching range. A new tuning cycle completes within 10 seconds, while saved tuning parameters can be recalled in as little as 0.1 second when returning to a previously tuned band.
Digital Modes Without an Extra Interface Box
The integrated sound card and USB interface simplify computer connection for supported digital-mode operation, including a one-cable FT8 workflow. Keep the connection chain straightforward and the station easier to maintain.
Useful Operating Tools
50Hz CW Narrow Filter
Fine filtering for crowded CW operation.
CW and Digital-Mode Decoding
Integrated decoding tools for supported operating modes.
Preset CW Messages
Store frequently used CW messages for faster repeated calling.
Voice Recording and Call Playback
Record and replay commonly used voice calls from the radio (requires additional microSD-memory card).
SWR Scan
Check antenna behavior across a frequency range directly from the radio.
Noise Reduction and Noise Blanker
Built-in DSP tools for managing unwanted noise.
1Hz Minimum Tuning Step
Fine frequency adjustment when it matters.
FM Broadcast Reception
Receive 78–108MHz WFM broadcast stations.
