Ana Sayfa > Neler, neler yapmışlar! ***
**AMERİTRON ALS-1300***
<< < (3/4) > >>
TA2OD:
Turgay bey güle güle kullanın.
Gücü ve fiyatı çok güzel. http://www.ameritron.com/Product.php?productid=ALS-1300 merak edenler linktende inceleyebilir
TA2AHI:
Güle güle kullanın gerçekten harika.
TA3EP:
Hay maşallah, gerçekten çok güzel cihazmış. Propagasyon falan istemez, kafadan direkt okyanus aşırı görüştürür herhalde bu...
TA3ATA:
BESLEME KAYNAĞI İÇİNDE DEĞİL..
AMİTRON  ALS-1300 SPS...
Output Power: Typically 1200 Watts PEP SSB/CW, 600 Watts
continuous.
Input SWR: 1.5:1 or less
Operate/Standby Switch: Selects exciter or full amplifier power instantly.
T/R Switching: Typically 5ms relay switching
T/R Relay Drive: 12VDC at 15ma, ground to enable
Indicators: ALC, SWR, PA and TX LED indicators
Metering:
Current: Simultaneous monitors individual 600-watt module current
Multi-Meter: FWD/REF Power, PA Unbalance, ALC, HV1, HV2
Inrush Current Protection: Step-start extends life of power supply components.
Power Requirements: 240VAC/12 amps (default), 120VAC 20 amps
Dimensions (ALS-1300): 7"H x 10.5"W x 17.5"D
Dimensions (ALS-1300SPS): 7"H x 10.5"W x 14”D
Weight, Amplifier Section: 23 pounds
Weight, Power Supply: 13 pounds
The ALS-1300SPS
TA3D_SK:
Yuksel Bey,
iyi gunler,
Yok daha neler?? 300 Amper dile kolay, mumkun degil 30 Amper belki...
selam ve sevgilerimle.
yasar GOCET
TA3D/VU
