Gönderen Konu: MFJ-1835 Cobweb Antenna  (Okunma sayısı 9465 defa)
Çevrimdışı TA5JJ
« : 07 Haziran 2017, 18:14:15 »
Yine bir saheser...
Tabi  kullanmak icin kendine mekan ve zaman yaratabilen icin....
This five-band (20, 17, 15, 12, 10 Meters) half-wave Cobweb Antenna is perfect for restricted space or portable operation. Sky-gray fiberglass spreaders and nearly invisible wire elements (flat 9x9x1/2 feet square. 8 pounds), blend in with your surroundings while standing tough against nasty weather.
Horizontally polarized for less local noise pickup plus solid gain over verticals will allow you to work DX easily — even on QRP. Radiation pattern is nearly omni-directional so you don’t need a rotator. No radials needed! Low SWR is due to MFJ’s exclusive Spider-MatchTM broadband network. Use lightweight TV hardware to mount it on your chimney, balcony, fence post or other. SO-239.
Ynt: MFJ-1835 Cobweb Antenna
« Yanıtla #1 : 20 Haziran 2017, 20:45:09 »
Montajını Ecnebi Ablalardan izleyelim https://www.youtube.com/watch?time_continue=10&v=JXqCC6i639U
